Question about Garden
How dose the carboretor work - Garden
    Sergeant:
  • 316 Answers
Hello sir, mower will not start or run, does it have good spark,good compression,or only runs on full choke,engine surges up and down, are you getting fuel to the engine if not try this, your carb. is clogged up here is what you can do for a simple repair and other things if you want to, you will need a new air filter,spark plug, oil, if you want to a new blade also ,sears has a mini tune up kit that you can buy. now for the carb, empty fuel tank, place mower on side to where carb is facing up place a rag under carb to catch excess fuel,remove the bowl nut and bowl careful of the gaskets,now spray carb cleaner in the small port holes in the carb steam in the middle of the carb until clean,now spray the bowl nut holes until clean there are three,after cleaning put bowl on the same way you removed it with dip towards front of float,put bowl nut in, now while you have mower on side drain the oil remove filler cap to drain,put pan under spout,mower holds 21 o/z of 30 wt oil,you can remove blade to get sharpened or put new one on,to remove blade put a pair of vice grips on the body where the blade can stop and not turn it is usually a 9/16 or 1/2 socket, put blade on add oil,add new and fresh gas,you should be good to go,hope this helps,what i am telling you here is what i would do if it was here in the shop,any comments welcome,thank you.
Posted on Feb 20, 2012
Doesn't act like it is getting gas. Cranks but wont start. Will start if I pour gas in carboretor but won't stay running. Changed gas filter and fuel pump.
Hi: I sounds like it is not getting gas, it probably need the carburetor cleaned out. but first make sure the gas is turned on, tighten the carb . I you have left it for a long time with out running the gas out it most likely needs the carb cleaned Good Luck I hope I was of some help
Dec 19, 2015 | John Deere EZtrak Z225 Zero-Turn Riding...
Why is fire shooting through exhaust when I'm trying to start
Too much fuel going into engine which is then not burnt. This is due to one of the following, injectors inncorectly set or faulty, carboretor incorrecetly set or that the engine manigment chip is faulty. Timing may also be out, but this is less likely idf engine runs reasonable well otherwise. Hope this helps
Sep 29, 2015 | 1999 GMC Envoy
How to remove the carburator on my 2001 v star 1100 classis?
Need to take off the fuel tank and after intake system from carboretors
Aug 31, 2014 | 2001 Yamaha V Star 1100 Classic
Troy bilt service manual
need to post you engine model number and type so you can get a match.there are many cabruraters some are for working some are for fun....
Aug 11, 2014 | Garden
How can i fix when the carboretor having a gasoline leak on the outlet?
sounds like the needle and seat are dirty or worn out causing the carburetor to over fill with gasoline.
take the caburetor apart, clean the jets and fuel needle, and put back together. if it still leaks then replace the needle and seat.
Jun 07, 2014 | 2007 Bajaj CT 100
My carboretor dosent geting oil
What is the make model and year of your motorcycles?
Oct 27, 2012 | Yamaha FZS 400 Fazer Motorcycles
My toyota corolla does not start normally unless i spray fuel inside the caburator please help to solve this problem.
is it a carboretor or is it fuel injection if a carboretor probably a sticking flote easy to do just remove it and clean if its fuel injection get the fuel pump checked or injectors
Sep 26, 2012 | 1990 Toyota Corolla
I have a 1999 kmx 125 and got it with no tubes on the nipples of the carboretor i have cut some to size but dont no which 1 goes were?
The smaller ones are vent tubes. It really doesn't matter how they are run - they all need to end up open with the ends under the bike.
There will be one single, larger hose connection on the carb for the fuel line from the tank. Other than that - all the rest are vent tubes.
Nov 12, 2009 | 2002 kawasaki KMX 125
My picture dose not work but my sound dose how do i fix this problem
go for the HORIZONTAL OUTPUT TRANS or THE VERTICAL IC , , check those 2 sections , good luck AJ
May 15, 2009 | Panasonic CT-32E13 32" TV
Carboretor
mcdevito75 here, Something wrong with--in the carb. Have it rebuilt or replaced. ----- Not unless the gas is leaking from outside the carb. in which case tighten the screws holding the 2 halves of the carb. together.
May 02, 2009 | 1981 Ford F 100
Garden Logo
69 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
