Question about HP Pavilion dv7-1130us laptop
Laptop shuts off when unplugged - HP Pavilion dv7-1130us laptop
  • mthmmeier
    mthmmeier Feb 10, 2012
    When I unplug my laptop(hp pavilion dv7) it shuts off and will not turn back on until i plug it back in. I just bought a brand new battery. I have read about doing to display settings and changing something there, but i dont find the options to follow that. HELP please?
    Master:
  • 388 Answers
Its one of three thing charger battery or d/c jack (the bit you plug the charger into on the laptop) which needs replacing cheapest option try another charger they have a pin in the end of the charger witch connects to the DC adapter after time this pin can be moved if the two do not connect the laptop will not recognise the charger as genuine and will refuse to charge the battery
Posted on Feb 11, 2012
Does my computer operate on batteries ?
If you're referring to a laptop, it should have a battery. If it shuts down when you unplug the power cord, the battery may be bad, not making good electrical contact or missing. There is usually an icon at the bottom of your screen that indicates if the battery is charging or being depleted.
If you're referring to a desktop - no battery.
Feb 25, 2015 | Computers & Internet
Gateway laptop shuts down instantly when unplugged but fully charged.
I have come across connection issues on the battery terminals. Make sure the brass contacts are not tarnished or bent. Have you tried another battery?
Feb 19, 2014 | Gateway Ne56r31u Intel Celeron B830 X2...
Compac pasario c500 on/off light just blinks when I power on computer screen stays blank?
Shut down, unplug, remove battery, plug in, reboot. If it reboots, open Control Panel, Power Options, Advanced power settings, Change Sleep and Hibernate to Never. Adjust the settings to your preference. Set the Screen Saver time. When your laptop is not in use shut it down and unplug, this will prolong life and a reboot everyday will reset your laptop.
Jan 17, 2013 | Computers & Internet
Dv9740 hp laptoop does not shut down or sleep
Open power settings adjust. OR shut down at the start up menu. You can always push the on/off button. When not it use shut your computer down, unplug.
Dec 15, 2012 | HP Pavilion DV9740US Laptop
Dell Inspiron 6000 powers up, caps lock flashes 9 times, then laptop shut down. Why???
Unplug power cord from laptop, remove battery from laptop. Open memory access panel on the bottom of the laptop. Remove memory module(s) (SO-DIMM). Plug power cord back into laptop. Turn laptop on (with the memory removed), the caps lock and scroll lock LEDs light, then the laptop shuts itself off. Unplug power cord from the laptop. Reinstall the memory modules. Make sure they are seated correctly. Put the battery back in, plug the laptop back in, and power on. Laptop should power on and boot up properly.
May need to hold the power button down to get it to power on properly.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Dec 03, 2011 | Dell Inspiron 6000 Notebook
When l unplug ac adapter the tablet shuts down
Make sure that the battery on your laptop is properly seated. If it is then the laptop battery may not be able to hold a charge anymore. So when the power is disconnected the computer shuts down.
Aug 06, 2011 | Sylvania Computers & Internet
The computer does not start up. It lights up the power indicator and after a couple of minutes it went off. Sometime the number indicator keeps beeping and it remains until I shut the computer off. For...
Try unplugging the laptop. Then once you've unplugged the laptop remove the battery. With the laptop unplugged and battery removed, hold the power button for 10 seconds. Replace the battery and the power cord and see if the computer boots.
Mar 16, 2011 | Dell Vostro 1320 Notebook
Compaq Presario CQ40 - always shut down by itself. Want to know what is the problem.
I have same problem as yours. . My laptop shuts down by iteself. . My Battery isn't working too. . It is fully charged but when i unplug the adapter, it will shut down. . Badly need help. .
Aug 28, 2010 | Compaq Presario Notebook
I have an Aspire 7736Z-4809 and it seems that the battery isn't working. If I unplug the power strip the computer shuts off. Is this the battery or the settings or the plug? Any thoughts?
Unplug the laptop then remove the battery. Reseat the battery, plug the laptop back in. Then restart your laptop. Give it 5-10min to allow for a small charge and then remove your charger again. If the laptop shuts off immediately it is quite likely that your battery has failed. This is quite common for batteries. If you're under warranty please contact the manufacturer. Else you will likely find a cheaper battery solution on ebay. -Ravi Shanghavi
Aug 19, 2010 | Acer Aspire 5335-2257 Notebook
UNPLUGGING COMPUTER
I WOULD'NT RECOMEND DOING THIS EVERY TIME YOU COULD LOOSE SOME FILES OVER TIME
Mar 09, 2009 | HP Pavilion dv9000z Notebook
HP Pavilion dv7-1130us laptop Logo
73 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
