Question about RoadPro Digital Compass Inside_Outside Temperature Voltage Meter and Ice Alert
TEMPERTURE HOW DO I CHANGE THE DISPLAY SCREEN FROM CECIUS TO F?
On the bottom where the backup battery is located, open this up to reveal the battery and the switch is located there. Hope this helps!!
Posted on Feb 22, 2012
How do I change temperature reading from cecius to fahreenheit?
Is there a button marked ?C/?F: ?
26222988-lkq3pofalwofyawnl3ngt3yc-5-0.png ?C/?F:
Press and release the "?C/?F" button to switch between Celsius and Fahrenheit mode.
Jun 21, 2016 | Acu-Rite Acurite Wireless Indooroutdoor...
2003 Lincoln Navigator, I cleaned my center console panel (AC/Heater control knobs) because of sticking buttons now the buttons (Auto, Off, Dual, etc) does turn on or off AC/Heat, nor does the display...
shudnt hav done that-u caused corrosion--now u need to take um out and see if their salvagable--getta haynes manual or sec629-ur local library
Nov 20, 2013 | Lincoln Cars & Trucks
My Frigidaire PHSC239DSB2 side by side's digital temperture display is flashing a 2 on the freezer side & the fresh food sides temperature went up to 47 degrees, but has no flash. What is goin
HI this is a difficult one without a visual but i would sugest u disconnect the power supply.re-connect everything again and re-start.reset temp if not pre set.and try before u call an engineer.good luck.Ali
Jun 18, 2012 | Frigidaire FRS26H5AS Side by Side...
Where is the temperture control system
some model has not display temperature control system.
You must see your instruction manual for indicate how to control the temperature. if you do not have download www,fitness.manualsonline. com or www.retrevo.com or www.manualsfactory.com
God bless you
May 09, 2012 | 2005 Chrysler 300 Hemi
My 2007 Chevy HHR 2.2L, coolant temp sensor is reading that the coolant temp is 20 degrees warmer than the outside temp after sitting for over 12 hours and the operating temp gets to 214 degrees without...
Sure the engine coolant will be warmer than the outside temperture and if the car has been sitting a long time in cold weather and the outside temperture warms up it could be the other way around. The coolant temperture sensers aren't real accurate as they are a relaitive senser beween hot and cold and the numbers reported don't have to be real just the change from hot to cold and the reching of the coolant to the operating temperture. Noe it the senser doesn't read the opertating temperture coprrectly you'll have all kinds of problems. The therostaste will try to set the temperture of the water to it's set temperture and can open or close completly to get 195 degrees F. Many times if it's too cold then the stat is bad and needs to be replaced This shows up in alot of cars first thing after winter and the first onset of cold weather when the daily tempertures vary the most from day to night.
May 06, 2011 | 2007 Chevrolet HHR Special Edition
How do you program this heater
temp setting
1. press the temp/timer button untill the temp icon blinks
2 use up and down arrows to set temp.3 the temperture icon will stop blinking and the current room temperture will appear after desired temp. is set.
4 the heat will turn off shortly after the desiredtemp. is reached and the temp. ndisplay will blink.
5 the heater will turn back on when room temperture drops below the set temp.
timer : auto -off press the temp/time button untill timer icon blinks. the hour display will apear. the auto off icon will also appear.
2. use up and down arrow buttons to set the heater operation time between 1 and 10 hours. this function will activate once the timer icon stops blinking.
3. the heater will automaticly turn off when time runs out.
set temperture first so heater will cycle on and off till shut down time reached
Feb 02, 2011 | Comfort Zone CZ9009 Oil Filled Electric...
How to change the thermosat sensor becuase no have reading the temperture in the dask display
follow the uper hose to the eng and it should be right there where there with wires going to it
Jan 18, 2011 | 2000 Daewoo Nubira
I need to know how to change the temperture from celcius to farenheite
press and hold PRECISE CLEAN for 5 seconds, a tone will sound and c or f will appear on the display. repeat to change back. to exit press CANCEL/OFF
Dec 17, 2010 | Whirlpool RBS275PD Electric Single Oven
Freezer and Fridge at wrong temperture
How old is this fridge? Your themostat may be shot. Put an accurate thermometer in the freezer and cooler to ge the real reading. If they are the same as on the door then the themostat is probably the problem. If not, it could be that all you need is a new display.
Dec 17, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
RoadPro Digital Compass Inside_Outside Temperature Voltage Meter and Ice Alert Logo
41 people viewed this question
Top RoadPro Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a RoadPro Boating Expert? Answer questions, earn points and help others
