Question about Gateway Computers & Internet
Need to now where to buy a newton power supply for my gateway 700x (newton power) nps-250HB A
Wont power up nothing
  • 2,478 Answers
Go to atxpowersupplies.com for $39.99
Posted on Feb 11, 2012
2 Suggested Answers
Fame_Guru
  • 483 Answers
SOURCE: Need to replace power supply
you have it here..
http://www.oemliquidators.com/search_result.asp?product_id=6500724&title=GATEWAY%20NPS-180EB%20POWER%20SUPPLY%206500724,%206500817%20-%206500724
Thanks
Fame !
Posted on Apr 27, 2009
I can't find an old user manual or technical manual on the NPS-200PB-96A. Does any one know where I can find one? I haven't been able to find one on Google.
User manual for a Newton NPS 200 Watt Power Supply? (Newton Power Supply. NPS)
What is it you wish to know?
I suggest you Do Not open it up to attempt repair. There are Electrolytic Capacitors inside. (Radial Aluminum Electrolytic Capacitor) These capacitors can hold a charge for weeks, months, sometimes over a year.
If your finger/s touch the terminals on the bottom, the charge could be released to You! If your finger/s touch the Positive terminal on the bottom, and touch the metal case of the Power Supply, the charge could be released to You! The shock is Bad to Fatal.
The capacitors have to be properly drained in order to attempt repair. Is it the form factor you're after? It's an ATX form factor SMPS. (Switched-Mode Power Supply) 6 inches Wide, 5.5 inches Long, and 3-1/2 inches Tall.
Specifications and Manufacturer?
http://support.gateway.com/s/POWER/q00323/650032306.shtml
What the various power cables are?
http://www.playtool.com/pages/psuconnectors/connectors.html
Post back in a Comment.
Oct 07, 2010 | Gateway Computers & Internet
Gateway yellow power button, nothing starts, no fan, nothing. opened up computer and see mobo led light is lit. newton ps has a test button. tried to test with various components plugged in and the test...
Power supply has several voltages. Just because the 5v power is active doesn't mean all the voltages are OK. You need to have the power supply tested for 12v and 3.3v. A quick test is to unplug all the wires from the power supply. There is a single green wire on the motherboard main plug. Connect (use a bent paper clip) that green switch wire and any black wire. Plug in the power supply and it should run (fan starts)
Oct 26, 2009 | Gateway (ATX-300-12EB3) (ATX30012EB3)...
Need Manual for Slot1 PIII Gateway Jabil Tabor III Motherboard.
The memory specifications for that motherboard are as follows:
  • 100-megahertz (MHz) Memory Bus Speed (FSB)
  • Three 64-bit or 72-bit Error Checking and Correction (ECC) 4-clock, 3.3V, unbuffered synchronous DRAM (SDRAM) Single or double-sided DIMMs in the following sizes: 8 MB, 16 MB, 32 MB, 64 MB, 128 MB
  • Expandable to 384 megabytes (MB) of SDRAM, CAS latency of 2, using 64-Mbit chips
  • DIMMs must adhere to the Intel 4-clock 100-MHz 64-bit unbuffered SDRAM DIMM specification, latest revision
  • Uses gold-plated DIMM socket
  • ECC signal and multiple bit detection, single bit correction, supported, using ECC DIMMs, can be enabled and disable in the BIOS Setup Utility
  • Jun 21, 2009 | Gateway Computers & Internet
    Newton Power Ltd NPS-210BB Power supply dead.
    Not a solution I am afraid., but can you tell me who in the UK mends these as mine has just gone
    May 31, 2009 | Computers & Internet
    Want to add memory to Gateway 700x
    Max memory is 2GB, i.e. 1GB per slot(DIMM), so you will need 2 X (SimpleTech 1 GB PC3200 400MHz DDR RAM). {Always use matched pairs only}
    Visit this link : http://www.simpletech.com/upgrades/gateway/700x/700xddrintelp428ghz/
    .................sodeep
    Mar 31, 2009 | Gateway 700 X PC Desktop
    Upgrading RAM on your Gateway 700X (DDR) Computer is easy, Gateway 700X (DDR) Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. RAM Type, and comes installed with 512 MB (removable) of RAM.
    You can upgrade your Gateway 700X (DDR) Computer to up to a maximum of 2.0 GB RAM, the Computer has 4 sockets to install RAM, already with 512 MB (removable) standard RAM installed. For best Computer performance use the maximum amount of allowed RAM per slot for your system.
    Dec 08, 2008 | Computers & Internet
    Computers & Internet Logo
    130 people viewed this question
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Alun Cox
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
