Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
Can a Kenmore model 116 3493590C be replaced by #116 53913300 Power Whisper belt
Trying to replace the power wand
reddevil6
  • 1673 Answers
SOURCE: kenmore whisper tome model # 116
If this uses a cogged belt, it should not fall off unless it is the wrong one. Give me the whole model #, then I can look and see what you have. The number of the power head is needed.
Posted on May 26, 2008
SOURCE: kenmore canister power-mate
I was able to get the whole thing reassembled.  If there is something specific that you are having trouble with let me know.  Everything snaps into its specific spot--it is just tricky to get it all lined up.
Posted on Sep 25, 2008
  • 2692 Answers
SOURCE: need to replace power cord
Here are the Sears links to purchase both the part and the manual.
http://www.searspartsdirect.com/partsdirect/searchByPartDescAction!searchByPartDescription.pd?brandId=0582&productCategoryId=0645000&modelNumber=11633922300&backToLink=Return+to+Sub+Components+list&partDescriptio
Posted on Dec 31, 2008
  • 231 Answers
SOURCE: I have a Kenmore canister vacuum cleaner. The
check the reset button or the wire that goes into the powermate sometimes it frays and breaks
Posted on Jan 04, 2010
VacuumRepair
  • 438 Answers
SOURCE: Need to replace belt in Kenmore Vacuum Power-mate nozzle
Here's what you'll need to replace a belt on a Kenmore canister vacuum:
- Phillips Head Screw Driver
- Flat Head Screw Driver
There are two different types of belts that are used on a Kenmore Canister. One of them is called a cogged belt, which has little teeth on the inside of the belt. The other is called a serpantine belt, which looks like a car belt, and has little grooves on the inside of the. You'll be able to tell which on yours takes after opening up the power nozzle.
This is the Cogged or Geared Belt with little teeth inside the belt:
Kenmore Canister Geared Belt for Canister Vacuums
This is the other Serpantine Belt that has little grooves on the inside of the belt:
Kenmore Canister Serpantine Belt for Canister Vacuums
Here's how you can replace the belt on your Kenmore Canister vacuum cleaner. First, before taking apart the power nozzle to change the belt, try pressing the overload protection system reset switch. This overload protection feature is designed to shut off the power nozzle if something gets stuck in the brushes, to prevent the belt from breaking. On most Kenmore models it's either a grey switch cover to the right of the neck for your power nozzle, or it could also be a little red colored pole. The reset switch will turn all power off to the power nozzle. If you turn on the vacuum, and try turning on the power nozzle and you hear absolutely no noise, then it's possible it may just need to be reset. It also could mean that your hose may have a short circuit in it (pretty common on Kenmore), and the hose is not getting power down to the power nozzle. If however you turn on the power nozzle, and you can hear the motor in the power nozzle come on when you switch it to carpets, then mostly likely your belt needs to be changed. On the model that I was fixing, the reset switch is a grey color, and I highlighted the reset switch in red:
So we'll just say for this repair that you are able to hear some noise come on in the power nozzle, but the brush is still not turning. This indicates a bad belt. Here's how you can fix it:
Step 1. If you're power nozzle is a square shaped nozzle like the nozzle that I took a picture of above, then you'll need to first remove the headlight cover before you can access the roller brush and belt. Simply squeeze both sides of the headlight housing, and while squeezing, lift upwards with your fingers exactly where my fingers are located in this picture:
Step 2. After the headlight cover has been removed, you'll see two screws underneath of the headlight cover, directly in front of the neck of the power nozzle. You'll need to remove both of these screws. I have circled these screws in red:
Step 3. After both of these screws have been removed, turn the power head upside down, so the roller brush is facing upwards. Look on the both the left and the right sides of the power nozzle. You should see writing that points to an area to put your flat head screw driver. You'll need to put the flat head screw driver down inside of the nozzle, and pry the top blue housing from the black bottom housing. Here's where the screw driver should go on the left side0723429.jpg:
Here's a picture of the screwdriver prying off the right side:
Step 4. Now turn the power nozzle back over on top, and remove the top housing of the nozzle. You may have to push the handle release pedal in order to take the top housing off.
Step 5. Once the top housing has been removed you should now either see a white semi-circle shaped housing over top of the brush, or your model may not have this part (some did and others didn't). If yours has a long white part over top of the power nozzle, look at the back corners of this white colored housing, and you'll see two clips, one on each side. You need to push these clips in, and pull backwards at the same time.
