Question about Gaggia Titanium Espresso Machine
Getting a pinch clamp off
Need to get pinch clamp off water hose connected to steam value
How do you change out a bad water pump on kenmore stackable model 417. 917 02000
go to an autoparts store and get a radiator hose pinch off plier pinch off the top tub to pump hose so that the water does not run out when you remove the water pump hose clamps; then remove the pump or, open it up to remove the impeller (fan) obstruction if that is the problem
Feb 04, 2013 | Washing Machines
My washing machine want drain out the water but it will spin what do you think the problem is is there a relay for that.
The pump is most likely clogged. this is a direct drive pump, which is connected to the
motor, Usually it is a small sock in most cases. You will need to drain as much water
as you can (A shop vac is ideal for this) and **** the water from the drain hose as
well before detaching the hose clamp from the tank to the pump. Use a kitty pan to
catch the remaining water. The pump is accessed by having someone tilt the
unit to access the underneath. Pinch the spring clamps and move them back to remove
hoses. Unplug the unit before servicing. Hope this helps.
Apr 26, 2011 | Roper RAS8445KQ Top Load Washer
I pumped my steam mop to get started as I always do. I heard a loud pop and now it won't produce steam and leaks water on the floor.
The mop broke...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Jun 15, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Rancillio Expresso Machine won't pump water through. Makes lound noise.
Hi There are a couple of things. 1. Your pump is not primed. Open the steam knob and push the middle switch. 2. Your intake hose is pinched or not connected to the pump, or your intake hose is not in the water tank.
Feb 21, 2010 | Rancilio Silvia Espresso Machine
Cleaner willnot dispense water and vaccum it again. Soap dispense fine. would like a owners manual.
sounds like you have a clog in the waterline, or a pinched hose.
Locate the water line hose, disconnect, and blow through with can of compressed air.
If nothing goes through...you have a blockage/pinch.
Sep 18, 2009 | Bissell 1699 ProHeat Clear View Upright...
Hoover steam vac hose broken so I get no suction.
The entire hose has to be replaced. I beliive they run about 39.99
Jun 11, 2009 | Hoover F5872-900 SteamVac Wet/Dry Vacuum
Steam coming out of vents and water runnind down inside of dash
Your heater core has corroded through. You need a new heater core. You may be able to get by temporarily, with bypassing the heater core hoses, located in the engine compartment. These hoses carry coolant heated from the engine, to the heater core. You remove the hoses from the core, and put a pipe in the middle, connecting the two hoses together using hose clamps.
Should there be a cool morning, or if you need the defroster, you won't have warm air. Just a temporary fix.
May 10, 2009 | Mitsubishi Cargo Cars & Trucks
I have a kenmore washer 80 series that over flowes help please
I had the same problem with a 90 series and there is a small hose connected to the water level knob that had slipped off.
Jan 21, 2009 | Kenmore 24032\24036 Top Load Washer
I have an affinity washer by frigidaire and I am getting an e20 problem code. The link will not work for the product manual from the company and the link on Fixya also does not work can someone help...
E20 = Clogged drain pump.
Tools I used: vice grips, both phillips and standard screw drivers, flash light and an 8mm socket with ratchet.
I solved this problem by removing the rear oval type cover by removing the 6 phillips screws that hold it on, but first thing is to unplug the machine! I unplugged the electrical connection going to the pump. Then I removed the hose closest to me by removing the pinch clamp with a pair of vice grips. Then I removed the two screws holding the pump down to the frame of the washer (8mm socket). Then I removed the farthest hose by removing the pinch clamp with the vice grips. Once this was done I took out the pump. The hose entering the pump contained a sock, debit card and thirty-five cents!
Once I removed all of the debris I reversed the order but this time I used an automotive hose clamp which makes re-assemble waaay easier!!! (Saves about 30 mins) Total repair time took me 1 hour, but if you use an aftermarket hose clamp instead of the pinch clamp on the hose coming into the pump this will save you at least 30 minutes because it is soo difficult to put back on because of the tight space.
One-hour, a minor cut and $2.35 for the clamps later all is fixed!
Jan 19, 2009 | Frigidaire Affinity ATF7000ES Front Load...
How do I take my Affinity washer apart to fix an E20 clog problem
Jun 08, 2008 | Frigidaire GLTF2940ES Front Load Washer
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
