On turning on, the carriage returns to the left, but the motor does not stop, as indicated by a continuous clicking sound, followed by error bleeps.
    Genius:
  • 2,120 Answers
Uneconomical to repair, sorry. Bad Carriage Assembly.
Posted on Oct 23, 2008
After typing first line, hit the return key. The carriage would not return to the far left margin...it only moved 12 or so spaces to the left.
The carrier slides on a silver shaft that is about 1/2" thick spray some WD40 on the shaft, if that doesn't do it you have to get some on the carrier motor bearings located under the case in the R. rear corner.
DickyO
Feb 22, 2014 | IBM Wheelwriter 3 Series Ii Typewriter...
I get the 5100 error code. I have done the reset procedure to no avail. The cartridges seem to move normally and there is no obstruction apparent. Any suggestions on how to fix? Thanks, Terry
Hi
Error 5100 on canon is a Carriage Home Position Error. Try reseating the printer cartridges. If that doesn't help make sure there is no paper stopping the carriage from moving right to left. Try cleaning the plastic strip (encoder strip, behind the carriage) that runs the length of the carriage, it may be contaminated. Use alcohol and a swab (Q-tip) to clean. Before cleaning unplug it from the power supply. Hope this helps...please post back for further assistance.
Daniel
Jan 08, 2011 | Canon Pixma MP450 All-In-One InkJet...
ERROR 86:01
General causes are media or other obstructions in the carriage path, the trailing cable, worn carriage bushings, lack of lubrication in the carriage path, a dirty encoder strip, the scan-axis motor, or the service station. Follow the steps listed below to accurately troubleshoot the issue, and replace the appropriate parts.
1. Visually check for jammed media or other obstructions in the carriage path and remove any obstructions found (remove any loaded media as well).
2. Determine if the noise is normal. Some noise is normal. Specifically, it is normal to hear a slight clicking noise when the carriage moves under the left or the right-hand covers.
3. If an 86:01 error occurs during initialization and the carriage does not move out of the Service Station continue Step 4, otherwise go to Step 5.
4. Remove the right cover and check the cable connection between the Interconnect PCA and the Service Station motor. If connections appear normal, replace the Service Station
5. Attempt to verify functionality, if problems persist, continue with the remaining steps.
6. Unlock the carriage as instructed below:
a. Highlight the Set-Up menu and press the Enter key.
b. Press the Up Arrow and Enter keys simultaneously and then press Enter.
c. Scroll to Service Utilities and then press Enter.
d. Scroll to Unlock Carriage and press Enter.
e. Unplug the printer from the power source.
7. Move the carriage manually through the entire movement path to see if it encounters any obstructions or has more resistance in any particular spot. Remove any such obstructions if possible.
8. Clean and lubricate the carriage rail.
9. Slide the carriage manually back and forth several times to evenly spread the lubrication across the entire carriage rail.
10. Turn the printer on and attempt to verify functionality.
Nov 13, 2009 | HP DESIGNJET 500 InkJet Plotter Printer
Canon i80 service error 5100
Hi guys,
Service error 5100 indicates that carriage return (CR) operation is not performed successfully. After the printer turned on, printer initialize some operation include CR operation. This error happens when carriage part (carriage unit) has problem when move right and left in initialization process.
This may be caused by:
  • Faulty carriage part so thatit cannot read film encoder properly. As a result, carriagepart move on uncontrolled.
  • Dirty film timing **** strip (Horizontal film encoder;available only ini series and above) so carriage part cannot read film encoder properly.
  • Another material (such as broken paper, etc) present in carriage path, blocking carriage part from moving.
To fix this problem you may try the following tips:
  • Check if any material present in carriage path; remove (clear) it
  • Check if film encoder is dirty; wipe slightly with moistened clothe.
  • At last, if carriage part is faulty you need to replace it.
Hope this will be helpful for you. Please don't forget to rate me.
Regards,
Source:
Inkjet Printer Forum
Dec 24, 2008 | Canon i80 InkJet Printer
Canon i80 error 5100
Hi antoinette,
Someone has ever asked this problem and I have post a solution for this. Here is my answer:
* Faulty carriage part so thatit cannot read film encoder properly. As a result, carriagepart move on uncontrolled.
* Dirty film timing **** strip (Horizontal film encoder;available only ini series and above) so carriage part cannot read film encoder properly.
