Question about Innovage Jumbo Remote Control
Need code for samsung flat screen tv
Cant find manual need code to use my remote on my samsung flat tv
I have a Samsung TV iamuseing a ermsom remote need codes for this remote
Search Results
    Remote Control Codes
    support-us.samsung.com/.../pop_troubleshooting_fr...
    Samsung ElectronicsAug 11, 2011 - ... all televisions. If you encounter problems, use the television's ownremote control. ... While the television is on, press and hold the TV Power button and enter the corresponding two-digit code. ... SAMSUNG ... EMERSON. 64.
    Remote Control Code List
    www.jumboremotecontrol.com/remote_control_code_list.html
    ... codes for the remote. If you do not see your device listed, you can use the codesearch feature to program the device into the remote. TV Codes TV Code List ...EMERSON ... SAMSUNG, 004,005,009,015,104,105,106,109,172. SAMSUX ...‎Guide to Programming the ... - ‎Download the Manual - ‎8 Device Learning Jumbo ...
    Remotes - Device Codes - HiFi Remote
    www.hifi-remote.com/codes-tv.shtml
    TYPE, BRAND, CODES ... TV, Emerson, 0463, 0236, 0019, 0180, 0280, 0179, 0154, 0177, 0178, 0038, ... TV, Samsung, 0019, 0060, 0030, 0056, 0178, 0032.
Feb 05, 2016 | Samsung 50 in. Plasma TV
AEGG3CLL803606Z Samsung flat screen tv lost remote need codes to RCA Universal Remote
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 16, 2014 | RCA Universal Remote Control
I NEED THE MANUAL CODE FOR A SANYO RMT-U130 UNIVERSAL REMOTE FOR MY SAMSUNG TV
If you know the setup codes to check with your TV brand,
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
If you do not know the setup codes, and wish to know more about setup codes and setup proceedings to many brand remote controls, check this site. General setup codes to check with Samsung brand TVs are : 0105 0077 0076 0109 0007 0009 0004 0005 0085 0172 0942 0358 0012 0015 0080 0104 0106
Jan 23, 2013 | Samsung Televison & Video
I have a Samsung LTN1765X/XAA with the user manual, but I have no remote which is required to go through the menus to set up the TV - I have an ATT 200B universal remote with manual and have gone through...
$29 vs the cost of a new tv is not too bad. i had a similar problem with a Vizio and smart remote. in my case i was able to get support from the remote manufacturer and solved my issues. i didnt have the right code and could only access some of the remote functions until i found the correct code throught the remote manufacturer. not sure how much help you could get from att. i was using a logitech remote. if you cant get help with the codes for the remote, i would opt for the samsung replacement remote.
Dec 24, 2010 | Televison & Video
I need the code to input into my Jumbo Touch Screen Remote so that I can use it on the Samsung Plasma T.V.
here is the manual:
http://www.remotecodelist.com/remotes/innovage/Jumbo_Universal_Remote.pdf
good luck.
Dec 07, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
TV CODES
I HAVE AN UNIVERSAL ZENITH REMOTE AND I NEED REMOTE CODE FOR VYOU 32 IN FLAT SCREEN LCD
Feb 18, 2008 | Televison & Video
Samsung Remote Issues
if the tv is a new tv along with remote take it back to the supplier it should still be on warrant.good luck
Apr 18, 2007 | Samsung (BN5900218A) Remote Control
Innovage Jumbo Remote Control Logo
210 people viewed this question
Top Innovage Televison & Video Experts
Computer Repairing
Computer Repairing
Electro Med Services...
Are you an Innovage Televison and Video Expert? Answer questions, earn points and help others
