Question about Sony PlayStation 2 (PS2) Console
Removed Laser ribbon
Hi my brother has recently removed part of the laser ribbon from my ps2 slimline.....now i was wondering if i could replace the whole laser with an original ps2 laser as i have one lying around....please help on this
    Filmmaker:
    Uploaded 5 video answers.
  • 152 Answers
Sorry a ps2 **BIG SYSTEM** wont fit ..now the ribbon in some of the old ps2 are thin insted of the wide type and they may fit but if i understand your ? right a ps2 lazer wont fit
Posted on Nov 26, 2008
Please someone help me! I have a slim 90001 series ps2 that is not working. I've replaced the Motor/laser, power button and all ribbons and white cables and it STILL will not play any dvd, cd, PS1 or PS2...
When you received the laser (optical pickup) did you unsolder the static point on the laser board before installing the laser or check to see if there was one?
If there was one and you did not unsolder it will not allow the laser to work. They are usually near the back and are a drop of solder and when unsoldered they tent to look ( | ) like separate pads.
May 05, 2010 | Sony PlayStation 2 Slimline Console
The ps2 won't realise there is a disk in it.
I have fixed this issue twice in two different PS2's. You have to take the PS2 apart and clean the laser. Also make sure the Laser can move freely, when you are done make sure the laser is at the most inner part before putting the PS2 back together. Taking it apart isn't too easy, but it's not that hard either. CAUTION: Be carefule of the ribbon cables, they will break EASILY. You have to carefully remove the cover, a ribbon cable( or two) needs to be disconnected before you can completely remove the cover.
It will hopefully work when you are done.
Sep 18, 2009 | Sony PlayStation 2 Slimline Console
Disc doesnt spin , the lens dont move up and down , only lights red
Sounds like a motor issue, not a laser issue.
http://cgi.ebay.co.uk/PSTwo-Slim-DVD-Drive-Snake-Motor_W0QQitemZ290237209741QQcmdZViewItem?IMSfp=TL080609158a11571
That link is for a new snake motor which moves the laser back and forth
http://cgi.ebay.com.my/Playstation-2-Ps2-PS2-Spindle-Motor-V3_W0QQitemZ250083031090QQihZ015QQcategoryZ11328QQcmdZViewItem
This link is for a new spindle motor.
Jun 11, 2008 | Sony PlayStation 2 Slimline Console
PS2 Slimline read error
ps2 slimlines had as problem with doing the lasers .this was a fault of over voltage to the laser lense.sony did bring out a mod for this.you would have to replace the laser .they are not all that dear.make sure you get the right one for your model
Apr 26, 2008 | Sony PlayStation 2 Slimline Console
Disk read error on slim ps2 scph 75003
hello pauldonp...if this is an early version of the slimline they had a problem with over voltage which inturn took out the laser.your only option may be to replace the laser . sony did bring out a mod for this..i preferr the real old version of the ps2 as they had all separate boards and if one went faulty you didnot have to replace the lot ,also the lasers were a lot cheaper than the later models .in the slim lines the lasers are not all that expensive .they do take a bit of setting up as you have to know the ohms setting on the laser for each model..hope this helps
Feb 08, 2008 | Sony PlayStation 2 Slimline Console
Laser Wont fire
I had the very same problem with my ps2. What I had found was that I had indeed gotten a nonfunctioning laser. After I installed another new laser, the system functions without any problem. I hope this information helps you.
Jan 05, 2008 | Sony PlayStation 2 Slimline Console
Sony slimline ps2 NO DATA
the ps2 slim gets disc read error alot. this issue can be fix by replacing the laser in the system. make sure you get the correct laser
Nov 03, 2007 | Microsoft Xbox 360 Console
No data error all discs, even new ones
Hi STokesG101,
I am StokesG too.  Greg Stokes From South Carolina USA.  You Laser has melted.  If you good with Electronics repair like me, you could open the case back up and replace the laser.  The Ribbon cable that connects to the laser is held in place.  You have to carefully unlatch the retainer that holds the Ribbon in.  I think it is read and pulls out on both ends of the ribbon connector.  Its not a flip up type, it is a pull out type connector.  You can get another laser from www.repairmyvideogame.com
I can replace the laser for you for $40 which includes return shipping.  My email is repairtech@playstationclinic.com and I run the website www.playstationclinic.com
Sep 30, 2007 | Sony PlayStation 2 Slimline Console
Disk Read error
Re order the optical carrier ribbon, form the net and also make sure the optical laser is the right class, amp. Volt and resistance as the normal one. If you put in a different 'class' laser the device could be more damaged... hopefully not. Now your warranty is out the window as you have opened the box yourself. Firstly the easier thing is to buy a whole new blue ray device, it should be a Sony, (no surprise) just quote the serial number and device name on the web or on the phone and volla! Install the device and everything should be working. Good luck.
Sep 24, 2007 | Sony PlayStation 2 Slimline Console
Disks wont spin on new laser
Did you remove the anti static solder blob (point) on your new laser with a soldering iron and solder wick prior to installing it? The symptons your explaining indicate that point is still intact, If so you will need to carefully remove it first then reinstall the laser and try again.
Sep 13, 2007 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 (PS2) Console Logo
79 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
