Replace drive belt bosch classixx dryer
I've got the belt over the drum, but cannot remove the side panels to loop the belt over the drive - the side panels appear to be welded/glued/painted or somehow adhered to the back and front panels. How can I access the drive unit?
  • Columb Duffy
    Columb Duffy Apr 30, 2012
    Sorted - this model should be fixed only from behind. I didn't need to take off top or side panels at all.
  • 4 Answers
Worked for white knight dryers for a while and saw that the siders and main case are spot weldetd together, but dryers are really simply put together, take out more parts so you can get to what you need, but take pictures to remind you how they go back
Posted on Feb 10, 2012
  • 130 Answers
SOURCE: BOSCH WASHING MACHINE WONT SPIN, FLASHING RED SPIN LIGHT
check the pump clean out. sounds like something is jammed in the pump
Posted on Feb 16, 2009
  • 333 Answers
SOURCE: Bosch Classixx 1200 Express - metal got under the drum
If the obstruction is between the drum inner and outer then you may have to remove the rubber door seal to gain access. ISOLATE THE POWER FIRST. The problem with disturbing seals is that they may no longer seal when replaced! - Particularly if the machine is a few years old.
Probably best to leave it to a guy with a van full of spares.
Posted on Apr 01, 2008
  • 67 Answers
SOURCE: the tumble dryer does not
does the element heat up then turn right back off after a few seconds? if so, there is 2 sensors that control the heat element, one is in the duct right after the fan. when this sensor senses too hot, it will shut down the heat element. either your sensor is bad, or the lint is not getting out, causing the heat to build up in the duct.
Posted on Oct 27, 2008
dnewcombe1
  • 1564 Answers
SOURCE: bosch classixx 1200 wont spin or drain
There are two drive belts, I'm sure one is gone.
Posted on Jun 20, 2009
SOURCE: the drum won,t go around
BOSH WFL 2260 SPINS OK BUT WASHING CYCLES DO NOT WORK. FILLS WATER OK
Posted on Jan 01, 2010
Loud, low (bass) noise, not coming from the vent or the heating element
Most probably caused by one of the belts being frayed and about to break. You might want to replace the small drive belt (00096426) first as it does the most work of transferring the motor power to the shaft causing the drum to rotate. A worn belt can cause a low frequency hum and potentially slow down drum rotation as it slips on the hubs. Replacing the large drum belt requires a lot more work than the drive belt because you must remove both the front and side panels of the dryer; whereas, the drive belt is accessed by removing the right side panel.
Apr 25, 2015 | Bosch Axxis WTA 3510 Electric Dryer
Replace the drive belt
Remove the back
hook it on the motor pully and start to wrap it around the drum pully until it is to tight to continue then turn the drum pully to finish the job
Sep 27, 2014 | Bosch Washing Machines
How do i replace belt
On this model in order to replace the belt first disconnect power to the dryer. Looking at the front of the unit in the seam between the front panel and the dryer top, use a putty knife to press in & release the spring clips in the right and left sides of this seam to release the top panel. Lift the panel & rest it against the wall. Reach in & remove the 2 screws holding the front panel to the side panels. Once you have removed the screws, lift the front panel up slightly to remove the complete front panel from the stationary clips at the bottom of the dryer. Be careful with the wires going to the door switch. Either remove them from the switch or simply lean the front panel against the right side of the cabinet. Next, lift the drum and slide the new belt around the drum to the mark made by the previous belt on the drum. Be sure the ribs are facing down. Part number for the drive belt is 31531589 which over the years crossed to 341241. On your knees, reach back by the motor and idler assembly and lift the idler pulley tension arm to route the belt allowing the idler to take up the slack in the drive belt. Reassemble and dryer some clothing.
Mar 24, 2012 | Maytag PYE2300AY Electric Dryer
Replace belt
  • Disconnect the power source from the dryer. You can unplug from the wall outlet, remove the fuse from the fuse box or flip the breaker in the panel box.
  • 2
    Pull off the front panel of the dryer. Remove the screw in each corner at the bottom of the dryer's front panel. Lift up the front panel until the two clips at the top disengage. Remove the two screws that are found beneath it at the corners to remove the cabinet top.
  • 3
    Remove the belt by releasing the tension applied by the movable idler pulley wheel. The belt loops over the drum, under the idler pulley wheel and then around the motor's drive pulley.
  • 4
    Discard the used belt. It is fine to just throw it in the trash.
  • 5
    Install the new belt by pushing in on the idler pulley arm. Make sure the new belt is placed flat along the exterior of the drum.
  • 6
    Replace the screws back into the dryer's front panel. Screw them in tightly so that the panel will not fall off or jiggle loose.
  • 7
    Reconnect the power source back to your dryer. Either plug it back in or flip the switch in the breaker box.
