Question about HEWLETT-PACKARD B210a AllInOne InkJet Printer
Hp b210a reset ink level - HEWLETT-PACKARD B210a AllInOne InkJet Printer
HP Photosmart B210a error message
Simple. Remove the ink and printhead. You can remove printhead by pulling gray latch up and sliding printhead up and out. Clean printhead gunk off using warm running water. Remove any ink gunk on the right side of printer if you see any. Turn printer off and on. See if problem went away. If it did, try putting the cleaned printhead inside printer again. If problem comes back, seems like the issue is with a bad printhead. Below are video instructions on cleaning head manually. The printheads are not same. B210 printhead is not the same with HP 6500, but instructions are same.
Jun 07, 2017 | HP DeskJet F4280 All In One Printer InkJet
Hp b210a error
plug the printer directly to the walloutlet.... then unplug the printer from the back of the printer without turning off the printer.... then press and hold the power button for 30 sec and then plug in the power chord... check if it works...
if it does not then do a reset on the printer...touch the control panel 4 times in this order - Bottom-Left (BL)/ Top Left (TL)/ BL/ BL until Support Menu displays on the control panel, and then touch OK >> Resets Menu > Semiful Reset.
the printer was turn off... then again press the power button to turn it on.. check if this works
This should work for you.
Aug 29, 2012 | HEWLETT-PACKARD B210a AllInOne InkJet...
HP C309a Photo Smart Premium how to reset ink level
I don't think so its resets though printer, now a days counter re setter devices are available, using the device you can resets the counter of cartridge memory..
Feb 03, 2012 | HP Photosmart Premium C309A All-In-One...
How do i reset ink levels on a new hp 6500a printer, is there any1 who actualy knows ????
what do you mean by resetting the ink levels? to know how to get the estimated ink levels of your printer?
May 30, 2011 | HP Officejet 6500 Wireless All-in-One...
How to reset the ink level of my hp officejet 6500
Checking ink levelsUse one of the following methods to check the ink levels. Method one: Check the ink levels from the HP All-in-One The ink level is displayed on the main screen of the control panel display. Locate the two icons that represent the print cartridges. The icon on the left is for the color cartridge and the icon on the right is for the black cartridge.
  • The exclamation mark (! ) symbol indicates a low ink level.
  • The question mark (? ) symbol indicates the product cannot determine the status of the print cartridge. This might be because the cartridge is refilled.
Figure 1: Ink levels on the control panel displayc01362755.gif 1 - Exclamation mark indicates low ink in the color cartridge 2 - Ink level in the black cartridge is OK Method two: Check the ink levels from the computer using the HP ToolboxFollow these steps to check the estimated ink levels using HP Toolbox.
  1. Make sure the product is on and connected to the computer.
  2. Open HP Solution Center .
    • Windows XP: On the Windows taskbar, click Start , click All Programs , point to HP , and then click HP Solution Center .
    • Windows Vista: On the Windows taskbar, click the Windows icon (c01364735.gif ), click All Programs , click HP , and then click HP Solution Center .
    • Windows 2000: On the Windows taskbar, click Start , click Programs , point to HP , and then click HP Solution Center .
  3. Click Settings .
  4. Point to Print Settings , and then click Printer Toolbox . Printer Toolbox opens.
  5. Check the ink levels displayed on the Estimated Ink Levels tab.
Figure 2: Estimated ink levelsc00670267.gif
Jun 02, 2010 | HP Officejet 6500 Wireless All-in-One...
Reset ink level on hp 6310 #98 cartridge I have been using refilled cartridges and the in level is ''empty'' even when the cartridge is new and just filled. how can I reset the ink level?
if you are using a refilled catridge you would not get ink levels right.
if you want right ink level use genuine ink catridges.
you can try taking out the catridges turning off the printer and turning it back on and then reinstalling the catridges.it might not help so if possible buy hp ink catridges.
Aug 27, 2009 | HP Officejet 6310 All-In-One InkJet...
Deskjet f4185 reset ink level...
for colored is only 3ml and the black is 8ml
Aug 03, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
HEWLETT-PACKARD B210a AllInOne InkJet Printer Logo
361 people viewed this question
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Victorman
Victorman
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
