Question about Sony PlayStation 2 (PS2) Console
Ps2 v12 laser adjustment - Sony PlayStation 2 (PS2) Console
5 Suggested Answers
SOURCE: Faulty PS2 v12
Best Solution: Purchase a cronit wire (the blue type, not green) from RadioShack for about $3. Unplug the unit & remove the back cover. At the lower left side - locate the Parker-laser mechanism. Splice one end of the cronit wire and attach it to the source then connect it to the center module (if no port is available - piggy back it onto another blue cronit wire) you'll see.
Posted on Mar 13, 2007
  • 13 Answers
SOURCE: Disks wont spin on new laser
Did you remove the anti static solder blob (point) on your new laser with a soldering iron and solder wick prior to installing it? The symptons your explaining indicate that point is still intact, If so you will need to carefully remove it first then reinstall the laser and try again.
Posted on Sep 20, 2007
Cerfer39
  • 709 Answers
SOURCE: Disk wont spin
First of all the new laser lens will not allow your Slim to read NTSC UC games if you have a PAL european Console.
There is no reason the New laser should have not read the disc unless it Came to you damaged. It sounds like you know how to replace a laser.
Posted on Oct 18, 2007
petraman7
  • 1175 Answers
SOURCE: I require instructions on how to replace the ps2 laser block
The screws are under the square caps on the bottom of the unit.
one may be covered w/ sticker.
Do a websearch for "changing laser pickup PS2" ...There's plenty of helpful sites.
Posted on Mar 25, 2009
Ps2 v12 clicking sound
Sounds like the CD/DVD drive is starting to fail.
Jun 27, 2012 | Sony PlayStation 2 (PS2) Console
Mar 25, 2009 | Sony PlayStation 2 (PS2) Console
Put in Sanandreas and it reads please put in a PS2 format disk
1. CLEAN THE LASER. ALWAYS DO THIS FIRST. MOST TIMES THIS IS ALL YOU NEED TO GET YOUR SYSTEM BACK RUNNING A 100% AGAIN
2. IF THE LASER CLEANING DON'T WORK ON YOUR PS2 SYSTEM PERFORMANCE THEN TRY ADJUSTING THE LASER VOTAGE.
3. IF THE LASER VOTAGE DON'T WORK YOU NEED TO REPLACE THE LASER
Dec 28, 2008 | Sony PlayStation 2 (PS2) Console
PS2 Modded Trouble Reading DVDr's
Your DVD potentiometer pot on the back of the PS2 laser lens needs to be readjusted. Some people will try to tell you it's out of alignment but if that was the case it would not read CD's. Some people will try to tell you the laser lens is bad. If that was the case it would not read CD's. On the back of the laser lens are two potentiometer pots. In english? Two lil screws that are turnable. One controls the power of the DVD laser one controls the power of the CD laser.
http://www.cyber-mag.com/station/laserV9.htm
That link will give you pretty lil pictures of what i'm talking about :)
In a nut shell the story goes like this folks. If your PS2 won't read certain game DVD's that are of a certain color or if it all of a sudden mysteriously fails to read games it once read but will play cd's just fine, the voltage of the laser for DVD's is not set correctly. (this does needs manual tweeking from time to time if you take your ps2 and move it around alot or if you take it over to friends houses etc etc. Basicly alot of movment in general can take this out of alignment. Even keeping the PS2 on it's side could theoreticly (just my opinion) based on gravitational pull, unbalance the potentiometer.
RESOLUTION:
Step 1 identify your PS2 version:
Version 1 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U1"
Version 2 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U0"
Version 3 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U2"
Version 4 - SCPH-30000, 30001, 35001, 30002, 35002, 30003, 35003, 30004, or 35004, 8 screws on bottom of case
NOTE: Version 4 has 2 varieties of motherboard: Gap/No Gap, the difference between v4 "Gap" and v4 "No Gap" is the "Gap" is there's a spot in the center of bios chip where each side lacks solder points.
Version 5 - SCPH-30000R, 30001R, 30002R, 30003R, 30004R, or 30006R. Also, some SCPH-30000, 30001, 30002, 30003, and 30004 models have a V5/V6
NOTE: Version 5 & 6 - the difference between these two versions is one of the connectors in the corner.
Version 7 - SCPH-39000, 39001, 39002, 39003, 39004, 39008 or 37000
Version 8 - Only in Japanese consoles. SCPH-39000, or, SCPH-39006 (GH-022 BIOS 090)
Version 9 - if you have SCPH-50000, 50001, 50002, 50003, 50004, 50006, or 50007 you have a v9 or v10 board.
Version 10 - SCPH-5000x, with date code "3D" to the right and below the serial number on the back of the console. (GH-026 board)
NOTE: To know if its a v9/v10 start up PS2 with no game in it ,press triangle and check dvd driver version dvd ver 3.00 = v9 & dvd ver 3.02 = v10.
If your model # is SCPH-50000, 50001, 50002, 50003 or 50004 AND if you can find a small ''a'' under the SCPH number or have DATECODE "3C" you have a V9 PS2 main board. (GH-026 board).
If your model # is SCPH-50000, 50001, 50002, 50003 or 50004 AND if you can find DATE CODE "3D" as shown below, you have a V10 PS2 main board. (GH-026 board).
Version 12 - The new slimline PS2 consoles are referred to as PSTwo here, but elsewhere they are also known as "v12" units... their numbers are SCPH-70011/SCPH-70012, and also SCPH-70004 CB (Belgium).
Step 2 use either google or the link above. If you're using google your keyword search will be something like "ps2 v12 laser lens adjustment" *replace v12 with your ps2 model.
In either case navigate to the site and follow instructions to set the pots back to their factory default settings.
Oct 11, 2008 | Sony PlayStation 2 (PS2) Console
Ps2
sounds like the laser is out of alignment, you can either try to adjust the laser or you can search ebay or other places for a replacement laser assembly for your model.
if you want to tackle the adjustment of the laser assembly then.
but first try this.
Aug 02, 2008 | Sony PlayStation 2 Slimline Console
Everytime i turn on the ps2 it says disc can not be read but nothing is wrong with the disc
try a nother ps2 if the games work then im sorry to say you need to replace the laser ? try one thing first ie give laser eye a clean then gently push laser to the back of ps2 and try a gain
Mar 08, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 probs
  • If you are using copy / pirate disks, the Ps2 Will not pick this up unless it is "chipped," which is very risky both in a way to harm the console and in a way to get you arrested as it is illegal.
  • If you've had the console a long time and not a problem like this before - The laser has probably burned out. No point in buying a new laser because you would be cheaper buying a new Ps2 Console
Jan 06, 2008 | Sony PlayStation 2 (PS2) Console
Sep 13, 2007 | Sony PlayStation 2 Slimline Console
Disk wont spin
Faulty PS2 v12
Hello shaundiane, first of all try by replacing the optical block unit. If the problem persists, continue with replacing the RS2004FS driver IC. Best regards, Arpi
Jan 24, 2007 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 (PS2) Console Logo
44 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
