Question about Shop Fox W1776 18 Gauge 38"2" Brad Nailer Kit
My nailer won't work
  • 28 Answers
Do you have a constant air leak at the head of the gun? If so you have a blown diaphram seal. Order from mfg.
Posted on Feb 17, 2012
My 601 won't shoot any spikes it just leaves a 1/4 '' indent were nail should be?
If you're getting an indent in the wood from the driver, the gun is working properly. If the gun isn't driving fasteners/nails it's because the nail isn't under the driver when it's activated. Several things could cause this: Having the wrong angle nails in your gun. There is something in the feed path of the nails preventing them from feeding fully into the nose piece. The feed shoe is jambed or feed shoe spring is broken.
Feb 18, 2013 | Senco & Frame Pro 601 Framing Nailer
Porter cable FR350 round head nailer type 2 fires when it is connected to air hose and won't fire afterward
Various nailers will fire on their own when connected to air if the orings have become hard or worn and internal trigger valve parts worn-out (mostly Dewalt and P/C). You could buy an oring kit or purchase trigger valve seperately. Replacing trigger valve and lubing the headvalve with white grease will most likely solve the problem. After repairing the gun, be sure to remove the nails from the mag after each use to prevent possible discharge of nail. Good luck
Oct 21, 2012 | Air Tools & Compressors
Porter cable roofing nailer piston won't retract
Could be the check-band around the cylinder. Easy to check. Remove the head and pull out the cylinder. There should be a rubber band covering a series of pin-holes drilled into the cylinder. Usually the band will fall out of place or break. Use any rubber that will stay in place to cover the holes. Good luck.
Oct 16, 2012 | Porter Cable RN175 Roofing Coil Nailer
I have a porter cable roofing nailer model # RN175 that does not advance the nails everytime what causes this?
Some causes, in order of probability:
Roofing nailers get a lot of tar build up on them, especially around the nose safety and nail feed pawl area. Cleaning off this buildup will usually take care of most problems with roofing nailers.
On the side of the gun away from the side you load the nails on there is a small cylinder with a piston inside that attaches to the feeder pawl. If air isn't getting to the piston or the piston's o-ring or spring is damaged, it won't cycle properly to advance the nails.
If the driver doesn't retract fully, the next nail won't be able to advance properly for the next shot. This can be caused by o-rings in the head that are worn or out of their proper place.
Oct 06, 2012 | Air Tools & Compressors
Wont shoot nail every time pin wont return all the way up
Some reasons the driver/piston assembly won't retract fully:
- damage to the o-ring (LB1003) around the piston
- cylinder (BA0165) is scored badly
- driver (EA0167) is bent, twisted or warped
- o-ring (LB1023) around bottom of cylinder (in groves & covering small holes) is stretched out or out of place.
- Seal (BC0492) at bottom of cylinder & under bumper is damaged or gone
Aug 11, 2012 | Senco 1Y0013N FP35 1 1/4 Inch To 2 1/2...
My ridgid r213bna nail gun won't fire a nail, but has good pressure & no jam...
If a gun is firing and nails are not being driven into the work it's because of one of two problems. The nails aren't feeding fully under the driver or the driver isn't fully retracting each time the gun is activated. Is looks like you've eliminated a feed problem so you are going to have to take the gun apart to find out why air is not being held in the bottom of the head long enough to push the driver back up the cylinder. Go to www.ereplacementparts.com and bring up your model so you can follow along. Remove the four screws holding the head cap on. The things that can cause your problem are: the piston seal & o-rnig are damaged, the cylinder is badly scored, the o-ring & cylinder ring on the bottom half ot the cylinder are damaged or out of place, or the driver guide under the bumper is broke or missing. If it turns out internal parts are damaged or missing, I highly recommend the overhaul kit to replace all the 'soft' parts inside the gun as long as you have it apart.
Jul 22, 2012 | Nailers Ridgid Finish Brad Nailer R213bna...
Paslode nail gun ,fan won't shut off
replace circuit mold assembly or spark unit its probably the spark unit
Jul 08, 2012 | RTO PasLode 900420 Impulse Framing Nailer
Firing pin won't return SB 1842bn
Lubricate it and crank up air pressure and return spring.
Feb 14, 2012 | Stanley Bostitch Sb1842bn 18 Gauge Brad...
My framing nail gun won't fire when trigger is squeezed air leaks out but won't fire
Time for oring kit # d518005 available at Dewalt service center or at www.toolpartsdirect.com.
May as well order the replacement trigger valve while there. These two items will renew your gun. Good luck
Sep 16, 2011 | Dewalt Round Head Framing Nailer D51845
Shop Fox W1776 18 Gauge 38"2" Brad Nailer Kit Logo
136 people viewed this question
Top Shop Fox Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Shop Fox Air Tool and Compressor Expert? Answer questions, earn points and help others