Jan 11, 2012 | Amana DLE330RAW Electric Dryer
How to replace belt on samsung dv218ae
Hello & Welcome to FixYa
Please follow the step by step instructions for belt replacement given in this video:
Please get back to me if you have any other questions.
Kevin
Aug 07, 2011 | Samsung DV218AEW Electric Dryer
How do you change the drive belt on a Bosch Classixx tumble dryer WTA3003GB/17?
Its a fairly simple process depending on your machine. Most Bosch machine belts are simple to replace. Here is a good resource: http://www.videojug.com/film/how-to-replace-the-belt-on-a-tumble-dryer-bosch
Dec 03, 2010 | Bosch Axxis WTA 3003 Electric Dryer
How install a drive belt on GE Dryer DBVH512EFWW.
Instructions Things You'll Need:
  • Phillips screwdriver
  1. Unplug the dryer and open the dryer door.
  2. Unscrew the screws under the top lip, where the dryer's door closes, with your screwdriver. Once these screws are removed, lift the top off of the dryer. On older models, the entire top will hinge upward out of the way, and on models made after 1997, half the top will pull off.
  3. Remove the screws on the inside-top corners of the front panel so the front panel of the dryer can be removed and set aside. On models made before 1997, the front panel should be carefully set to the right side; on newer models, the panel should be set to the left side of the machine. Be careful not to damage the door-control wires.
  4. Locate two screws approximately 6 inches off the floor on each side and remove them, allowing you to push the sides of the dryer slightly apart so the drum can be removed. Pull the drum slightly toward you and reach around to remove the dryer belt from the motor pulley. If the belt is broken, this step should not be necessary. Once the belt has been removed from the motor pulley, the drum should pull up slightly and out of the dryer toward you.
  5. Remove the old dryer belt and put the new one in place, with the ribs of the belt facing the drum. The slack part of the belt should be placed near the motor. Reverse the previous directions to replace the drum, replace the screws that hold the sides in place, replace the front and replace the top.
  6. Pull the dryer out from the wall and remove the four screws holding in the panel near the bottom of the back of the dryer. You will see the motor, the drum and the belt you just set in place. Loop the belt around the motor pulley and the idler pulley, and turn the drum by hand to make sure that the belt is straight and will stay in place. Screw the panel back on and push the dryer back into place against the wall.
Sep 22, 2010 | GE Dryers
Bosch Classixx 1200 - Drum not turning
It could be the motor itself (is there any overheating smell from the motor) or it could be the capacitor which controls the motor. I had a similar problem and it turned out to be the motor brushes. I replaced the brushes and all was OK.
The only other thing that could be wrong especially if it overfills with water is the water level switch (this is a pressure switch on the side of the washer) You can easily check this by removing the hosepipe to the switch and blow gently into it, you should hear a clicking sound) This might be the clicking that you heard so it is probably Ok.
Aug 08, 2017 | Bosch Washing Machines
Bosche classixx 1000
Rotate the drum by hand. If the drum spins to freely without much resistance then it is possible that the drive belt has come off. Its unusual but it can happen. Remove back panel and refit the drive belt carefully.
If the machine is older than 5 years its possible that the wash motor brushes need replacing. If this is the case then you need to call a technician to replace them.
0417362396 Melbourne Metro area
Regards Sam
May 20, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Put dryer belt on maytag dryer
generic maytag dryer belt replacement
type 1:older models by Maytag with lintscreen under door
  • unplug dryer
  • remove 2 screws from under front panel
  • tilt front panel up from the bottom and unclip top
  • remove door switch wires
  • set front panel aside
  • remove front drum retainer 2 screws each side
type 2:newer models by whirlpool lint screen in top cover
  • unplug dryer
  • remove lint screen
  • remove 2 screws under lint screen
  • with putty knife or other blunt blade
    unclip spring clips at front corners of top panel
  • remove 1 screw each side of front panel 1/2 way from top
  • remopve door switch wires
  • tilt front panel down and unclip
all
  • withdraw drum forward
  • examine drum rollers for wear
    if worn or locked replace in pairs
  • examine felts and nylon glides(if fitted) for wear
    if worn replace
  • examin case floor for tensioner
    (sometimes broken belt ends pull the tensioner out of place its easy to see the slots on the case floor for the 2 feet and spring, looks like a power socket)
  • loop new belt around drum at wear mark of old belt
  • insert drum
  • loop belt around motor pulley
  • pull tensioner to end of travel against spring
  • loop belt around tensioner
  • relax tensioner
  • rotate drum by hand to make sure belt wont jump off
reassemble in reverse order
Oct 29, 2008 | Maytag Dryers
Washing Machines Logo
66 people viewed this question
Top Washing Machines Experts
