Question about Refrigerators
Ge trash compactor gcg1500
When I pull up on the foot pedal to initiate the compacting cycle, it doesn't work - it makes a electric noise but nothing happens
SOURCE: GE Profile trash compactor is stuck
This has happened a couple times to me and the fix is fairly simple. The problem is the trash ram is pushing down on the edge of the metal of the trash compartment because the door is partially open. The solution is to back-up the ram the the door will close.
To back-up the ram, you will need to pull the compactor out from under your cabinets and unplug it. Turn the compactor on it's side to expose the bottom. There is a plate on the bottom that covers the motor gears. Remove the plate and turn the large gear counter-clockwise to back-up the ram screws (at least this is how it works on my model works). The gears are a little greasy so you may need to add some after messing with the gears.
Good luck.
Posted on Dec 25, 2008
SOURCE: g.e. profile compactor gcg1540f0ss
the nut on the ram drive fell off for me and the chain fell off and then broke the grear drive. At 72$ each for the two ruined gears I don't know if I should try to repair it or get a new one.
ERRR
Posted on Apr 24, 2008
MNfisherman
  • 11896 Answers
SOURCE: our 1 1/2 year old trash compactor will not operate
You may have to get a voltmeter or multi-tester and test voltage from power supply. Check to see if fuse is good. Check wires to pedal and lastly, use capacitor tester and test all capacitors to see if there is a faulty one.
Posted on Aug 25, 2009
SOURCE: Trash Compactor Model GCG1500LOBB. the foot
I also found that after 2 years my GE Profile Trash Compactor (purchased in June '07), the pedal was hanging down on the left side. I searched the internet and called GE to no avail.
After a few attempts, I finally solved the problem by removing the screw on the left side and adding a metal "L" bracket, with the bottom of the L flush against the back of the front panel. That way, when you depress the pedal, the screw can't pop out of the metal it's attached to.
Dannys00
Posted on Dec 25, 2009
  • 1751 Answers
SOURCE: I have a KitchenAid Trash Compactor Model
Hi
you better replace the unit
is not relibly try fixxing it
Posted on Nov 26, 2010
Ge compactor stops after just starting
the running cycle for this type of trash compactor is a max of about 30secs. The fuller the bag is the shorter the cycle. However, if this is not how yours is running try checking to see if there is any trash stuck between the ram and the basket. Or make sure that the foot peddle is still staying in the "up" position.
Feb 27, 2012 | GE Stainless Steel Built In Trash...
I have a GE trash compactor I have to hold up the foot pedal for it to work. When I let it go the compactor stops. thank you
There is a spring that holds up the pedal. It is broken or has come apart. By the pedal in the up position it is a safety switch allowing the compactor to run. You may have to repair this or simply put a small block under the pedal of the unit to run.
I hope my suggestions helps and all the luck to you.
burdfrenzy
http://stores.ebay.com/Pittsburgh-Joes-Pants-Nat
Dec 23, 2010 | GE Profile GCG1580LSS 15" Built-In Trash...
Dannys00
Dec 21, 2009 | GE Profile GCG1580LSS 15" Built-In Trash...
Our compactor does not work. It makes a humming noise but will not function.
motor jamed . try removing basket . ( pull out and lift up ) ck for plastic of other things in or around drive and rollers .both sides and in back .. ****
Dec 07, 2009 | GE Profile GCG1580LSS 15" Built-In Trash...
Our 1 1/2 year old trash compactor will not operate
Aug 25, 2009 | General Electric Profile JGP945 30 in. Gas...
Door hard to open
The tracks that the door are on have to be cleaned and lubricated with WD40 or equivalent. This should solve your problem. Hope this helps
Nov 09, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
Good luck.
Oct 21, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
Sure is... The motor drives a ram up and down to compact your trash... Like most drive systems.. it needs to find a refrence position near the top of the stroke.. that position is normally sensed by a switch.. so it is possible your motor is bad or.. it is also possible your top sense switch is bad too.. For $400.. the GE tech should come out and stomp on your trash until it is compressed.... In either case.. if you are handy.. you may be able to open the compactor up ( with power unplugged) and check the position of the ram.. if it is near the top.. you may be ableto reposition it down a little then try cycling it.. It may buzz if the motor is bad ( windings shot) or it may work OK.. if it does and the problem comes back after you cycle it.. there is a good chance the top sense switch is bad or the windings in th emotor bad too.. Hope that helps...
Aug 16, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
Refrigerators Logo
61 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