* Another material (such as broken paper, etc) present in carriage path, blocking carriage part from moving.
* Check if any material present in carriage path; remove (clear) it
* Check if film encoder is dirty; wipe slightly with moistened clothe.
* At last, if carriage part is faulty you need to replace it.
Hope this will be helpful for you. Best regards,
Source:
Dec 18, 2008 | Canon i80 InkJet Printer
Cartridge error
Step one:Clear any paper or carriage path obstructions
Right-click the link below to open a new browser window with specific instructions about how to clear paper jams. When you have completed the instructions for removing a paper jam, return to this point in these instructions to continue resolving a carriage stall. Click here for information on resolving paper jams.
Moving the carriage
With the all-in-one turned on, open the print cartridge access door. The print carriage might try to come to move into the access area. Allow it to move to that position if it does.
Without turning off the all-in-one, disconnect the power cord from the back of the all-in-one. The power cord must be disconnected to allow the parts to be moved by hand and to reset the paper feed mechanism.
Looking in through either the print cartridge access door or the output paper tray, verify that the print cartridges are locked into the carriage and have not come loose. Also verify that there are no obstructions under or around the carriage to block it from moving.
Verify that the print carriage can move freely across the width of the all-in-one by gently pushing the carriage to the left and then to the right. Clear any obstructions found.
You may have to reach through the output paper tray to access the print carriage.
Close the print cartridge access door and reconnect the power cord.
Press the On button to turn on the all-in-one.
Print the self test from the menu to check the functionality of the product by following these steps:
*Press Setup , press 2 , and then press 6 in sequence. (The printer should be in ready mode.)
If the self test printed in the step above, then try to print from the computer to see if the issue is resolved.
* If the issue is resolved , you do not need to continue with the rest of the instructions on this page.
* If the issue is not resolved , continue to the next step.
Step two: Plug the product directly into a wall outlet
Verify that the product is properly connected to a suitable power source by following the instructions below.
Verify that the computer and the all-in-one product have a three-prong power plug.
Remove the product cable from any power strips or surge suppressors, and plug it directly into a grounded (three-prong) wall outlet.
Try the print job again to see if this step resolved the issue.
NOTE:If the product prints when plugged directly into a wall outlet while disconnected from any power strips or surge suppressors, the power strip or surge suppressor may not be allowing sufficient voltage to reach the product.
Step three: Ensure that the control panel faceplate is installed correctly
If the control panel faceplate, or bezel, is incorrectly installed, the product may indicate a false carriage stall or carriage jam error condition. If the product has not been set up before, make sure the control panel faceplate is installed correctly by following the instructions below.
If the control panel faceplate is already installed, and your printer has been working for some time, do not attempt to re-install the faceplate. Press firmly on the faceplate to ensure proper installation of the faceplate adhesive or pins.
NOTE:If the control panel faceplate is already installed, proceed to the next step.
Attach the front panel covers.
Align the faceplate over the buttons on the top of the HP All-in-One.
Figure 1: Aligning the faceplate
Snap the faceplate firmly into place.
Comment by technotech, posted on Nov 01, 2008 72a068b.gif Figure 2: Attaching the control panel faceplate
Make sure all the buttons can move freely.
Step four: Perform a partial reset
A partial reset will return user settings to factory defaults. On some models, language and country/region settings are also reset. Perform a partial reset of the product by following the instructions below.
With the unit turned on, unplug the power cord from the unit.
NOTE:Do not do a partial reset when the printer is turned off.
Press and hold # and 3 while plugging in the power cord.
When Part.NVM Reset displays, release both buttons. The unit gets reset and comes online.
Step five: Remove and re-install the print cartridges
Improper placement or installation of the product's print cartridges can cause the product to indicate a carriage stall error condition. Ensure that the cartridges are installed correctly by following the instructions below.
Turn on the HP Officejet, and open the print-carriage access door.The print carriage will move into the access area.
Figure 3: Opening the print carriage access door
After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot.285fc74.gif
Figure 4: Removing the print cartridge
1 - Print cartridge slot for the tri-color print cartridge
2 - Print cartridge slot for the black and photo print cartridges
NOTE:It is normal to see ink buildup in the print cartridge slots.
Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
Close the print cartridge access door.
Step six: Service the printer :- If you have completed all the steps listed above and are still experiencing a problem, service the product.
