Question about Sharper Image Watches
The sharper image stainless steel case mens watch
Stainless steel case, china, global radio controlled, 5 atm
SOURCE: watch band repair
Cleaning yellow Nautica plastic or rubber wach bands
Posted on Oct 15, 2007
escapement
  • 2334 Answers
SOURCE: stainless steel band won't snap into my watch
Stainless steel bracelet ends (so called wings) must be curved flush to the watch case.
Another way is to use curved spring lugs (pins).
Posted on Dec 17, 2008
escapement
  • 2334 Answers
SOURCE: stainless steel band adjustment
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 19, 2009
escapement
  • 2334 Answers
SOURCE: Adjust watch band for Seiko 7T94 Stanless Steel Band
Job done!
Posted on Apr 04, 2009
  • 66 Answers
SOURCE: umm..mine is called.."FOSSIL 10 ATM" there's
10 ATM means that the watch is water resistant to 10 atmosphere's of pressure.
Long story short, yes you can swim with it. Yes, you can shower with it too.
Posted on Aug 02, 2010
I want a link for invicta pro diver model 0886
https://www.invictawatch.com/watches/detail/0886-invicta-pro-diver-men-488mm-stainless-steel-stainless-steel-silver-dial-pc32a-quartz
Nov 11, 2016 | Invicta Watches
Seiko5 watch service centre in abu dhabi
Take it to a local jewelry shop and have them either fix or send it in for repairs
Aug 10, 2016 | Seiko Wrist 5 SNK665K1 Automatic...
Where do I get the screws for a Stuhrling 142A2.PK2 Mens Pocket Watch?
Try a watch repair shop or contact Stuhrling Original, LLC at 449 20th Street, Brooklyn, NY 11215, (718) 840-5760.
Jun 05, 2014 | Stuhrling 142A2.PK2 Mens Pocket Watch...
Swiss Legend Chronograph Stainless Steel Case- how to change the battery
Take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving in doing it yours
Feb 24, 2010 | Swiss Legend Chronograph Stainless Steel...
Oakley crush 2.0 watch with broken rubber strap. Where do you get replacement part?
Did u manage to het one ? Because i have THE Same problem. Oakley cant help me
Jul 15, 2009 | Oakley Crush 2.0 Stainless Steel Case with...
Stainless steel band won't snap into my watch
Dec 12, 2008 | Philip Stein Teslar Large Gunmetal Watch
Watches Logo
66 people viewed this question
Top Sharper Image Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Sharper Image Watch Expert? Answer questions, earn points and help others
