Question about Lexmark X4270 All-In-One InkJet Printer
Alignment problem error message. - Lexmark X4270 All-In-One InkJet Printer
  • Official Brand Answer
  • 3,344 Answers
It could be due to cartridges in the printer. Try the steps below to identify and fix the problem:
  1. Make sure the printer is on.
  2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
  3. Remove both cartridges from the carrier.
  4. Close the printer cover.
  5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
  8. Replace whichever cartridge is causing the error to appear with a new genuine Lexmark cartridge. Try to print a document again to verify that the problem is fixed.
If that doesn't help, try this approach:
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 4200 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Align to fix blurry edges. Your printer will then print a page that will help align the cartridges.
Posted on Feb 14, 2012
How to set print alignment in hp officejet K7100
During cartridge alignment, the error message 'Print cartridge alignment failed' displays on the printer control panel....
More Info visit this links...
Print cartridge alignment failed Error Message Displays on the All in...
Alignment Page Does Not Print
Thanks,
HP Printer Support
Jun 26, 2014 | HP Officejet Pro 8500 Wireless All-In-One...
Printer keeps giving alignment problem message
hello, remove cartridges, clean with something soft the wiring of both printer cartridge slot and cartridge itself, make sure you use alcohool, sanitary or even parfume wich dries fast and is not greasy, after that power up printer and check to see if everything is alright, if other error ocurs reply here.
hope that helped, best regards
Feb 28, 2014 | Lexmark International Lexmark 7300 Series
Align page not detected error on HP PSC 750 printer
Need to replace all print head with error or nozzles block
and try for alignment
once the page is printed it needs to be scanned to save alignment
if still get same message need to check for scanner functionality
Nov 08, 2009 | HP PSC 750 All-In-One InkJet Printer
Keep getting replace yellow ink cartridge error message
Where did you get the error message on printer or computer?
If you get the message on printer remove all cartridges and reinsert the cartridges and align the ink cartridges. If the alignment page prints successfully then the problem is resolved.
If you get the message on the computer disconnect the usb from computer. uninstall the software and reinstall the full feature software by selecting connect USB later.
May 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
Hp officejet 6110
If machine does not print the colors it cannot align. Try changing the color and try again
Apr 03, 2009 | HP OfficeJet 6110 All-In-One InkJet...
My HP Officejet 7410 All-in-One keeps giving me the error message - Scanner failure - Turn power off then on. Turning power off then on, even disconnecting power cord, repeatedly does not solve problem.
Our HP Officejet L7780 displays the "Align Printer" message and then does it automatically wasting several sheets of paper aligning, then the next time we print a page the same message comes back. Is there a way to turn off the "align Printer" message. It is printing ok otherwise.
Jul 31, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Error message Alignment
There is no doubt in my mind it Will be the cartridges you are using, alignment will continue to be requested if print out is missing bits do yourself a favour and use HP gen., not trying to plug HP just telling you the facts
Dec 06, 2007 | HP PSC 750 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
76 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
