Question about Baby Gear
Balance beam scale
How do I weigh something on a balance beam scale?
  • 21 Answers
First, with scale empty, set all wieghts to their zero positions. Set zero adjustment so that the indicator is on zero. Place sample on scale and, working from heaviest to lightest, set each wieght to one notch less than what would overange indicator. When all wieghts have been set add the values of each wieght position.
Posted on Jan 13, 2009
How to measure 250gm dried herbs
If I needed to do that I would use a kitchen weighing scale and if the weight accuracy required was on the near-enough side I wouldn't care if the scales were old as I would weigh out 10 ounces.
If reasonable accuracy was required I would use a balance type kitchen scales with a 250gm weight.
If greater accuracy than that was needed I would ask at my local post office...
If still greater accuracy is needed you would first need a humidity controlled environment and about 24 hours for the herbs to stabilise before weighing...
Feb 24, 2017 | Health & Beauty
How do I find out the weight of my 42LC2DB television for a wall bracket
If its not on the paperwork get your bath scale have some one hold tv and stand on scale. note weight put down tv back on scale note weight and subtract,
I am assuming it's not a 60 inch, if so maybe 2 people and 2 scales
mike
Feb 19, 2016 | Televison & Video
How to calibrate seca 780
I recommend you look in your local yellow pages for a scale company. Calibration is very easy to do, but we recommend that you bring the scale to a local scale company. All unit sold by Precision Weighing Balances are factory calibrated and should provide you trouble free weighing for many, many years.
Jun 15, 2011 | Seca 780 Digital Adult Scale, 440lbs/200kg
For the Health-o-meter physician's beam scale, how do you know when it is in balance? What should you do to get it in balance?
For any scale you need to have a known weight to calibrate the scale. Try using something like a 5lb bag of flour or 10lb bag of potatoes.
On the top of the scale set the scale to whatever known weight you have on the platform and see if it agrees, if it is just slightly off, then use the adjustment screw to fine tune the scale, it will be at the end of the left side of the arm.
Dec 27, 2010 | Health-O-Meter Health o meter 402KLWH...
My health o meter doctor's scales model 230 will not balance at zero
Hi. Cldchasr is talking about an electronic scale, not your beam scale. Coachphil was helpful but inaccurate for this model. I have a 230. Use Coach's method but there is no screw on the left to adjust. Instead, use the black zero balance at the upper left. Move the black slide on the silver bar until the scale balances.
Aug 08, 2010 | Health-O-Meter 500KL Medical Scales...
If a man has 8 balls,and out of eight one ball is lighter than other seven.if he has a balance and had two chances.how will he find the lighter one??
Put 3 balls on each side of the scale. If the scales balance then weigh the remaining 2 balls and this will show the lighter one. If on the first weigh (3 balls each side) the scales do not balance- then take the three ball from the lighter side and put two on the scales (one each side) and keep hold of the remaining one. If the scales balance then you are holding the lighter ball. If not the scales will show which is the lighter ball. You can use the same logic for up to 9 balls.
Jul 06, 2010 | Computers & Internet
New Scale out of box will not weigh correctly
Take a 5 pound bag of sugar, flour or what have you. Put it on the scale. If it is off, turn the scale so that you can check every possible place for an adjustment. Adjust and go for it!!! Good luck...Lee
Jan 16, 2010 | Jobar International Idea Works Wireless...
Scale is not weighing correctly. Weighs correct
The scale must be on a hard, level surface. Make sure there is absolutely no dirt on any of the pivot points. Calibrate it with a KNOWN 25 pound weight.
Jan 04, 2010 | Health-O-Meter Health o meter 402KLWH...
Does anyone know how to do #6
Step 1) Load 3 weights on to each side of the scales. If scales balanced, then weigh the 2 weights that you left off in step 1.
If scales uneven, remove the 3 from the heavy side and then weigh 2 of the 3 from the lighter side, if balanced it's the 1 weight you didnt weigh.
Hope this helps,
Dec 29, 2008 | Nintendo Professor Layton & the Curious...
Baby Gear Logo
118 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
