Question about Dremel 400 Xpr Rotary Tool
Shaft threads are striped - Dremel 400 Xpr Rotary Tool
Shift lever loose
hello,I had some threads striped out of the end that goes over the shaft and caused it not to tighten good enough on the knurled end coming out of the gear housing. I took it off, retapped it with an 8mm tap and bought a new 8mm bolt to go in there. Actually gave me a chance to re-adjust the position too. Works great now.
get the service manual for it it will help you can download it from the below link:
http://goo.gl/HyxTzr
good luck
Jul 29, 2013 | kawasaki VN 1500 Vulcan Classic...
Swingarm pivot bolt striped out on 81 flh
Hi Anonymous, this issue should be repaired by an experienced professional at your local dealer or reputable shop. It can be done without removing the cylinder head, transmission or primary depending on your scenario. Your damaged threads can either be restored or replaced with steel threads without contaminating the affected area with broken aluminum threads. good luck and have nice day.
Aug 29, 2012 | Harley Davidson FLHT Electra Glide...
Troy bilt lawn mower were spark plugs go in striped and wont tighten
you can get a spark plug thread repair kit at a auto parts store
Aug 12, 2012 | Garden
Striped head on head bolt on satorn vue 3.0
You have 2 courses of action here,one get a new block ,( exspensive)or get a helicoil thread insalled in the striped hole ,drill according to spec. on package and install with supplied tool ,it all comes in a kit at napa or other parts stores ,
Jul 21, 2012 | 2002 Saturn VUE
Plug hole is striped
Hi Skipper62, it's always a possibility when ever steel threads go into aluminum threads. you must be carefull with any fastener not cross thread when installing especially aluminum threads. If you trailer your bike to your local dealer or reputable shop, they can replace the stripped out aluminum threads with steel threads without removing the head. Good luck
Apr 30, 2012 | 2002 Harley Davidson FXDX Dyna Super Glide...
How to get the shaft out of evinrude 1988-89 v4 outboard
We had some success suspending powerhead (if removed from lower) and first rattling the shaft with an air chisel (using blunt head) - worked best on dry rust. If that didn't work it was soaked for a few days in rust buster. and tried again. If that didn't work, we put a bearing splitter on the groove above the pinion splines and a perfectly cut threaded pipe with a threaded union on one end over the drive shaft in such a manner the pipe would apply pressure to the crank shaft when the union was unscrewed.
Now if that didn't work, you can cut the drive shaft off the engine at the crand shaft and drill a hole thru the stuck part. Then tap a thread into the hole and thread a bolt into the stuck part till it bottomed out in the crank shaft and continue to thread it in and it would walk the piece out -saving the crankshaft.
Hope it doesn't have to go that far.
Dec 19, 2010 | Clymer EvinrudeJohnson Outboard Shop...
The nut holding the steering wheel in place has been stripped. It may be possible to rethread. What is the size and thread count for this nut?
Snap-on has thread file's they come in metric or stander each file has 8 sizes total of three, # tfm7530b - tf1127b - tf1124b.
Dec 30, 2009 | 1994 Pontiac Firebird
How to get the blinker switch assembly out of a 1966 oldsmobile 98?
1966 Olds 98?
It's been a while, so bear with me. The main objective is to remove the steering wheel, to have access to the turn signal switch.
1.Negative battery cable disconnected
2.I believe you twist the horn button in the middle of the steering wheel, and pull up, to remove. The horn button should have a ring of thick rubber on the bottom, which keeps it in the steering wheel. The chrome piece under the horn button may come off with it, or it stays on the steering wheel. This is the part that is fuzzy to remember.
3.Remove the steering wheel nut, and lock washer.
4.If you do not have a steering wheel puller, go to your nearest auto parts store, and see if one is available to rent. The cost of this puller is relatively low, so you may just want to go ahead, and purchase one. While you're there you need to obtain another tool also. Steering Wheel Lock Plate Tool.
5.After the horn button is removed, and the steering wheel nut, you will see a flat metal area of the steering wheel. On each side of the threaded part of the steering column shaft, there are two small threaded holes, in this flat metal area.
