Question about Philips 47PFL3603D LCD TV
My Phililips 42" tv has loud static sound when turned off
Occasionally when I turn off my 42" TV it will start to have a loud static sound coming from the TV that will not stop until I turn the Televison back on. I have had to leave the tv on for the last 5 days. Can you help, has anyone else heard of this problem?
  • sugar50nj
    sugar50nj Feb 10, 2012
    Im sorry, The problem is when I turn the tv off, the static sound begins and will not stop until I turn the tv back on, Model # is 42PL3704D/F7. The static is very loud and annoying,
  • 18 Answers
SOURCE: Philips 42PFP5332D 42 in random clicking problem
EVERY TIME I HAVE SEEN THIS PROBLEM IT HAS ALWAYS BEEN THE SMPS...SWITCHMODE POWER SUPPLY CIRCUIT BOARD...THATS WERE THE NOISE IS COMING FROM...RELAYS ON THAT BOARD ARE BEING ENERGIZED WHEN THEY ARE NOT SUPPOSED TO...THE UNIT SHOULD REMAIN IN STANDBY MODE UNTIL AN ON COMMAND IS RECEIVED VIA THE REMOTE CONTROL OR SET POWER ON BUTTON...TRY REPLACING THE SMPS..JOEACE
Posted on Jun 06, 2008
  • 5 Answers
SOURCE: 42PF9630A 42
ssb:pnx2015 stby &control
b4e
7j00-5\pnx2015
STBY CPU
1LA0\16MB
X840GA
Posted on Jun 18, 2008
  • 52 Answers
SOURCE: 42" Philips plasma screen goes black
you need to replace y-sustain board.
Posted on Jul 25, 2008
Roshan89
  • 271 Answers
SOURCE: Phillips 42 inch Plasma tv
there is internal failure inside..
Posted on Sep 16, 2008
toddthetvmd
  • 101 Answers
SOURCE: I have a 50" philips plasma , shuts off and blinks red light 2 and 7 times Y main board module problem?
It is your Y sus board. Most of the time one of the buffers goes bad and takes out the Y sus. If you do the repair.YOU NEED TO REPLACE BOTH BUFFER BOARDS also. If your buffers are bad,they will dammage your new board.If you have a multimeter you can check if the buffers are shorted.Check the upper buffer by placeing one lead to the first pin of the black connector and the other lead on the third pin.You should have 500 or more ohms resistance.If none,reverse the leads. If your reading is less than 200 ohms like about 70-120 ohms even reversing the test leads. Your board is bad. Testing the lover buffer is about the same,Just test the last pin,and the third to the last pin. same results apply. If you install your new Ysus with a buffer that is bad,it will short out the diode "D5018" on the Y sus.Near the upper black connector,or even short out the main IC.You can also have your board rebuilt, There is a company on Ebay. I have used them once. Worked great. And fast as hell..o delivery. Hope this helps.
Todd
Posted on Jul 05, 2010
I have a 42 inch Hitachi plasma tv that is making a very loud static noice coming from the internal speakers. It stays at a contstant very loud volume unless I completly mute the tv or turn the volum
Based on what you have tried if a buzz or loud static via the speakers you have something wrong in the audio output circuit of the set--problem here is that circuit may be part of the Main board that processes all signal---a look inside---following the speaker leads back would lead you to that board.
A simple thing to do to narrow it a little (you may have done this) is with sound all the way off put your ear to the internal speaker--hear anything at all like a deep hum?
Depending on age of set and cost of the board likely bad it may or may not be a do it yourself repair.
SD TECH
Apr 26, 2012 | Hitachi P42H401 42 in. Plasma HDTV
Samsung 60" DLP - 6
Hello.
It looks like you ignored lamp replacement in your TV. It have to be replaced every 2.5 years of average use. It's like oil change in a car. Regular scheduled service.
You can read info about lamp replacement in your TV owner's manual, buy lamp on-line and replace it by yourself to save some money.
Regards.
Russ.
Dec 01, 2010 | Televison & Video
Same problem
Do you have to turn the TV off and then on again to get the sound prob to go away? Our sound problem happens 10 to 15 x per day depending on how long the TV is on.
Jul 12, 2009 | Philips 47PFL7403D 47 in. LCD TV
Plasma tv makes loud static noise screen goes blank and shuts off
Take the back off and try to isolate where the sound is coming from.
Nov 24, 2017 | Philips 42PF7320A 42 in. Plasma HDTV
Tv picture and sound
Sometimes you just have to shoot the old girl.
Mar 13, 2009 | Televison & Video
Screaming static
Try turning off different lights near the room or in the room that it is in. Our tv does that if the overhead light in our bedroom is on, it's a room right next to our living room.
Jan 14, 2009 | Polaroid 4226TLMB 42 in. LCD TV
My toshibia model 27d46 tv will not turn on
Toshiba flat-screen digital SDTV, 27", won't turn on. Was difficult to turn on for awhile, but some channels had no sound, others that were in English usually, would suddenly turn into Spanish language. A loud static noise would occasionally come on, and then go. TV just won't even turn on now. Is there any possible repair that would be less expensive then replacing the set? I can't lift the set,as it is much too heavy. I'm a senior, and I'm strong, but not that strong.
Dec 13, 2008 | Toshiba 27D46 27" TV
Weird, annoying noise every so often
Is this happening on just on input?
If so... Check your connections. If you are using the component cables, make sure you haven't plugged the right audio into the red video input. it's a common mistake. I see it all the time.
If this is happening on all inputs, be sure the noise is coming from the speakers. Then replace the main board.
Nov 28, 2008 | Philips 42PFL7403D/27 42 in. LCD TV
Loud hum when attempting to turn on my RCA F27628 27"TV
could be that the main b+ filter Capacitor went bad and blew up. Also could have been the horizontal output transistor shorted and the flyback poped. In eather case it would be recommended that you take this set into a repair shop unless your familar with HV circuits in tv sets. Good Luck
Jun 10, 2006 | RCA F27628 27" TV
Philips 47PFL3603D LCD TV Logo
77 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
