Question about LG 60PC1D 60 in. Plasma Television
LG60PC1D-UE TV will not turn on.
Opened back and found 6 blown capacitors on the EAY32961901 power board. Had already ordered the EAY32961801 power supply (which is the board listed in previous strings) but the capacitors appear good on the one in the TV. Do I need to replace both boards or can I only replace the 1901 (don't want to mess with soldering capacitors)?
    Top Expert:
  • LG Master
  • 73,710 Answers
Hello
If you have the new power supply board, just replace it. But 1901 and 1801 looks different to each other.This is the picture of the 1901.An this board the sub power board.LG60PC1D-UE TV will not turn on. - 2_11_2012_10_30_19_am.jpgThis is the picture of 1801. Both boards are entirely different to each other. How can it be repalced? 2_11_2012_10_33_23_am.jpg
Posted on Feb 11, 2012
LG LED TV no sound or pictures
If you have already been inside of the back circuit board area, make sure that you don't use any type of magnetic screw drivers or any thing that can statically discharge a capacitor etc. Next since you say there are 3 boards present,the board, you are looking for is the power board.How to identify the correct one, follow the AC cord from the plug into the board that it first attaches to.That is the power board.Carefully disconnect any 6 pin or any multi pin connector and mark them for re assembly.There should be 6-8 screws that are removed then remove board.Have a very bright light on hand and carefully examine the board for any broken circuits or burnt components.If found ,go online and search eBay Amazon etc. For replacement board. Assembly is reversed order of removal.
May 19, 2016 | LG Televison & Video
I have no power to my LG 26LC55 tv
Ok had the same issue with mine, opened the unit up and found the Dark Blue capacitor had blown, the top of the capacitor had bulged out, A friend ordered some 3300 uF 10V capacitors from RS components [you have to buy them in packs of 5]
Lay the unit on a soft surface,
Undo the 4 large screws that hold the base on
Then undo the screws around the side, there is on the back as well
You will find 2 screws in the connections area
Lift the over off
The power board is located on the left hand side
Remove the power lead on the bottom of the board
Then the other cables.
Undo the 4 screws that hold the board on place
Locate the capacitor it's a blue one, run your fingers across the tops of the capacitors, if you find one that is leaking or raised that's failed
Turn the power board upside down
With a soldering iron and desolder tool, desolder the capacitor
Make note of the position of the + / - locations
Insert the new capacitor and resolder
Also check the power fuse located on the lower left of the power board
Good luck it worked just great with mine
Dec 14, 2010 | Televison & Video
BRAVIA KDL-52X2000 50 in. HDTV-Ready LCD TV: my tv turns off on its own and a red power light b...
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
May 17, 2010 | Sony BRAVIA KDL-52X2000 50 in. HD-Ready...
There's no picture, the LED light just blinks, nothing.
I opened the power supply unit, and found two blown capacitors (swollen, and oozing black stuff) It is easy to fix, if you keep track of where the screws go, because there are so many.
1) open tv, and tape screws where they go
2) open power supply unit, and check if any capacitors are swollen, and oozing black junk, even if its just a litte
3) if you find blown capacitors, look on the back of the board, and find out what hole, or socket the leads go into, they all have a number.
4) with a DEsoldering gun, remove the solder from back of board, its easy, trust me. I'm no tv repair man, but even I could do it.
5) write down how many microfarads the capcitor(s) are, and the corresponding hole number.
6) find replacement capacitors online, and solder back into psu
7) re assemble tv, and enjoy.
Nov 02, 2009 | Toymax Magnavox 37MF331D 37 in. LCD TV
61" plasam TV will not turn on
This is one of two problems, Bad capacitors in the power supply or your Y Sustain board has failed, I would go for the first, take the back off your tv and look for swollen or domed shaped capacitors on the power supply, They may also leak a brown liquid like substance.
Replace all that you can see and this should cure the fault.
Oct 12, 2009 | LG 60PC1D 60 in. Plasma Television
Tv turns off by itself
Solutions?
Hope this helps
Apr 07, 2009 | JVC LT-32P679 32 in. LCD TV
Philips 42PF9630A/37
I have the same problem, except with a Philips 50 inch model 50PF9631D/37, except mine sometimes does 6 long flashes and 3 short. Here is what I found, after MUCH online and other research:
It is probably the Power Supply board. One other indicator that it is the power supply board is that if you unplug it for a minute or so, and then plug it back in, it might start up and stay running until you shut it off again (that is what mine would do). Mine eventually would not come back on after repeated unplugging. I have learned that the reason for this is leaking capacitors on the Power Supply Board. If they are really bad (like mine eventually were), the TV will not come on at all. The reason it will stay running once it is going is that there is a separate set of circuitry for the TV once it is going.
I UNPLUGGED my tv and waited 1 hour (for capacitors to hopefully discharge), and then opened up the back of the TV (all you need is a "Torx" (also known as star-head screwdriver, with 2 different sized bits (buy multiple bits if necessary, they are cheap and I don't remember the sizes).
PLEASE NOTE: Even unplugged, TV's have capacitors which store large amounts of electricity which can discharge quickly and kill you. Be very careful. One website suggested wearing special, high-voltage rubber gloves.
The Power supply board is the big computer-looking board in the center. I stared at mine for 15 minutes and was able to notice 2 capacitors with slightly bulged tops. I have learned that this is a common problem with these boards. All you need to do to remove the board (at least with mine) is to carefully (there is a little clippy thingy on the bigger ones) unplug the wires connected to it, and unscrew the screws holding it in with a phillips-head screwdriver.
I was able to find a replacement board at various places on the internet, but the best was BestBuyParts. I found they had 1 Original Board for mine for $300, an updated replacement for $300, and a refurbished replacement for $205. I ordered the refurbished one and will let you know my success when I get it. Interestingly, the original board was made by Samsung!
Interesting side note: I tried to simply replace the $1.00 capacitors on the board to save money, but they are REALLY hard to find. I finally found that the original capacitors, made by Samwha, are no longer sold as 105 degree celcius capacitors, but are now listed as 85 degree capacitors, and their 105 degree replacement is now back-ordered. I have also ordered approximate substitutions, to see if I can save the old board. Bottom line: It looks like Philips bought the board from Samsung, who got some bad capacitors from Samwha, and we all pay the price.
Finally, check to see if there is a recall. 12,000 Philips TV's with Ambilight have bad capacitors which are sparking and have been recalled. I doubt it is related, but I bet I know who manufactured those bad capacitors.
Nov 19, 2008 | Philips 42PF9630A 42 in. Plasma Television
A reset switch?
Wait until the power comes back on? Plug the TV back in? The obvious solutions are usually the best.
Sep 02, 2008 | RCA L26WD26D 26 in. LCD TV
TV shuts off within 5 seconds of turning on
Solutions?
Hope this helps
Feb 15, 2008 | Sony KDF-E42A10 42 in. LCD Television
LG 60PC1D 60 in. Plasma Television Logo
480 people viewed this question
Computer Repairing
Computer Repairing
