Question about Car Audio & Video
How do i hook up a radio shack MPA - 35 WATT P.A. AMP to my stereo
Draco
SOURCE: when i turn my radio up all the way my speakers cut out and then come back on
i soundds like its too powerfull for them beouse some new speakers now have a shut off if they are ready to go out or blow to make sure you dont damage them
Posted on Jan 15, 2007
lynchms
  • 93 Answers
SOURCE: can't get my Accurian subwoofer to work
OK if you came out of the receiver sub pre-out RCA jack into the subwoofer RCA jack ( most subs call this low level line in) and no sub sound you may need to program the receiver to tell it that a subwoofer is being used, many receivers have this function, and some default it to NO SUB and them your low end soung goes to the front right and left speaker, so check the receiver manual and look under adding a subwoofer instructions if available.
Posted on Jan 29, 2009
petraman7
  • 1175 Answers
SOURCE: user manual for 40 watt pa amplifier (32-2054)
http://support.radioshack.com/productinfo/DocumentResults.asp?sku_id=32-2054&Name=PA%20Amplifiers&Reuse=N
Posted on Apr 01, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: Realistic MPA-35 amp by Radio Shack
It's not that this amp isn't like "newer amps" with + and - terminals, it's that this amp is made for public-address system use. This kind of amp is used in a store, for instance, to pump background music through speakers all over the place. The terminals you connect to are determined by total impedance of the speaker configuration used.
Most single speakers, or the two- or three-way cabinets for home stereo systems, are 8 ohms. If you're connecting a single speaker you use the "common" and "8 ohm" terminals on the rear panel. With multiple speakers, you need to figure out the total impedance and use the appropriate terminal. In series, impedances add. Two 8 ohm speakers in series would total 16 ohms, so you use the common and 16 ohm terminals. In parallel, the total impedance drops. Two 8 ohm speakers in parallel total only 4 ohms. You need to figure the total impedance of the speaker configuration and connect accordingly. Too great of a mismatch will damage the amp or speakers or both.
You might be able to find the manual for this amp on Radio Shack's website. Here's a link to the manual for the model MPA-40 which should have similar output terminals. The basic information about figuring out total impedance and general use of PA amps applies to your amp as well.
Posted on Jun 16, 2009
  • 219 Answers
SOURCE: I NEED A DIAGRAM TO HOOK A NEW PLUG FOR A RADIO
we need to know what kind of mic are you hooking to it?
Posted on Jan 01, 2010
Hook up sound to a sony ps-lx340
try a RADIO SHACK SA-155 MINI AMP at Radio Shack. I believe around $30.00. Use the amp many times.
Nov 28, 2014 | Sony Ps-lx320 / Ps-lx340 Stereo Turntable...
Big finals and how to install them for radio shack trc-447
It doesn't make a difference how big your final is the radio will not except it. What I'm saying is if you install a 100 watt final into it ,no matter what you will only get a max of 25 watts because the radio cannot handle the 100 watt load.No if you start changing components inside the radio to obtain the 100 watts you are now in violation of fcc rules , unless you are a licensed tech , if you were then why are you asking this question. The best thing to do do is get a 100 watt amp and hook it up. you will be smoking the neighborhood.
Aug 28, 2013 | Radio Shack TRC-447 CB Radio
What is the headphone jack size of the fender sp-10 10 watt amp
Call your local stereo store. These items are very standardized.
There are 2 standard sizes for headphones. the one for PCs and phones is the smaller size. An amp or receiver probably take the next size up. If you screw up and get the wrong size someone like Radio Shack or the like will have an adapter that sells for a buck or 2.
Jul 03, 2012 | Fender Sp-10 Electric Guitar Amp 10 Watt
My stereo in 1997 chevy caviler is turning off and on when turned up to a high volume. I have a sony xplod 52 watt by 4 channel radio. With two 6x9 sony xplod 50 watt rms and 300 watt peak power in the...
Most likely cause is heat. The clearances behind the radio are often not sufficient to provde the proper air coolling that the higher power radios need. The heat sinks on the rear of the radio require a certain amount of air flow to dissipate the heat generated under high load conditions. If you add summer heat to the equation, you can have the radio going into thermal cutout to protect it circuity.
May 27, 2011 | 1997 Chevrolet Cavalier
Looking for manual Realistic MPA-40 35W
I have a realistic mpa-40 35 -watt pa amplifier owner's manual
cat, no, 32-2032A
You can conyact me @ ltlerock@aol.com
Jan 03, 2010 | Audio Players & Recorders
Jun 16, 2009 | Audio Players & Recorders
Need diagram to hook up stereo system. alpine amp and stereo
go to radio shack for installation kit and diagram
Mar 20, 2009 | 1999 Land Rover Discovery
External amp with 901" eq
BUY A SHERWOOD STEREO RECEIVER 100 WATT PER CHANNEL AT RADIO SHACK WHICH HAS A TAPE LOOP FOR 901'S AND A TURNTABLE INPUT ALSO. COST $100.00.
Jan 14, 2008 | Bose 901 VI Main / Stereo Speaker
Car Audio & Video Logo
29 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
