Question about Mitsubishi WD-65736 Television
Mitsubishi WD-65736 Television - Reset timer
I want to reset the timer, put bew bulb in and now the timer light is on and tv does not work
SOURCE: mitsubishi tv
ok.
#1. replaced capacitors on power board. DM board FMT board .
# 2 on power board you need to chek caps. 3300mf x 35 v.QTY 2.
# 3 12 capacitor 1000mf x 16 v.
If caps 1000mf x 16 v . looked good. replaced anyway......
Posted on Sep 17, 2008
  • 179 Answers
SOURCE: Timer light blinking green/tv won't turn on
the wd 62327 doesn't have a DM module as it doesn't have the atsc tuner. are you sure you have a wd62327?
in a normal set
power:
Green Blink = μPC Initializing (after AC off/on) (1~2 sec)
get the error code by doing this: (and let me know)
Error Code Operational Check
Pressing the front panel “INPUT” and “MENU” buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The ” Power LED” flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Note: The front panel buttons must used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is “34”, the LED will flash 3 times, pause, and then flash 4 times.
Posted on Nov 17, 2008
  • 52 Answers
SOURCE: How to reset lamp timer on mitsubishi wd-65734
This model there is no reset for lamp timer.
Posted on Nov 14, 2009
SOURCE: Green Light on Mitsubishi WD-62525 keeps blinking
Fluke solution: Press and hold Menu+Enter on front of TV...
WD-62525: My Green Blinking Fix!!!
http://www.avsforum.com/avs-vb/showthread.php?s=eb9ba9017a86fd9993de5feb77ee5f25&p=17646001#post17646001
Posted on Feb 09, 2010
SOURCE: Mitsubishi Model WD-52725 timer green light blinking fast
My Mitsubishi WD52725 will not turn on...the timer light is blinking. We pushed the reset button, unplugged tv. Just got off the phone with Mitsubishi customer "service." After answering numerous personal questions, and being on hold for several minutes, I was told that the only solution was to push the reset button. Duh! We'd done that several times with no change, which is why I called them! BIG WASTE OF TIME!!!!
Posted on Jun 19, 2010
My Mitsubishi tv WD 73734 won't show a picture you can hear sound and it powers on and off lamp light red and timer lighter blinking
No TVs will behave that way due to a timer. TVs only will display a nag screen telling you to reset the timer. If your lamp is more than 2 years old, it is suspect of failure. Be sure you buy a lamp with an Osram brand or Philips brand bulb inside. Any compatible(knockoff)lamps will not perform as they should. Mitsubishi DLP TV Bulbs
These folks sell original Osram bulbs in their lamps and they have a 6 month warranty. I use them myself for repairs and really have had great experiences with them.
Sep 09, 2015 | Mitsubishi WD-73734 73" Television
I just replaced my bulb on my mitsubishi wd-65736 but picture is still dark looking and the bulb stays lit up after we cut the TV off. Could I have hooked the two wires up wrong?
This site lists your service manual for $7.99
https://www.completeservicemanuals.com/mitsubishi/dlp-projection-television/wd-65736-service-manual/prod_1408.html
This site claims to have a free PDF download, but the "free download" link throws you to www.tradebit.com, which sells the service manual (as a downloadable PDF file) for $7.99
http://www.promanuals.com/serviceparts/mitsubishi-wd-60735-wd-65735-wd-73735-wd-65835-wd-73835-wd-60c8-wd-65c8-wd-73c8-wd-65736-wd-73736-service-manual/
This site sells your TV service manual for $5 as a .PDF sent to your email:
http://tv-part.com/index.php?target=products&product_id=1369
If you can read/use a service manual, $5+tax is a lot better than $hundreds for a new television. Or- buy the downloadable manual, and give it to your favorite electronics friend to peruse. The darkness coming from the new lamp might bespeak of a power supply problem, or a poor connection between the lamp and the power supply. The fact that the lamp module stays on after it should go out also says power supply problem.
In the worst case, keep both your lamp modules (they're probably both good), and sell them online to help defray the cost of a new television.
Sep 30, 2011 | Mitsubishi WD-65736 Television
Timer light blinking fast and is green, Tv will not turn on even after a reset, bulb is good
First mistake was buying Mitsubishi Model WD-62525
The DM capacitors need replacement contact a local Mitsubishi Model WD-62525repair center.
Jan 23, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Blinking timer light - no other lights are blinking I have unplugged the TV overnight, replugged it in and hit the reset switch. TV will not come on. If it's a bad bulb, not sure why the lamp light is...
The blinking timer light is usually caused by bad capacitors on the DM board. The V26 DM repair kit from www.tvrepairworld.com should repair that issue. The kit contains the parts and the Cd with instructions.
Dec 20, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Wd 57732 won't turn on, power/timer light blinks
probably something related to the FMT board. will need shop service.
Aug 30, 2009 | Mitsubishi WD-57732 Projection Television
Buzzing noise from Mitsubishi DLP WD-52327 after replacing bulb
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
Feb 14, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Red light front of tv
If you still have a good picture, then NO, just reset your lamp timer. The instructions should be in your owners manual.
Feb 01, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi WD-65736 Television Logo
180 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
