Question about Briggs & Stratton Garden
I bought an Ariens, model #921031 Deluxe 24 with a Briggs & Stratton engine brand new online and haven't used it yet. It's been sitting and now I have a puddle of oil under it. The place t
921 series snow blower- Ariens with a Briggs & Stratton engine. Model # 921031- Deluxe 24, serial # 001566
  • Briggs & Str... Master
  • 2,478 Answers
Some times, the seals not sealed yet not being run. Check all your oil and gear oil levels and run it. Hope everything will be ok then.
Posted on Feb 15, 2012
  • 48 Answers
SOURCE: 5 hp Briggs and Stratton snow blower
easest way is to remove shutoff wire from coil and then see if you have spark - if this is a point system it prob needs points and condenser
Posted on Oct 21, 2008
  • 18 Answers
SOURCE: wanted briggs and stratton 92908 manual
Find the B&S website and you should be able to download a parts or service manual.
Think it is briggsandstratton.com.
You will also need your type number (after the 92908).
Posted on Apr 18, 2010
  • 402 Answers
SOURCE: kids broke pull cord
Remove the entire housing and do not drill the rivets unless you can replace them with the same size.
Posted on Jun 07, 2010
rycgl
  • 1545 Answers
SOURCE: My briggs & Stratton star but they don not
Remove the brass bolt holding the carburetor bowl on and clean it real well. It has some very small holes in it that carry gas up to the carb and may be partially or completely clogged, causing your problem. All holes must be clear.
Posted on Jun 13, 2010
hunter19_46m
  • 7482 Answers
SOURCE: Briggs & Stratton Model 92502 3.5 HP Engine with
Hi hjconn...
Sounds like you have dirt/debris in your carburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
NOTE: Before you dissemble the carburetor:
Make sure you mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you dissemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Also check you fuel line condition after a while they will degrade and need replacment.
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting fire at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope, if you are getting spark then:
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on Jun 25, 2011
13 HP briggs and stratton intek motor on a pull behind weekend warrior brush cutter
Manuals - Briggs & Stratton
https://www.briggsandstratton.com/us/en/.../manuals
Briggs & StrattonFind Briggs & Stratton manuals online by selecting your lawn mower or product type &engine model number. Never worry about losing an owners manual ...
Sep 10, 2015 | Measuring Tools & Sensors
Crafsman 2400 watt generator star ok but only run for 45 sec.& it won't star again the motor is a briggs & stratton 5.0hp
I have a Craftsman Snow Blower with a Briggs & Stratton Engine. I had the same problem. I searched online and read a little bit about this run and stop problem. One solution was to put something over a piece of metal that separates the hot engine part from the other part of the other side of the engine. I used a piece of heat resistant cloth from Lowes in the plumping area where the torches are. It fit and worked. Engine keeps running. I ran it for over an hour last spring prior to storing it.
Nov 01, 2012 | Electrical Supplies
Brand new Briggs & Stratton lawn mower Model 90000 E series won't start.
trry a shot of starting fliud see if it wont start then make sure your getting a spark to
Jun 13, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
Ariens 1640 Zoom Riding Mower with Briggs & Stratton engine smoking
check to see if the oil smells like gas the needle valves go bad in the carb and gas over flows into the crank case also the head gaskets go bad and **** the oil from the crank case
May 08, 2012 | Ariens Garden
Want to repower an ariens model 10M6d snowblower engine. Is there a replacement engine I can use?
Go to small engine warehouse. There is an button on the top, repower old equipment. They have a few briggs & stratton engine options there.
Jan 17, 2011 | Ariens Garden
Where is the spark plug located on an Ariens Sno-Thro compact?
I am assuming this is a 22 or 24 inch model. The engine is an overhead valve design and the spark plug is buried on the left side of the motor (looking at it from the handles) You should be able to see a large black wire going into the engine. Depending on the engine make it may have a rubber cover or just plug wire covering the plug.
On this page are pictures showing the location of the spark plugs on Briggs & Stratton engines.
http://www.briggsandstratton.com/engines/support/frequently-asked-questions/Identifying%20the%20correct%20spark%20plug%20and%20gap.aspx
The OHV horizontal shaft engines are about half-way down the page.
Feel free to ask any other questions. I know Craftsman Snow Blowers. Please remember to rate this answer!
Jan 13, 2011 | Ariens Garden
New 24 hp B&S engine running out of fuel
There is a restriction somwhere before the fuel filter, this is assuming gravity feed and there is no fuel pump for the engine.
Jun 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
WE NEED A MANUAL FOR BRIGGS & STRATTON ENGINE FOR A ARIENS SELF PROPELED LAWN MOVER
ok here is a link to get you to search for the correct model. should find it here. if not do a google and put 'Briggs and Stratton model XXXX manual' search.
http://lawnandgarden.manualsonline.com/manuals/mfg/briggs_stratton/190477gs.html
AndystUK
Sep 02, 2009 | Garden
What kind of oil for a husqvarna riding mower?
Yes SAE 30 is the recommended oil for B & S engines. You can find it on amazon for good price. here: Amazon com oil 30w . Hope this was helpful. cheers
Jun 14, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
301 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