Step 6. Once this white colored housing has been removed, or if you model didn't have this housing, you'll now have full access to the roller brush and belt. You should instantly be able to see the belt if it's broken, as it won't be connected to the roller brush. Simply pull straight up on the roller brush to remove it from the vacuum cleaner:
Step 7. Wrap one end of the belt around the metal motor shaft in the back of the nozzle. Wrap the other end through the roller brush, and stretch the brush back into the housing where it belongs. Simply reassemble the parts, and test the vacuum to make sure the brush spins!
If you don't hear the power nozzle motor come on when you change the hose from Floors to Carpeting, this either means the reset switch needs to be pushed, or that you have a bad hose that needs to be replaced.
If you would like help on how to diagnosis the electric hose to see if it's bad, please just use the Clarification Request here on Fixya. If you have any other questions, please feel free to ask me, I'm always more then happy to answer follow up questions. If this repair was helpful to you, please be sure to rate it as helpful by clicking the thumbs up icons at the top of the repair.
Thank you very much,
Chris J.
GoVacuum
Posted on Apr 07, 2010
Belt not turning
Those have a tendency to short out in the wands. Use a test light or meter to find out where the power stops. Test lower wand first then upper then hose, then unit. Replacement wands are available, there's really no fixing them. I'll include a link to the wands I'm referring to.
Good Luck!
Lower (most common)
http://www.vacuummedic.com/product.php?id=452
Upper (very common)
http://www.vacuummedic.com/product.php?id=450
Feb 07, 2013 | Kenmore 25512/ 25513 Progressive Canister...
My power mate keeps losing power. As I am vacuuming, it surges off and on. The rest of the vacuum works perfectly fine. help!
Remove the wand from the telescoping pole, and look at the two holes in the wand where the electrical connection is made between the wand and the pole. You may see corrosion, which will cause the connection to be flaky and the power assist to surge on and off.
In any case, a good bet is that the wire harness in the wand needs replacing. It's about $15. (P/N KC37GBZTZV06) You'll have to take the wand apart - 3 screws and some judicious prying - to replace it.
Dec 28, 2010 | Kenmore 25614 / 25615 Progressive Bagged...
My Epic 6500 power head will not turn on. Had to push the reset many times the last time it ran, and now it will not turn on. Help!
Does the power nozzle motor come on? Is it just that the brush won't turn? If it's just the brush not rotating, the belt probably broke and needs replaced.
Is the brush clean? If not, clean all threads, etc. off.
Check all wire connections for breaks, cracks, and discoloration. Power nozzle to wand, wand to wand, wand to hose. If any of those are found, that part, and probably the one it connects to. will need replaced.
Ensure all connections are snug.
Internal wiring, including connections, could be bad. This would include wiring in the power nozzle, wands, hose, or canister.
Reset or hose switch could be bad. These would need replaced.
Power nozzle motor could be bad. Generally the belt will break before the motor burns out, but it's possible it's didn't.
For any internal repairs, including belt replacement, the entire vacuum should be taken to an authorized Aerus Electrolux dealer. The service technician can also troubleshoot and find the problem. This is generally done at no charge.
You've got a great machine, and with proper care and maintenance it should last for years to come.
Dec 22, 2010 | Electrolux Epic 6500 Vacuum
Brush not working??? Belt is fine.
Even though the brush is spinning, you probably need to replace the belt2_bing.gif because it is stretched. It is probably slipping on the beater bar...
Jim
Nov 27, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Kenmore Progressive Canister Vacuum -Model 116 22812200.
hello... you might want to try checking the elbow or neck of the power nozzle for blockage. Remove the wand from the head and look through it. Also look through the wands . If there is no blockage, maybe there is a problem with you nozzle. Reattach all the parts and turn on the machine, turn on the power nozzle. Can you hear the other motor start? If so, check to see if the belt is turning. If it is not, and you definitely hear the secondary motor, then you need a belt. If it doesn't make any sound then, with the machine still running, press the button on the upper part of the power nozzle, this should reset your motor. I hope these tips helped ya, let me know, by giving feedback when asked. thank you, Rene (The Vacuum Doctor)
Nov 10, 2009 | Kenmore Vacuums
Power head does not activate
have you pushed the rest switch on the top housing? It may be on the side?
Aug 28, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore vacum wand power cord
http://www.vacsew.com/vacuum-cleaners/kenmore-vacuum-parts.html/
Try here
Jul 16, 2008 | Vacuums
Kenmore whisper tome model # 116
May 23, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
210 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
