Question about Toshiba SE-R0305 Remote Control
How do I fix DVD recorder remote jammed keys?
Not all letters will working when labeling and keys responding poorly when programming.
  • 14 Answers
Could be damp and dirt inside the controller caused by sweaty hands, just wipe clean But not too hard or it will cause the other possible fault which is that the carbon coating on the rubber keypad has worn off. I have cured this for a short time by fixing silver foil with super glue on the rubber contacts. But only lasted 4-5 months because rubber flexes, maybe another glue or a conductive paint of some kind would be better.
Posted on Feb 11, 2012
Insignia_Remote_Codes_I need the program codes for my ILO DVDR04 Recorder using my insignia remote.
If codes for your product are not listed in the User Manual for your TV, then you may use the search function to find a working code. Full details can be found in the User Manual, but basically:1. Turn on the device you wish to control2. Press the device button on your remote (DVD in this case)3. Press and hold SET until the red LED blinks twice, then release4. Enter 9 9 1; the LED blinks twice5. Press the number that matches your device type (2 for DVD)6. Aim the remote and press the power button; if the device responds go to step 87. If the device doesn't respond, press the CH ^ key until the device turns off8. Press SET to store the code
Remember that not every universal remote will control every device and, if the search fails, the remote is not compatible with your DVD recorder. I hope this helps.
Nov 07, 2011 | iLO DVDR04
How to clear remote so I can program it again
Link to the manual
http://audiovox2.info/docs/rca_acc/man/D770_DOC_OM.PDF
Problem: The remote is not
performing commands properly.
• You must put the remote in the
correct mode by pressing the
corresponding component key (TV,
VCR, DVD, SAT, AUX1, AUX2) so
the remote knows which component
you want to operate.
• Make sure the component is “ready”
(e.g., DVD player has disc loaded;
VCR has tape loaded, etc.).
• You may have pressed an invalid
key for the mode the remote is in
(e.g., the RECORD key only works
in VCR Mode).
• If you are trying to turn on an RCA,
GE or PROSCAN component, press
the component key (TV, VCR, DVD,
SAT, AUX1, AUX2) instead of the
ON·OFF key.
• If you’re trying to change channels,
try pressing the OK key after
entering the channel number as this
is a requirement of certain models
and brands.
*There is a possibility that a
programmed code may only be able
to control some of your component
features (e.g., only turns a
component on and off). Follow the
steps provided for programming the
remote (See Programming sections
on pages 5–7). If the component can
be turned on and off, make sure you
press the CH+/CH- key to see if the
component responds. If not, try the
next code from the list.
Good Luck :)
PLEASE rate my solution
Dec 18, 2009 | RCA DIRECTV Satellite Remote Control
LG RH266 DVD/HDD RECORDER The HELLO message keeps repeating when turning the unit on. So cannot receive picture etc Is there a code from the remote to fix this or a part replacement ?
hi,i have an lg 389h dvd recorder,it just says hello scrolling across the display,and doesnt respond to any functions on the,remote control,any ideas,cheers.
Oct 14, 2009 | LG DR787T DVD Recorder
Sony rdr gx360 only responds by displaying "DVD3" to remote cntrl
http://www.docs.sony.com/release/RDRGX360_EN_ES.pdf
Page 23 in the manual. Had the same problem. Press and hold ENTER and 3 for at least 3 seconds. Problem fixed
Dec 17, 2008 | Televison & Video
Remote control
turn on the dvd player
press and hold the 'enter' key and the '1' key at the same time
remote will start to work again
Sep 14, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
I have two panasonic recorders whose remotes compete. I reset one to setting 1 and the other to setting 2 to fix. Now one of the machines will not respond to either remote (the other is fine). How do I...
Try changing the settings back to the original setting on the remote that goes to the machine that is not responding. You might consider investing in a universal remote where you can program or self detect the frequency for each machine, but has a multi channel program setting so that you can have both machine frequencies on one remote. Let me know if this works or you need further assistance.
Jul 05, 2008 | Televison & Video
Remote control "enter" will not respond in DVD mode
I had the same problem. Powering down and rebooting (unplugging) the recorder fixed the problem.
Mar 12, 2008 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Universal remote
has anyone responded, I need the codes also.
Nov 05, 2007 | Lite On LVW-5115GHC+ DVD Recorder
DMR-ES30V remote and DVD panel buttons not responding
I assume you have fixed this by now, but if not, call panasonic's help line (number is in your owner's manual). They will walk you through the complete reset process (maybe 5 minutes). you will have to re-program everything the same as you did when it first came out of the box, but that doesn't take too long. Also, first try taking the batteries out of the remote. Make sure they are still good. Wait 60 seconds or longer, then replace batteries.
Jul 23, 2007 | Panasonic DMR-ES30VS DVD Recorder/VCR
Toshiba SE-R0305 Remote Control Logo
50 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
