Question about GE (JASHO96273)
Networking 1 by 1 illustation on how to creep a Network cable. Standard and Cross cable thanks
  • sanyaoludayo Oct 24, 2008
    I Appreciate your support on this on this problem,
    this solution help me out on crimping networking cable
    Thank you,
    Fixya.com
    Regards
    Master:
  • 363 Answers
Hello, everyone, have you ever played a game called RuneScape? I heard this game is very popular before, and now there are still many players, and recently I found a website may be able to help you, to share with you www.rsgoldfast.com
Posted on Jan 18, 2017
  • GE Master
  • 2,460 Answers
Against my better judgement, because crimping doesn't work half the time, here's the color code.
A 4-pair Cat-5e or 6 cable has BLUE, ORANGE, GREEN, and BROWN pairs. The ones with the most white are called Tip. In a 568B wiring scheme, they go 54361278.
or, like this
1 2 3 4 5 6 7 8
wo ow wg bw wb gw wbr brw
Data is actually carried on pins 1 2 3 and 6.
If you wire the other end of the cable the same way as above, it's called a straight through cable.
If you reverse the orange and green pairs, it's a crossover cable. This is also the pattern for 568A
1 2 3 4 5 6 7 8
wg gw wo bw wb ow wbr brw
Getting the wires to untwist and behave is half the fun, that's why we use special plugs when we absolutely have to crimp. Otherwise, we use a jack and patch cord.
Carl
Posted on Oct 24, 2008
Can i connect a netgear JFS524 directly to acable modem
Yes for sure you can do that.As the connector is RJ45.The only think is that for Thomson you need a cross-wired cable to connect to the netgear JFS524. If netgear do have Uplink port then you can use normal or straight through cable.For more infor Cross-wired cable are use to connect between network devices.
Feb 25, 2015 | NetGear ProSafe JFS524 24Port Ethernet...
I have two des-1005d network switches. i want to communicate betwwen them with a cat5e cable. the cable is made as cross through and distance is about 70 meters. with one switch pc is connected and at...
Max distance for Cat5e cable is about 100M, but that is the best case scenario, essentially a straight line, down a building. If you have any kind of interference, like flourescent lighting, high voltage lines running parallel to the ethernet cable, the distance will be much less than 100M. Although it looks like you have 60 feet to spare, anything interfering with the cables will cut the signal down. Try to move the switches closer together, make the cable from pc to switch longer and ADSL modem to switch longer and cable between switches shorter. Use a known good straight through ethernet cable, as modern switches don't require crossover cables.
From Wikipedia: http://en.wikipedia.org/wiki/Category_5e#Maximum_cable_segment_length
According to the ANSI/TIA/EIA standard for category 5e cable, (TIA/EIA 568-5-A[5]) the maximum length for a cable segment is 100 meters (328 feet). If longer runs are required, the use of active hardware such as a repeater, or a switch, is necessary.[6] [7] This 100 meter limit is all inclusive. According to some authors,[who?] the practical limit for permanently installed cable is about 90 meters, leaving 5 meters at each end for the patch cables that connect the end equipment to the wall panel.
Hope this helps.
Sep 27, 2010 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
Connect an raymarine E120 Display to the RNS software in a PC
Try a cross over network cable from the PC to the E-Series. Raymarine Made each one of their cables as a straight cable so you would need to buy the cross over coupler or network switch box to use it with another unit. It's nothing different from normal networking with the exception that they have removed wires 4,5,7 & 8 from the cable and it's a straight. Give that a try.
Mar 21, 2010 | Raymarine E120 Multifunction GPS Receiver
Networking 2 computers
Yes you can make a simple Network between 2 PCs ....but ....you need what is called a "crossover ethernet cable" or "xover". A standard RJ45 ethernet cable WILL NOT work.
You also need to make sure both Pcs are in the same Workgroup and have unique computer names.... as is standard in Networking.
Dec 31, 2008 | HP Pavillion ZV6000 Notebook
Help in connecting two computer together for multy gaming
If you are using a network cable to connect two computers without a hub, then the cable has to be a CROSS OVER cable. You can't use a standard network cable.
If you connect more then two computers to make a network of computers then you must use a hub and standard network cables.
Jul 27, 2008 | Computers & Internet
Connecting campus wide networking to hub
Check the following:
Hardware First: Is Vista confirming LAN connection onn that PC, or is it showing disconnected cable?
Is the connection properties showing at least 100Mbps?
Are the RJ45 terminals okay?
Is the driver for the network card recognized by Vista and loaded?
If that is fine, then check the following in the network properties:
1. The IP address you are using
2. The gateway address: it must be the same as the gateway address in the other PCs accessing internet. Run and check
3. The Subnet mask. Use 255.255.255.0
4. HAve you Setup the Nework using the Setup Wizard, including Access INTERNET THROUGH A HUB THROUGH ANOTHER COMPUTER ON MY NETWORK?
Check those things and let us know. Ask for help from your network administrator about correct IP addresses on that LAN
Feb 26, 2008 | Compex MicroHub TP1008C Networking Hub
Networking
This site will give you directions on how to make a CAT5 cable. http://www.computerhope.com/issues/ch000639.htm
Sep 17, 2007 | Computers & Internet
NIC blinks on then off for longer run lines
Please check the RJ45 plugs. the wiring should be as follows: RG45 connector side#1 legs 1236 goes to RG45 connector side#2 legs 1236 see the colors of the wires they should be equal
Aug 23, 2007 | NetGear JFS516 Networking Switch
3com officeConnect with 16 connectors
check cable connection make sure it is all straight cable not cross cable, the switch could incounter traffic.
Mar 26, 2007 | 3Com OfficeConnect (3C1670500A)...
GE (JASHO96273) Logo
164 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