The steering wheel puller, is a bar shaped piece of metal, that has a threaded hole in the middle. There is a threaded shaft that goes into this hole. On each end of the metal bar are slots. Threaded bolts go through these slots, and line up with the two threaded holes in the steering wheel. There is a pointed tip, that rotates on the threaded shaft, of the steering wheel puller. This pointed tip goes in the middle of the steering wheel shaft. (The shaft that you removed the nut from)
Find the two correct threaded bolts in the steering wheel puller kit, that matches the threads in the steering wheel holes. They HAVE to be the correct size, AND the correct thread. (Fine thread, or Coarse thread. They will be SAE thread, and not Metric) If the puller does not come with bolts, or the correct bolts, you'll have to purchase them separately.
Place the puller on top of the steering wheel shaft. Run the threaded shaft of the puller down, until at least 3 to 4 threads of the shaft, are showing on the steering wheel side. Now place a threaded bolt in the slot on the outside part of the bar.
Run the bolt down into the steering wheel threaded hole on one side. Make sure it goes in at least 1/2 inch. Do the same with the threaded bolt for the other side.
Adjust the length of the threaded shaft of the puller, so that the two outside bolts will go in as advised. Adjust the threaded shaft out, or in. Be SURE the two threaded bolts, are threaded down into the steering wheel the same depth, and the bolts are the same length!
Now turn the threaded shaft of the steering wheel puller in, with a ratchet and socket, to remove the steering wheel. (Turn the shaft to the Right)
6.Now remove the steering wheel lock ring. The steering wheel lock ring tool is now used.
There is a cylindrical shaped piece that has threads on the inside of it, and has a hole at the top, that a lock pin slides through, for the above tool. This cylindrical shaped piece is threaded down onto the steering wheel shaft.
The tool has a handle shaped like a screwdriver handle, and a shaft attached to the handle. The shaft goes down into the cylindrical shaped piece. Then the lock pin goes through the cylindrical shaped piece, and also a hole in the shaft of the tool. This lock pin locks the cylindrical shaped piece to the shaft of the tool.
BEFORE the cylindrical shaped piece is pinned to the shaft, you slide a U shaped piece up on the shaft. (Thought it would be better to explain it this way)
The opening of the U, goes down towards the steering wheel. It's U shaped to clear the steering wheel shaft.
As you turn the handle of the tool to the right, it pushes the U shaped piece down. The U shaped piece then depresses the steering wheel lock ring down.
(There is a Thick metal spring under the steering wheel lock ring)
You have to take a metal pick, and a small flat tip screwdriver, and remove the round snap ring. May take a little finesse, and a few tries. Use patience. Now back the steering wheel lock ring tool off. (Turn to the Left) The steering wheel lock ring will come up, so that you can take it off. Remove the spring. Remove the plastic horn contact assembly. Now you can see the screws to remove the turn signal switch.
Sep 28, 2009 | 1972 Oldsmobile 98
I've striped the threads on the blade bolt of my 15 y/o Craftsman tablesaw. Can that be replaced?
Best repair would be to get a replacement shaft from Sears. Another option there is an item called a threaded shaft collar. It is made of one piece, split thru the OD to the ID on one side. A screw is adjusted to tighten the collar against the shaft. Flats could be added to the OD and the collar could be used in place of your current nut. This item could be purchased from an Industral Supply store. 2nd option - An experence welder could add material to the threaded area and the shaft could be rethreaded
Jun 24, 2009 | Craftsman 10" Table Saw
How do i remove the knob for a 1988 911 Porsche headlight switch? The shaft has a hole to hold it from rotating so i assumed the know screws out. I tried this, the knob rotates but does not come off....
hello jesse
the knob is most likely broken you need to take it off and get a new one, the threads on it are broken-striped,use plyers for the job,but safe the "light "logo new switch -knob -does not come with it..
proporsche
Jun 15, 2009 | 1985 Porsche 911
Dremel 400 Xpr Rotary Tool Logo
44 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
