Question about Husqvarna 350 18 Inch Gas Chainsaw 52CC Fully Assembled Brand New 18"
I got a Jonsered 2540 Turbo saw, who just starts, go for a couple of seconds,spmetimes minutes, and then die. When died, good spark, checked carb, cleaned,etc. saw is flooded. has to wait approx, 1
Starts, then sputter and stop. Floods when trying to start afterwards. Good spark.
  • 36 Answers
SOURCE: 345 husqvarna chain saw will not run
If it idles it is not flooding out as it it most vulnerable to flooding at idle if the stalling is happening as you try to throttle it up it is likely starved for fuel. Start by changing the in tank fuel filter, and the spark plug. good chance that will solve your problem. If it does not Turn the high idle screw out in 1/8 turn increments try running the saw after each adjustment. Keep track of the amount that you turn the screw. you might have to put it back to its original position. Some times adjustment screws will vi berate out of adjustment and other times crud will cause fuel restriction opening the screw allows for a larger port for any restrictions to pass through. After you use the saw for a short time turn screw back in if it starts to stall at idle or you notice increased smoke.
Posted on Jan 06, 2009
SOURCE: spear and jackson chainsaw. runs
OK - let's work through this. If you need choke all the time then the mixture is too weak when the choke is off. Putting the choke on literally chokes off the air supply to the engine by lowering a small shutter across the entrance to the carburettor. That means either there is too much air getting to the engine (don't see how!!) or too little fuel. So, how do we get too little fuel? You could check for this as follows;
- before we do anything tricky let's check the obvious things - is there a fresh fuel mix in the tank? Petrol does go off, especially if there is 2 -stroke oil added to it. If it's over a month old from the pump mix up a fresh batch. Is the idle speed set too low so the engine stalls when the choke is knocked off? You can see this screw to one side of the carburettor (you need to remove the top lid in front of the handle on the chain saw, and then remove the air filter to see it). Turn the screw half a turn clockwise to speed the engine up. Be warned - if the engine starts it will run faster than normal and that means the chain may start to spin around. Also - check that the chain brake is off (i.e. the safety lever is pulled backwards, and that the chain is free to move BEFORE you attempt to start)
- is the fuel filter blocked? To get to this, make a wire hook (e.g. thick fuse wire) and gently hook out the fuel filter that's sitting at the bottom of the fuel tank, and take a look at it (be gentle - you can damage the gauze if you are clumsy). Does the gauze look clear? I.e. if you dip it into petrol it will freely run into the filter and of course drain out when you lift it? If not, replace it.
- next stop - are the jets in the carburettor set right? I don't have a service manual for this (and I know the manual says unhelpfully "return for service") but basically you will have seen two holes on the side of the chain saw (below the handle) two small 0.8cm holes; one marked 'L' (for low speed) and the other 'H' (for high). Put a fine flat screwdriver down the L hole and feel for the slot of the low speed jet. Once engaged turn it out half a turn and this will enrich the mixture - if this seems to help and you can start the engine then adjust the L jet in or out until the engine is idling comfortably. If it idles too quickly then you can also turn down the idle screw (see previous paragraph).
- no luck still? Well, it could be fuel pump or a blocked jet in the carburettor but this really is a 'return to the service centre' task!
Posted on Jan 12, 2009
steve_lima
  • 181 Answers
SOURCE: Husqvarna chain saw starts and runs for 20 minutes then stops.
two things could be happening.......first is vapor lock......make sure you breather tube is clear and working........next is ....it could have a bad ignition coil on it.....after the coil gets hot the spark can become irratic or just not work any more.....
Posted on Feb 23, 2009
dontbother10
  • 2220 Answers
SOURCE: 353 husqvarna chainsaw, floods during start process
Husqvarna says the initial carburetor needle valve settings are from lightly seated 1 turn CCW for both H & L.
Your Operator's Manual can be downloaded here:
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2004/HOUS2004_1140204-95.pdf
Once flooded Huskys are very hard to start. This works well on my 359.
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close - sets fast idle) pull starter and listen for an attempt to start. once heard (usually two pulls)
  4. Set compression release – optional step even if saw is equipped with a compression release
  5. Push (open) choke pull starter until it starts. (usually the next pull)
Warm:
  3. Pull (close - sets fast idle) choke, - Don’t pull with choke closed.
  4. Push (open - fast idle maintained) choke, pull starter until it starts. (usually first pull)
Hope this helps
Lou
Posted on Oct 03, 2009
rwvanlue
  • 486 Answers
SOURCE: Flooding walbro carb from blower.
