Question about Brookstone Grill Alert Talking Remote Meat Thermometer
Unit beeps continuously
When we turned unit on to use it tonight, started to beep continuously and read 199 degrees despite the meat being raw. Replaced batteries and reset both pieces of the thermometer. Still reads 199 and beeps continuously
I had the very same problem and some web research suggested my unit was dead. However, I called Brookstone and they informed me that a faulty probe is typically the problem. I ordered a "Replacement Probe for Grill Alert (SKU# 558783)" which cost $15 (plus shipping and tax). This solved my problem, was well worth it as I like the Grill Alert, and I cooking turkey tomorrow!
Posted on Mar 30, 2012
  • johnvaustin
    johnvaustin Mar 30, 2012
When I plug it in the screen shows EEE, and beeps continually. It is around 65 degrees in the area. Nothing clears it or stops the beeping. It worked great yesterday.
The error code E:EE means the breadmaker thinks the temperature is too cool i.e below 59 degrees F or 15 degrees Celsius.
As you say the temperature is actually 65 degrees - then this means that the temperature sensor on the Bread maker has failed and will need to be replaced.
The EEE code and beeping will continue until the failed sensor is replaced and as this is a component failure it cannot be reset unfortunately.
Thanks for using FixYa.
Sep 11, 2011 | Regal Ware K6725 Kitchen Pro Bread Maker
Tip
Error Codes you need to know.
Standard Original IBM POST Error CodesCode Description
1 short beep System is OK 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Display adapter problem (EGA) 3 long beeps 3270 keyboard cardIBM POST Diagnostic Code DescriptionsCode Description 100 - 199 System Board 200 - 299 Memory 300 - 399 Keyboard 400 - 499 Monochrome Display 500 - 599 Colour/Graphics Display 600 - 699 Floppy-disk drive and/or Adapter 700 - 799 Math Coprocessor 900 - 999 Parallel Printer Port 1000 - 1099 Alternate Printer Adapter 1100 - 1299 Asynchronous Communication Device, Adapter, or Port 1300 - 1399 Game Port 1400 - 1499 Colour/Graphics Printer 1500 - 1599 Synchronous Communication Device, Adapter, or Port 1700 - 1799 Hard Drive and/or Adapter 1800 - 1899 Expansion Unit (XT) 2000 - 2199 Bisynchronous Communication Adapter 2400 - 2599 EGA system-board Video (MCA) 3000 - 3199 LAN Adapter 4800 - 4999 Internal Modem 7000 - 7099 Phoenix BIOS Chips 7300 - 7399 3.5" Disk Drive 8900 - 8999 MIDI Adapter 11200 - 11299 SCSI Adapter 21000 - 21099 SCSI Fixed Disk and Controller 21500 - 21599 SCSI CD-ROM System
on Mar 09, 2010 | Computers & Internet
I have a Frigidaire FMV156DBA built-in over-the-counter microwave that started behaving erratically tonight. The light started blinking on and off, accompanied by a repeated beeping. I unplugged the unit...
Yes have it serviced. Sounds like there is a loose/corroded connection inside and loose connections can cause fires. The intermittent/ramdom operation is indicative of this.
Apr 08, 2011 | Frigidaire Over-the-Range Microwave
I've misplaced the operating instructions for my williams sonoma remote meat thermometer. I can't get the probe unit/base to sync with the remote transmitter or to show a temp on the base unit and find a...
This is for a model ET-903WS: Turn the base unit on first. This is the unit with the larger display & buttons. Hold the power/mode button (upper left) down until you hear 3 beeps and the display lights up. Mine then displays "BEEF" and shows 160, with 3 blinking spaces. Next, plug the probe into the smaller remote unit. You should get 1 beep, the remote will display the temperature and the base will now display the same temp where the blinking spaces were. The first couple of times I tried, the base would not display. Unplug the probe, turn the base off holding down the same power/mode button and start over. I've had to do this as many as 4 times but it has worked perfectly while I wrote this!?! I really like this thermometer because I can put the meat on the grill go inside and have a drink while watching the game and then a friendly voice comes on when the internal temp is within 10 degrees of your target and says: Your food is almost done...your food is almost done." If you sleep through that, she comes back on at temp and says "Your food I'd done...your food is done". I take most meat off at the first warning and wrap it in foil. Watch the probe and it will continue to rise for about 20 mins. Enjoy.
Aug 08, 2010 | Microwave Ovens
Jenn-Air SCE 30600, oven error codes F1 and Probe
An F-1 error code on your model means the element was energized when it should not have been, A shorted interconnect harness or failed power relay board.
A probe indication could be a failed meat probe jack or bad harness in a unit that has one. In a unit without a meat probe, suspect a bad board.
Both conditions would warrant bringing in a tech.
Before you do, turn off the circuit breaker fot 3 miutes and turn it back on. This will reboot the boards. If problem persists, the call a service tech.
Nov 04, 2009 | Jenn-Air SCE30600 Slide-In Electric...
My Simple Start will not charge. I follow the directions and it just sits there and beeps. How do I fix this?
Here is what the B & D website says.
"If the unit starts to beep continuously, let it beep for about 1 minute, then turn the unit off and unplug the charger from the unit. Allow the unit to sit a full minute and then repeat the charging process.
If you still experience difficulties with the unit beeping after about ten attempts to charge, we recommend bringing the unit back to the retailer for an exchange, or taking the unit to the nearest factory-owned service center for assistance. "
It didn't work for me though.
Jul 09, 2009 | Black & Decker Simple Start Car to Car...
HOW TO WEIGH THINGS IN MICROWAVE
the microwave does not weigh things. you need to know the weight for things like auto defrost.
1 pound ground beef... enter auto defrost ..10
will read 1.0 ... 1 1/2 pounds... enter 15 ..reads 1.5.... 1/2 pound enter 5...reads 0.5 . unit beeps half way through heating program.. open door.. turn meat over close door. will continue to defrost
Jul 02, 2009 | Microwave Ovens
Charging Black and Decker Simple Start
First plug the charge adapter into an outlet, then plug into the unit. Push the power button to turn the unit on. Now, push the button for the light. The light should come on. At this point you hit the charge button and the green light should start blinking and there will no beeping. Then turn off the light. The green light should continue to blink and the unit will charge. This worked for me, hope it helps!
Jan 19, 2009 | Black & Decker Simple Start Car to Car...
Keeps beeping when recharging
It sounds like you need a new battery (this is what the beeping is) even though its only a year old the battery needs replaced!
Please rate my answer and help keep this site FREE!
Thank You!
Dec 28, 2008 | Black & Decker Simple Start Car to Car...
Brookstone Grill Alert Talking Remote Meat Thermometer Logo
975 people viewed this question
Top Brookstone Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Brookstone Grilling Expert? Answer questions, earn points and help others
