Question about Plumbing
Danze model 063-3059-4 - Plumbing
I have a danze model 063-3026-2. I can't find a cartridge to reference this model number. Does anyone know which cartridge I would need?
YOUR NUMBER...
Is NOT looking to resonate IN MY CYBERSPACE... Sorry.
try faucets direct (below)... Call direct
Danze Model 063 3026 2
THEY can be reached at (800) 864-2555
Call center hours are:
Monday through Friday:
5:00 am to 7:00 pm PST
eFAUCETS gave EVERYTHING (sad tactic)
https://www.efaucets.com/search/go#w=danze%20model%20063-3026-2
Carnac the Magnificent
Apr 10, 2017 | Danze Plumbing
How do i remove handle from danze kitchen faucet?
Google Danze kitchen faucet diagrams and it shows the intricate parts of different faucets
May 03, 2014 | Danze Plumbing
Install danze kitchen faucet
Did u check there web site most have instruction manual if I could see it I could tell you more
Apr 18, 2014 | Danze Plumbing
Danze aurora toilet installl instructions
Can a Danze Dual flush ( Model:Aurora) cistern be used on an American Standard Chleo toilet bowl. Will it clear the solid waste effectively?
Jan 11, 2012 | Danze Home
Need an instruction sheet for cartridge replacement for Danze Sheridan tub and shower faucet
This link will get you to the Danze illustrated parts list for the Sheridan single control tub and shower valve.
http://www.danze.com/products/pdfs/D510055_ip.pdf
Aug 08, 2010 | Danze Sheridan Tub & Shower Faucet
Bought a home, main kitchen faucet is a Danze NSF
I'm not familiar with a NSF 61/9, but I've used several other models. I believe these are all ceramic disc valve. They almost never wear out. If you remove the handle and the trim cap or bonnet, there should be a nut or adjusting ring you can tighten. Don't over do it. The handle give you quite a bit more leverage than the small tap when it is removed. Here is Danze web site and you can look up your exact model number and see a exploded parts list: www.danze.com
Jul 12, 2010 | Danze Plumbing
There's no set screw or plate covering the set screw. Not sure if handle just snaps on or what Danze Parma faucet
You didn't indicate exatcly what model. Check this link, and follow the install instructions. It tells you how to secure each type (3 different methods) One is a screw in the side with a cover over the screw.
http://www.danze.com/tech_specs.asp?show=D500058BN then click on install notes
Jul 04, 2010 | Danze & Single Handle Tub And Shower...
Looking for parts breakdown picture for DANZE NSF 61 Kitchen Faucet Any Links?
NSF 61(-9) is a standard rather than the model number (it's often very difficult to identify the model number. If you are able to find the model number, the link attached has all the technical specs for Danze products (even discontinued ones). http://www.danze.com/tech_specs.asp
Otherwise, I suggest browsing their faucet section until you find yours.
Good luck.
Sep 13, 2009 | Plumbing
Water leaking from tap when turned off
In order to remove the Danze handle from this particular model grasp the handle of the valve and then the body of the valve and turn the body counter clockwise in order to remove.
Hope this helps.
If you don't have a supply house near you that carries parts for the Danze products you can go to danze.com and order them there.
sanray
Jan 02, 2009 | Danze D500058BNT Parma Shower Trim Kit w/...
Plumbing Logo
204 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
