Question about Panasonic Cameras
Panasonic lumix fh20 with photofunstudio 5.0 error message when camera is connected saying,
Error message reads, "Unhandled exception has occured in your application. If you click Continue, the application will ignore this error and attempt to continue. If you quit the application will close immediately." Then it tells me to go to the bottom of the dialogue box for instructions - "To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the section. The application must also be compiled with debugging enabled. When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box. What is "unhandled?" Panasonic says my version of PhotoFunStudio is up to date. I made the mistake of opening something in Windows Media & using MS Internet Explorer once - is that the problem? I try not to use any MS anything on the web b/c it's just a virus/bug/rootkit/malware prone system.
  • 197 Answers
SOURCE: Turning off Hibernation
you'll need to reinstall your operating system.that's an almost FATAL flaw you're dealing with.
Posted on Jun 16, 2008
  • 11967 Answers
It may be an issue with the amount of processing power your computer has. You could try uninstalling the software and then re-installing it...sometimes that helps but, if your computer is under-powered, you may have to do without the program.
Posted on Oct 27, 2009
  • 11967 Answers
SOURCE: photofunstudio
Why don't you just right-click on the photo and select e-mail. You can even choose the size of the picture to send without affecting your original.
Posted on Jan 25, 2010
  • 428 Answers
SOURCE: See the end of this message for details on
Not sure whether this is a Q.
To enable just in time (JIT) debugging, the config file for this application or machine (machine.config) must have the jitDebugging value set in the section. The application must also be compiled with debugging enabled. For example: <configuration> < jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the machine rather than being handled by this dialog.
In VS the way to enable/disable that is: 1-On the "TOOLS" menu, click Options. 2-In the Options dialog box, select the Debugging folder. 3-In the Debugging folder, select the Just-In-Time page. 4-In the Enable Just-In-Time debugging of these types of code box, select or clear the relevant program types: Managed, Native, or Script. To disable Just-In-Time debugging, once it has been enabled, you must be running with Administrator privileges. Enabling Just-In-Time debugging sets a registry key, and Administrator privileges are required to change that key. 5-Click OK.
It has to be done by the developer and its his responsible to guide the application error reporting to the system event handlers. If this is an issue which occurs in a certain app, have to check for the .net version (specially in vista). Many 1.0 and 1.1 based apps give the problem. To install dotnet fw 1.1 on Vista will give an error. Most of the time caused by DEP (Data Execution Prevention). But the thing is some software forces the installation of .net framework (older versions). How ever Vista is packed with .net 3.0 and 2.0. Even if you allowed to install will not be able to uninstall 2.0 (possible to remove 3.0 though).
How to solve the installation issue: This issue is resolved in Microsoft .NET Framework 1.1 SP1, however you will need to use the following procedure to install both the .NET Framework and the Service Pack at the same time: Download Microsoft .NET Framework 1.1 Redistributable Package and Microsoft .NET Framework 1.1 Service Pack 1 using links below: Dotnet Framework 1.1 Redest Dotnet Framework 1.1 SP1
Save both installations in the same directory Ensure that the Microsoft .NET Framework 1.1 Redistributable Package is named dotnetfx.exe. If not, change its name to dotnetfx.exe. Ensure that Microsoft .NET Framework 1.1 Service Pack 1 is named dotnetfxsp1.exe. If not, change its name to dotnetfxsp1.exe. Open command prompt as Administrator, and change to the directory where the two installations are saved. Run the following commands using the order shown below dotnetfx.exe /c:"msiexec.exe /a netfx.msi TARGETDIR=C:dotnet" dotnetfxsp1.exe /Xp:C:dotnet etfxsp.msp msiexec.exe /a c:dotnet etfx.msi /p c:dotnet etfxsp.msp Install both Microsoft .Net Framework 1.1 and Service Pack 1 by running C:dotnet etfx.msi
The systems must be backed up before trying this specially the system state. How ever the keys can be repaid in a damage This thread will also be helpful
Posted on May 29, 2010
Panasonic DMC-ZS5 How to download pictures? Equipment needed ?
If you want to use a computer to read the internal memory or the SD card in the Panasonic Lumix DMC-ZS5, you will need the correct USB cable, which is an 8-pin micro USB (M) to USB A cable, . (One example: ) Then ensure that the camera is fully charged or is getting additional power (AC adapter or DC coupler). After connecting the camera to the computer, you should be able to transfer files from File Explorer (Windows) or the Desktop (Mac). This may depend on your OS, see page 140 of the Advanced Features Manual for the supported OS versions. (Check Windows compatibility for later Windows version compatibility.)
With Windows XP, Vista or 7, you can also use the PhotoFunStudio that came on the CD with the camera. There is an update to the software here: . See the manual for using the PhotoFunStudio software.
The direct link to the Advanced Feature manual is .
I hope this helps.
Jan 24, 2018 | Panasonic Cameras
New Dell, running Windows 7 professional. Photofunstudo 4.0 will not run. Error message: not compatible with OP. Can U help?