Nov 01, 2008 | HP Officejet 5610 All-In-One InkJet...
DISK WON'T LOAD, TURN ON AND ALL THE LIGHTS CONSTANTLY BLINK
Clear any paper or carriage path obstructions Right-click the link below to open a new browser window with specific instructions about how to clear paper jams. When you have completed paper jam removal instructions, return to this point in these instructions to continue resolving a carriage stall. Click here for information on resolving paper jams (c00095617).
  1. With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
  2. Without turning off the product, unplug the power cord from the back of the product. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
  3. Looking in through either the print cartridge access door or the output paper tray, make sure the print cartridges are locked into the carriage and have not come loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving.
  4. Make sure the print carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found. You may have to reach through the output paper tray to access the print carriage.
  5. Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
  6. Press the On button to turn on the product.
Plug the product directly into a wall outlet Follow these steps to make sure that the product is correctly connected to a suitable power source.
  1. Make sure that the computer and the HP All-in-One both have a three-prong power plug.
  2. Remove the power cord from any power strips or surge suppressors, and plug it directly into a grounded wall outlet.
Perform a partial reset A partial reset will return user settings to factory defaults. On some models, language and country/region settings are also reset. Perform a partial reset of the product by following the instructions below.
  1. Unplug the power cord from the unit.
  2. Reconnect the power cord into the unit.
  3. When the lights begin to flash, press and hold the On/Resume and Paper Size buttons.
  4. When only the On/Resume light is flashing, release the buttons. When the On/Resume light is steady, the reset is complete.
  5. Try the print job again to see if this step resolved the issue.
    • If the issue is resolved , you do not need to continue with the rest of the instructions on this page.
    • If the issue is not resolved , continue to the next step.
Remove and re-install the print cartridges Improper placement or installation of the product's print cartridges can cause the product to indicate a carriage stall error condition. Ensure correct installation of the print cartridges by following the instructions below.
  1. With the printer plugged in and turned on, open the cartridge access door (see the illustration). After a moment, the print carriage should come to the center. The print cartridge carriage is the plastic part that holds the print cartridges. When the carriage is at the center of the access area, unplug the printer.
  2. Remove the cartridges from the carriage and check them for damage. Check for obstructions under and around the carriage. Replace any damaged cartridges.
  3. Reinstall the print cartridges.
    • The black or photo cartridge goes on the right.
    • The tri-color cartridge goes on the left.
  4. Close the cartridge access door, plug the printer back in and turn it on.
Service the printer If you have completed all the steps listed above and are still experiencing a problem, service the product.
Oct 30, 2008 | HP PSC 1315 All-In-One InkJet Printer
I cant get my printer to print
Moving the carriage
Oct 27, 2008 | HP Officejet 5610 All-In-One InkJet...
"Clear carriage jam" persistent error...
I understand that you are receiving Carriage jam error.
Please follow the below given instructions to get the issue resolved.
Here is the web document:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00309142&cc=us&lc=en&dlc=en&product=90809&dlc=en&lang=en
Just copy and paste the entire link into the Internet browser's address bar and press enter.
Please remove the All-in-One Printer from the Power Surge Protector and plug it directly into a wall Power outlet, as the surge protector may not provide enough power to printer.
Let us power cycle your All-in-one to remove any static electricity in your All-in-one.
Please perform the step given below to power cycle the unit after removing the print cartridges from the printer:
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the USB cable from the computer.
2. Wait 30 seconds.
3. Plug in the power only
4. Repeat steps 2-3 two more times.
5. On the third time after plugging the unit into power, reconnect the USB cable from the all-in-one to your computer.
Please try installing the below patch and check for the result:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-14037-3&lc=en&cc=us&dlc=en&product=90809&os=228&lang=en
If the issue persists, try resetting the All-in-one to factory defaults by following the below given instructions:
Note:
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold Cancel and the Right Arrow while plugging in the power cord.
Continue holding until it displays S Full Reset message in the front panel of the All-in-One.
This should resolve the issue.
Regards,
Lawrence
Feb 08, 2008 | HP PSC 2175 All-In-One InkJet Printer
Print head jam
Iv'e seen these problems a 100000000 times with this printer and I found a little article you may wanna read before going farther with this machine!!!! Go to http://.i18nguy.com
Apr 19, 2006 | Epson Stylus C80 InkJet Printer
21 people viewed this question
k24674
