Question about Amana 24 in. ADB2200AW Built-In Dishwasher
Adb2200 won't fill- not for usual reasons
Water IS available. Changed inlet valve. Still not filling. Float microswitch itself operating normally. Is this an AC or DC solenoid inlet valve??? Measured voltage at inlet solenoid is 115VAC. Is this normal? This voltage appears to be present even when the unit is off, oddly enough. No water is moving..... Really bugs me that valve doesn't power off when the cycle is cancelled. Unit works perfectly when pouring water in to run a cycle. Only fill is affected. It SEEMS that my replacement valve is as bad as the original, but why is it still apparently calling for fill even when it is off? The water line flows just fine into a container; the valve although powered is simply not allowing the unit to fill. Odd coincidence, quite aggravating really. Am I missing anything? I sure wish a schematic or normal component operating voltages were listed somewhere! Have to wonder if the solenoid is actually a DC device but the driver circuit is toast. Who will tell me what this circuit is supposed to be doing?
  • 58 Answers
SOURCE: Does not wash properly
easy test i came up with. take 5 coffee cups place them on the top rack upright. one in each corner and and one in the middle. do this after the dishwasher has started a cycle and is full with water. with the cups in place let the dishwasher run for one minute. then open the dood. the cups should be mostly full. if not, there is either not enough water or you have a pump problem.
Posted on Nov 02, 2007
ginko
  • 19396 Answers
SOURCE: Dishwasher will not drain.
Check first that the drain hose and the drain lines are not blocked.
Once you ensure that the drain lines are clear, this usually means that the drain pump is stuck, clogged or faulty.
Try first unplugging power cord for ten minutes.
If this does not help, the pump is clogged or defective.
The drain pump must be tested by energising it, if the pump is fine, then this is may be a faulty control, replace the control assembly in this case.
Use the number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
Posted on Nov 29, 2008
SOURCE: My ADB1500AW Amana dishwasher is leaking at the water fill sensor
i have adb1500 i have replaced all the board on front of door, and it leaks at the bottom of door.
Posted on Oct 18, 2009
  • 401 Answers
SOURCE: Dishwasher not filling with water
make sure you didnt kink the water hose,wires on tight.check the float inside the dishwasher .it should lift up and down freely if its stuck up (maybe something is under it) it wont let it fill.good luck!
ERIC
Posted on Jan 26, 2010
  • 901 Answers
SOURCE: My Dishwasher starts as usual,,,fills with water
Check the user guide manual. If resetting procedure is shown, follow it.
Otherwise the problem is with micro controller board. You have to contact the service provider as this is a computer program related fault.
If mechanical timer is used you can try cleaning them. But I doubt as the mechanical timers are no longer in use for the past few years.
Hope your incoming mains voltage is as per the recommendations!
110 V or 220 V as per your country standards.
Some times voltage fluctuations causes this problem. Should not be less than 10 % in any standard.
Posted on Sep 21, 2010
Dishwasher won't fill with water
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Kenmore Dishwashers
Bosch SHX46AO60C/30 won't fill with water. Have check water under sink - it is on. Motor will run, but no water. Have tried all cycles.
Hi
Daniel
Aug 29, 2011 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Switch dishwasher on and starts up ok but when it comes to pumping water in it stops and does not do anything else.
Hello
Investigate these five areas if your dishwasher won't fill with water:
As water is filling your dishwasher, a float rises along with it. When the float reaches a predetermined level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Check your float assembly. Replace it if you need to.
The water that fills your dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with your dishwasher's filling ability.
Your dishwasher may not be filling with water simply because the water valve's filter screens are dirty and debris-filled. Gain access to your water inlet valve and try cleaning it out. This might be enough to solve the problem. You can learn how to access your water inlet valve in the replace a dishwasher water inlet valve section.
Alternatively, your water inlet valve could be defective altogether. That could be the reason your dishwasher is not filling. Test it for continuity. If it is not functioning as it should, replace it.
Your dishwasher's drain valve is regulated by a drain solenoid. If the solenoid is malfunctioning, it may not allow the drain valve to funtion properly, which in turn could be the reason your dishwasher is not filling with water. Investigate your drain valve and test the solenoid. If the solenoid is faulty, replace it.
Aug 22, 2011 | Dishwashers
Dishwasher comes on but it won't fill.
Hi
Daniel
Aug 21, 2011 | Bosch 24 in. SHX46A02 / SHX46A06 Built-in...
Hello my tricity bendix dishwasher won't take in water, it will pump it out and when I turned water off at the mains and disconnected the water pipe and put it in a bucket turned mains back on the...
Hi
Daniel
Aug 11, 2011 | Tricity Bendix 24 in. DH102 Free-standing...
Water is not filling up.
Hi
Daniel
Aug 01, 2011 | Whirlpool Dishwashers
Unit won't fill with water
Hi
Daniel
Aug 01, 2011 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher will not fill have changed the inlet valve but still not filling.
Hi
Daniel
Jul 20, 2011 | Bosch Dishwashers
Dishwasher is not working will not fill with water
Hi
Daniel
Jul 20, 2011 | Neff 24 in. S5543X2 Built-in Dishwasher
Bosch dishwasher does not fill with water
Hi
Daniel
Jul 19, 2011 | Bosch Dishwashers
Amana 24 in. ADB2200AW Built-In Dishwasher Logo
42 people viewed this question
Top Amana Dishwashers Experts
Oloyede Monsuru
Mike
Kolbrun...
Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