Some software will only run on a 32-bit OS - can you check to see if there is a 64-bit version of Photofunstudio available ? Good luck.
Dec 26, 2015 | Panasonic Lumix DMC FZ35 Digital Cameras
May be. If you try installing version 9 and it tells you that you must uninstall any previous versions , then yes. Most updates will do this for you, so just look for the message at installation time.
Jan 14, 2014 | Cameras
How to connect to computer
Please follow the instructions below to connect your Lumix DMC-LZ7 Digital Camera to your computer
1.Install the software ( LUMIX Simple Viewer or PHOTOfunSTUDIO-viewer-) in the CD-ROM (supplied) to your PC.
2.Set the camera to a mode other than the PRINT Mode.
3.Turn on the camera and the PC
4.Connect the camera to the PC via USB Cable (A) as shown in the diagram.Cable (B) is the optional AC Adaptor ( No need if batteries are used )
4. The drive appears in the [My Computer] folder ( If you are connecting the camera for the first time,the required driver is installed automatically and then the drive appears in [My Computer] )
5. The following message is displayed on the screen during Data Transfer
Jun 19, 2011 | Panasonic Lumix DMC-LZ7 Digital Camera
Memory card is locked, how do I unlock this?
Problems typically are pretty rare with Panasonic Lumix digital cameras. On those occasions where you do have an issue, though, look for an error message on the Panasonic camera for some clues as to how to fix the problem.
he seven tips listed here should help you troubleshoot your Panasonic camera error messages.
  1. Built-in Memory Error error message. If you see this error message with your Panasonic camera, the internal memory area of the camera is either full or corrupted. Try downloading photos from the internal memory. If the error message continues to appear, you may need to format the internal memory area.
  2. Memory Card Locked / Memory Card error message. Both of these error messages are related to the memory card, rather than the Panasonic camera. If you have an SD memory card, check the write protect switch on the side of the card. Slide the switch up to unlock the card. If the error message persists, it's possible the memory card is corrupted and needs to be formatted. It's also possible the memory card was formatted using another device that is not compatible with Panasonic's file structure system. Format the card with your Panasonic camera to fix the problem ... but keep in mind that formatting the card will erase any photos stored on it.
  3. No Additional Selections Can Be Made error message. If your Panasonic camera allows you to "save" photos as your "favorites," you may find this error message because the camera has a limited number of photos that can be labeled as favorites, usually 999 photos. You cannot mark another photo as a favorite until you remove the favorite label from one or more photos. This error message also may occur if you're trying to delete more than 999 photos at one time.
  4. No Valid Picture error message. This error message typically refers to a problem with the memory card. Most of the time, you'll find this error message when you try to play back images from the memory card and the memory card is corrupted, empty, broken, or has been formatted with another camera. To fix the memory card, you must format it, but formatting a memory card causes all photos stored on it to be lost. Try inserting the memory card in another device or in your computer and try downloading any photos stored on it before formatting it with your Panasonic camera.
  5. Please Turn Camera Off And Then On Again error message. At least this error message says "please." This error message most likely occurs when one of the parts of the camera's hardware is malfunctioning, usually a jammed lens housing. To try to fix this problem, start by turning the camera off for a few seconds before turning it back on. If this doesn't fix the problem, try resetting the camera by removing the battery and memory card from the camera for at least 10 minutes. Replace both items and then try turning the camera on again. If the lens housing is jamming as the lens moves through its zoom range, try gently cleaning the housing, removing any debris or grime. If all of these steps don't fix the problem, you'll probably need a repair center for the camera.
  6. This Battery Cannot Be Used error message. With this error message, you've either inserted a battery that's incompatible with your Panasonic camera or you've inserted a battery that has dirty contacts. Gently clean the metal contacts with a dry cloth. In addition, make sure the battery housing is free of debris. You sometimes may see this error message if you're using a battery that's not manufactured by Panasonic. If the third-party battery is working OK to power the camera, you probably can ignore this error message.
  7. This Picture Is Protected error message. You'll see this Panasonic camera error message when the photo you've selected has been protected from deletion. Try working through the camera's menus to figure out how to remove any protection labels for the photo files.
Keep in mind that different models of Lumix cameras may provide a different set of error messages than is shown here. If you are seeing Panasonic camera error messages that aren't listed here, check with the user guide for your model of Panasonic Lumix camera for a list of other error messages, or visit the Support area of the Panasonic Web site.
Jul 11, 2010 | Panasonic Cameras
An unhandled win32 exception occured in svchost
Windows error from some component of your browser most likely. Try reinstalling the web browser (and rebooting if it's Internet Explorer).
Apr 07, 2009 | Computers & Internet
Download of software
I have purchased a Panasonic Lumix FS 20 but am having trouble downloading the CD. After loading, the message "The system has been damaged. Please reinstall the application by following the manual.
I have tried this but still the same message appears when trying to access PHOTOfunStudio from the DeskTop Icon. What can I do????
Dec 18, 2008 | Cameras
Cameras Logo
224 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
