Question about Visonic Powermax Security and Management System
I want to hook up an siren to a Visonic POWERMAX system, and was wondering if I can use that as an external doorbell as well
No details are given in the user/installation manual, and no details in the programming manual either. So: anyone out there that has an external siren installed and hears a ding-dong when the door opens? I suppose the siren will sound when an alarm is triggered, but... what if that alarm is also triggering a doorbell in the 'alarm off' state, any sound coming from the siren? Thanks everyone
The kit includes a line plug with 2 screws for wires. assuming it is a phone wire that is to be used which of the 4 phone wires should be inserted into the line plug.
Usually the green and red, but best way to find out is pop the phone port box where you land line comes into the house, and check to see what wires are used. Some countries use 2 wire systems others use 4
Feb 16, 2015 | Visonic Security Systems Visonic POWERMAX...
My doorbell and intercom are not working
I would suggest contacting ADT and tell them about what he did, and what problems have happened since that time and have them come back to correct them. This sounds like the repair person is not fully experienced with the work he did.
May 20, 2014 | Cyrex Networks Cyrex EX-320H bw expansion...
I have a Ge Simon Xt Alarm and i want to hook up a external siren(part 13-950)I received a 4.7 resister with the siren and 50 ft of wire.How do you attach the resister between the red and black wire?Do...
Wire nuts are ok if the siren is indoors. Gel filled connectors are better if you are mounting the siren outside because they keep the connection from corroding. The resistor needs to go between the two wires you are hooking up. The color of the wires you will are are generally red and black. If your siren has a yellow wire, you can use it instead of the red to get constant siren instead of the "whoop, whoop, whoop" sound that sirens usually make. Putting the resistor at the siren will make sure that it is supervised. That means that if someone cuts the wire going to the siren, it will alert you at the panel. If you put the resistor at the panel, nothing will happen if the wire is cut.
May 19, 2011 | GE Security Simon 3 Wireless Home Security...
How can i reset visonic Powermax express
how can i reset poxermax system if i forget master installer code ?
Jan 24, 2011 | Visonic Powermax Express Home Alarm Kit
I have a Visonic Powermax and we have it install in our Church however the member that installed it no longer attends our Church and I need to reset the Installer code so that I can conduct tests and add...
I found this on the "Home Securty Store" website:
To reset the Visonic Powermax installers code to 9999
The User Code 1 will also be reset to 1111
Unplug the ac transformer and disconnect the main units back up battery then flip it over and find the pins labeled "DEF" on the circuit board. Lower right side of circuit board.
You'll need to short the two pins closest to the bottom of the powermax+ unit labeled DEF,a metal paper clip works just fine.
Have someone plug in the ac transformer while holding the short.Hold this for 10 seconds then unplug the transformer before removing the short.
Remove the short and turn the unit over, plug it back in and try 9999 as the Installer's Code.
(If the reset did not work the first time, try again making sure the short between the def points remains closed during the 10 second power up.)
Jan 22, 2009 | Computers & Internet
Visonic Powermax Security and Management System Logo
Top Visonic Home Security Experts
Gil Shultz
David Legender
David Legender
Are you a Visonic Home Security Expert? Answer questions, earn points and help others
