Question about Tappan TGF657 Gas Kitchen Range
Tappan Range Model TGF657BFWS
On the digital panel, it show "F1". The panel buzzes, and holding down the cancel key doesn't clear the display. The top range lights with a match, and the oven won't light at all. What could be the problem and how to repair?
  • 1 more comment
  • Hugh LaGrange Aug 19, 2008
    i have the same problem (F1)
    Vance balwin electronics has the part# 318010300 for $128.75 plus shipping. (F1) electronic board failed( clock) they call it.
  • Anonymous Dec 07, 2008
    Tappan TGF657BFW F3 code oven. Range begins to beep when door is opened F3 code appears in addition oven does not hold temp but doesnt show accurate temp
    President:
  • 878 Answers
Delo, I am not finding that model number, what I have that is close is the model number tgf657bfw5, if this is your model number the F1 code is a bad electronic control, part number 318010300. If this is not your model number, just ignore this post...Catriver..post back
Posted on Aug 07, 2006
Error code f1 e3
Try this out,
FAULT ERROR: F1 E3NOTE:Make sure harness to P1 connector is correctly installed
per wiring diagram before performing the following steps:
STEP 1 Power off and wait 5 seconds.
STEP 2 Power on and wait 5 seconds.
STEP 3 Press the following keys:
CONVECTION - CONV. BROIL CLEAN BAKED GOODS 190 TIMER SET
NON-CONVECTION - CLEAN STOP TIME 0 OVEN LIGHT 1
STEP 4 Press START.
STEP 5 Make sure Timer ID is the same as the oven.
STEP 6 Press CANCEL to exit.
Nov 27, 2012 | Kitchen Ranges
I need Please a solution to F1 Error Code on GE/Kenmore electric ovens Model # 911.4658815 Thanks E-mail: elylimo@gmail.com I have the same model number. 9114658811 and plugged in the stove for the...
To my understanding error code F1 would indicate a faulty control board, possibly thermistor control. The only recourse is to have this replaced.
This of course would require a fair familiarity of electrical/electronic components/circuitry and safety procedures, use of a DVM and possibly a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 13, 2008 | Kenmore 46123 Stainless Steel Electric...
Our oven starts beeping and then displays a F 1 code and shuts down.
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
Aug 12, 2011 | Jenn-Air Ovens
My Tappan electric range oven wouldnt shut off tonight after baking dinner. Instead, it flashed ''F1'' in the digital screen, and would not allow cancel to work. What could be wrong? It is a Tappan Dual...
The EOC electronic oven control/clock has failed. This is easy to replace. Go to www.appliancehelponline.com and enter your model # for diagrams and illustrations. All parts come with installation instructions.
Apr 09, 2010 | Kitchen Ranges
I have a tappan range that keeps getting F1/F3 in on the display panel.
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
Mar 03, 2010 | Tappan TGF363 Gas Kitchen Range
Kenmore oven control beeps and shows F1
According to Kenmore's list of error codes, F1 means EOC (Electronic Oven Control) failure, and the solution is to replace the EOC. You might look into that. The part itself costs around $80, as far as I can see.
Aug 24, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Display shows error code "F1"
F1 Failed Thermistor Control Replace Electronic Range Control (ERC)
Good Luck and Please Rate Fixya!
Jan 06, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
F1 flashes on display, keeps beeping
If your range
has cancel try pressing that
Sep 07, 2008 | Tappan Kitchen Ranges
The oven door of our Tappan locked accidently.We tried to cancel but there were no results.
what do you mean locked accidently if if the door is locked and 3hrs is on the display hit start then cancel if the door showes locked and is not (you can still open the door)push in on the door switch by hand and push cancel let me know
Feb 13, 2008 | KitchenAid KESC307 Electric Kitchen Range
F1 and F2
Here are the codes for Tappan ranges:
TAPPAN
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor F4 Oven temperature sensor shorted Replace oven temperature sensor F5, 6, 7 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F8 Lock switches Check switches and replace if necessary
Nov 06, 2007 | Tappan TGF363 Gas Kitchen Range
Tappan TGF657 Gas Kitchen Range Logo
561 people viewed this question
Top Tappan Kitchen Ranges Experts
Paul Carew
Sal De
Archie Ferrarini
Archie Ferrarini
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
