Question about Garden
Change mower blades masport president 4000 - Garden
3 Suggested Answers
  • 54 Answers
SOURCE: how do I undo the bolts holding the blades on my
The easiest way is with an impact wrench. If you don't have one there is usually a hole in the disc where you can insert a screw driver to lock it from turning.
Posted on Dec 05, 2009
  • 1116 Answers
SOURCE: how to remove the blade from the Masport lawn
There is a nut in the center of the blades. The easiest way to remove this nut is with an impact wrench. If you don't have one there is usually a hole in the disc where you can insert a screw driver to lock the blade from from turning and you will need a long handle ratchet in order to give enough torque to remove the nut. Once the nut is removed, the blade will slide right off. If you are doing this to sharpen the blades, you do not need to remove the blade to do this. Use a 1/2 HP grinder wheel and just evenly slide the wheel down the blade until it is sharp. CAUTION: it will cut you finger. Make sure you disconnect the power and the fuel is turned off at the time you do any of this work....
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Posted on Jun 09, 2011
Masport series 20 mowing uneven
check /replace blades
level up the mower deck
the blades have to be parallel to the ground so if wheels are worn or the deck tilts in any direction the cut will be uneven
Feb 03, 2017 | Garden
I have a masport 300/4 mower with swing blades,the bolt turns when I undo nut. There is no way to hold the bolt.any suggestions.Phil
the carrier plate bolt holding slots have flogged out
did someone fit the wrong blade bolts ?
need to take the whole lot off and replace it
Oct 26, 2016 | Garden
My masport mulching lawnmower making a clunking sounds when it's going
Blades could be hitting dead grass under mower deck,or the blade is loose !
Feb 22, 2015 | Garden
I have had my Masport mower serviced plus new blade but it dose not cut the grass
What is the problem?? Is there not enough power or does it run okay but just not cut the grass in which case maybe the blade in upside down.
Oct 12, 2014 | Garden
Masport mower
few things to check fuel lines are connected properly one may have gotton losse offf or pinched then make sure the blades are in off position some its a lever or a pull/push switch and battery may have gone dead or distributor to spark or plugs
Apr 13, 2014 | Garden
Looking for a Handbook/Manual for a Morrison 16in.Reel Mower about a 1979 or 1980 model.Can anyone assist.
The mowers are:
Model 400 (3.5 hp Briggs and Stratton)
Model 500 (Honda GX160)
Model 660 (Honda GX160)
I do not have the manual your looking for but the part number for the owners manual is
031796
You should contct these folks to order a manual:
HEAD OFFICE - NEW ZEALAND
Masport (NZ) Ltd
P.O. Box 14-349, Panmure
Auckland 1741
New Zealand
Phone: ( 064 )( 9 ) 571 1200
Fax : ( 064 )( 9 ) 571 5864
Website : www.masport.com
Email : sales@masport.co.nz
PARTS manual is here:
http://www.masport.com/LinkClick.aspx?fileticket=xZ1hKEx%2FYSc%3D&tabid=655&mid=1460
Thanks for choosing Fixya,
Kelly
Jan 05, 2011 | Garden
How do I undo the bolts holding the blades on my Masport 400 mower? When I try the disc holding the blades just keeps rotating.
Dec 02, 2009 | Black & Decker Lawn Mower Replacement...
Blades on Masport Ride-on won't disengage.
Yes sir assuming that all parts are origional. 9 times out of 10 its a rusted up idler arm. Remove the rust and grease up the idler arm bushings. Lubricate all other pivot points with machine oil or wd40.
Nov 21, 2009 | Garden
Masport Lawnmower won't start
you likley will need a new air filter and a carb cleaning. when mowers are turned on their side. oil will seep past the piston and if your intake valve was open it can pass thru into the carb and also spoil your air filter. I am assumeing you have a paper air filter. start by taking off your air filter. then you should also pull the spark plug, place a rag covering the hole. then pull the cord a couple times. chances are that you will blow the oil out of the cylinder.
Mar 31, 2009 | Garden
Garden Logo
110 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
