Question about Dryers
Can i use my stanley fionn stove without the top baffle
2 Suggested Answers
  • 491 Answers
SOURCE: I need some replacement parts for my
LOOK AROUND THE STOVE FOR A BRACKET WITH THE MANUFACTUOR DETAILS AND CONTACT THEM FOR INFORMATION ON PART OR GO TO A SRAP YARD AND YOU MIGHT GET LUCKY .
Posted on Nov 29, 2009
How to replace baffle inside tumbler
some baffles have a screw at the far end inside the drum. remove screw and push baffle to remove. If you dont have that type of baffle then you would have to open the top cover and tilt back. You will be able to see the screws that hold the baffles. some tops have screws in the back to remove top. Some have clips in the front that would need to be push in with a small spatula. Good luck. I dont know if your able to post pictures with your question, it would really help.
Nov 18, 2015 | Bosch Dryers
Napoleon NZ26 woodburning fireplace smoking back.
Get someone to come and do this correctly. You have a possible carbon monoxide poisoning hazard!!
Nov 18, 2013 | Napoleon 36" Zero Clearance Top/Rear Vent...
Maytag neptune dryer one of the dividers the screws came loose how can I fix this without calling for service
You are probably referring to the drum baffles. The baffles securing screws can be retightened by raising the top which requires the removal of the front panel. Click on the link below for the detailed steps.
Retightening the Baffle Screws on Maytag Neptune Dryers
Jan 24, 2011 | Dryers
I have a Stanley 4.0 peak HP wet/dry vacuum without any instructions. How do I empty it when it is full?
Usually with this type of vacuum the the top motor part unclips then tip the base unit over into an outside drain.
Jan 02, 2011 | Stanley SL18128P Wearable WetDry Vacuum
We do not seem to be getting as much heat from the stove this year as last year. The stove makes a loud clanking sound when it heats up and cools down. It is a regency wood stove Model R3/R9/RA3. There...
That stove has a metal baffle on top of an air tube that can warp with age. It might be changing shape as it heats up and making your sound. If this is the case it can block the path for the stove pipe and cause performance issues. The baffle plate and insulating blanket on top can be easily replaced.
Dec 07, 2010 | Stoves Heating & Cooling
Changing stove from gas to lp do we need to open top of stove to do this?
Only if it is an open burner stove. Sealed burner stoves are converted without removing the top. Which do you have? Your owner's manual shows how to convert it. If you're missing the manual, tell us your stove make & exact model # and we'll see if it's available online to download. Douglas
Sep 12, 2010 | Ovens
I need some replacement parts for my Waterford-Stanley Trinity wood stove. The Left and right top baffles. Do you know where I can buy them.
Nov 29, 2009 | Ovens
Baffle is loose on drum. How do we get access to fix the baffle
The screws that hold the drum baffles in place are located along the outside of the drum. Usually, you need to lift the dryer top in order to access them, and they can be tightened without removing any components. However, all dryers are not contructed the same and access to the drum can vary. If you would please post a brand name and model number it would help in being able to determine exactly how your dryer is configured.
Aug 31, 2009 | Dryers
Baffles are loose on my dyer maytag neptune mde5500
Hi Nick, welcome to FixYa!
1. Open the door and remove the two screws that secure each of the door hinges to the dryer frame. With the door open so you can take a hold of it, simply pull the whole door out of the notches that the hinges fit into.
Next, remove the two screws on the opposite side of the frame where the door closes to. (along with the two white plastic trim pieces the screws go thru) Once the door is off and the screws are out, pull the entire front panel forward and then it will lift off the tabs at the bottom and you can set it aside.
next, look up near the top of the cabinet, on each side, for the metal hooks that secure the top to the cabinet. Remove the screw (5/16" nut driver) that secures each hook to the cabinet. Take the hook off, repeat for the other side.
Now you can lift up the top of the machine, and rotate the drum so that the loose baffle is at the top so you can work on the baffle easily. Rotate the drum to the next baffle, etc.
I hope you find this answer helpful.
Dec 28, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
46 people viewed this question
Top Dryers Experts