The problem centers around the carburetor. The question lies in the condition and operation of the carb initially.
It appears you may need to double check your assembly of diaphragms and gaskets. check for loose welch plugs, adjustment needles in the wrong holes, inlet needle set too high.
*note: metering side diaphragm goes on top of the gasket, fuel pump diahragm has the gasket on top of it.
Posted on Nov 11, 2009
After starting and letting it idle for 30 seconds I start to cut but it starts to die when I give it gas it goes for a while then dies
What I do with my stihl saws is after starting I let it warm up for a few seconds and then run it at full throttle for about thirty seconds. If your saw does not want to keep running I would check to make sure air filter is clean. Next you can adjust carb.setting for idle and hi speed,check your manual for instructions. Also I would remove and clean spark plug,check gap and reset or replace as needed. Make sure your gas oil mix is proper and gas has not been setting for a long time,no more than a couple of months without some type of fuel stabilizer. I use either STA-BIL or sea foam at a rate of 2 to4 ounces per gallon of gas. About the only other thing I might suggest is to check the feul filter. They usually are located on fuel pick up line inside gas tank and can be a pain to get to. Good luck and I hope this helps Thanks
Nov 10, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
13 hp honda pressure washer 3000 psi 4gal/min Hard to start and dies out after 20 seconds after the engine gets hot and running after multiple starts the engine will stay running but then dies every 30...
There are a couple of things that can cause this problem. The first thing to check is if you are loosing spark. Dying after it gets hot sounds like to stater is failing in the engine. If you loose spark this is more than likely the issue. If you are not loosing spark you need to check the fuel system. Dying after 20 seconds it could also be a plugged main jet in the carb. Another common issue on Honda engines is a faulty vent on the gas caps for engines sold from around 2008 - late 2010. If your gas cap is only about 3/8" thick this is very likely to be your issue. Try running the engine without the gas cap on to see if it still dies. If not that is your problem.
Sincerely,
Aron Kerr
Landa Northwest
800.247.8103
503.255.6508
www.landanw.com
Nov 03, 2010 | Honda Landa PG 3500 PSI Pressure Washer
I have a husqvarna 55 chainsaw was running fine I was cutting a log then the saw just died checked and cleaned magneto. Now I get the saw to start and run but only for a few seconds then it dies.
it sounds like a small piece of dirt is in the main jet of the carb assuming you have good spark. you may need to remove the carb and clean it. if it has a float then the needle may be sticking especially if it had older gas in it over the winter as it gets thick and plugs up the fuel passages. good luck.
May 17, 2010 | Garden
Starts but dies after several seconds
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 21, 2009 | Homelite Garden
Will start then die
You didn't provide a lot of details, but I'll give you my two cents. If it's starting easily with just a few pulls and then dying after a few seconds, it's likely a fuel delivery problem. Check the carb to make sure it's getting a full flow of fuel. If it has an adjustable high speed needle, back it out a bit to see if that helps.
If it's running until it gets warmed, be thinking ignition problem OR perhaps a valve problem. Make sure the gas tank cap is the vented type. Make sure the engine fins are clear of debris and mud daubers nests. If someone stuck a cap from a milk jug on the fuel tank, the engine will run for a few minutes until a vacuum is formed in the tank.
If you're having trouble starting the engine, you should be checking spark (strong white spark), checking compression (50 lbs and higher) and fuel delivery through the carb. I usually pull off the carb bowl, if the carb has one, and check to see if there is any dirt in the bowl. If there is, you'll need a carb kit and a fuel filter should be installed between the tank and carb. Hope this helps.
Jun 06, 2009 | Garden
Mower will not start
you could have water in gas,look in the gas tank for any bubbles floating on bottom of tank this is water empty gas from tank and remove carburetor bowl too remove water from it .
May 13, 2009 | Garden
Husky 455 dies out at full throttle or under load
Your carb may be the issue but your ignition coil could be the culprit. Once they start going bad, they can act up intermittently or give various symptoms from day to day. The fact that your saw dies at full load or under load, probably means that when your saw gets hot or requires more spark, your coil is not able to provide it. Your carb is easy enough to clean out, you can take it all apart and clean all screens, etc....
I just replaced my coil due to the exact same symptoms and now my saw runs great. $60 off ebay and you can put it on in 15 minutes yourself. Check your carb first though
Apr 13, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 350 18 Inch Gas Chainsaw 52CC Fully Assembled Brand New 18" Logo
278 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
