Question about Frigidaire FRT21H8 Top Freezer Refrigerator
Light switch It is my belief that the light switch for the refrigerator is over extending and stopping the door from being able to close. Any suggestions on how to fix?
    President:
  • Frigidaire Master
  • 2,651 Answers
Correct, you can either take off the refrig door and place asmall shim under the hinge raising it an 1/8 inch or soor you can slightly pry down the light switch from the liner, and fill the small gap created with a small bead of silicone
Posted on Oct 26, 2008
Dometic refregerator 2652, the inside refer. light and the check light on the front blink when i open the refrigerator door. then stops a bout 20 sec. after closing the door
Sounds like a possible loose connection somewhere that is shaking when the door is opened. Check the main plug/power connection to the refrigerator for corrosion or just looseness. The inside light is controlled by a door switch so you may have a connection problem there also.
Jul 11, 2015 | Dometic RM2652 Refrigerator
The "open door" light constantly blinks Door is fully closed.
Hello Gregg;
My name is Peter. I am a retired field service refrigeration technician.
It would be nice to have a model number. The model number. It is located on a label on the fresh food section wall near the top.
There re several different door switches. Some are mechanical and some are magnet.
Open the doo, push on the light switch. Does the light go out?
If not it is a bad switch.
Food storage problem - You food must be within the confines of the racks. If they extend beyond your door will not fully close.
Send me a model number so I can see what you have.
Dec 26, 2014 | Refrigerators
Frigidaire FFHS2612LS4 wont stop beeping
Hey Brandon, this is JK. Thank you for your post. I understand that your refrigerator is beeping none stop. When the door(s) have been opened for longer than 10 minutes, an audio alarm sounds and the interior lights shut off. This protects the liner from melting due to the heat produced by the light bulbs. The alarm will sound every two minutes until the doors are closed. Once the doors are closed, the alarm will reset. The refrigerator will also beep on some models to inform the user that the door has been left open and the cool air is escaping. Check to make certain that the gaskets on both doors have no gaps and that the appliance is maintaining the desired temperature. If all of these suggestions pan out and the problem still persist, think about what may have happened prior to this occurrence. For instance, did you notice any error codes, odors, or other strange functions prior to this issue? If you are still having these issues and can think of anything in particular, please feel free to reconnect.
Hope this helps!
Mar 10, 2014 | Frigidaire FRS3R5EMB Side by Side...
We have a Jenn-Air French door refrigerator. It's about 4 years old. It is maintaining its temperature fine. But all of a sudden, about 3 hours ago, there is a constant sound similar to a squeaky...
This is most likely a door open alarm caused by a problem with the door / light switch. Locate the light switch plunger and depress it. The light should go off. If the light does not go off the door switch has failed. The door switch is removed by sliding a thin bladed knife along the side if the switch and releasing the locking tab. The freezer door only has one locking tab on one side of the switch. The fresh food compartment door switch has 2 locking tabs on opposing sides of the switch. You unlock the tab(s) and remove the switch. The fresh food compartment door switch has 2 wires on it that close when the door is closed. The freezer door switch has 3 terminals on it. One terminal is C common. One is NO Normally open and once is NC normally closed. The NC terminal will have continuity to C with the punger extended. The NO contact will have continuity to C only when the plunger is depressed.
I think you have a bad door switch. If the freezer door switch fails the unit will stop making ice.
Thanks for choosing FixYa,
Kelly
Jul 10, 2011 | Refrigerators
I hear a noise when i close the freezer door or when i push the light switch light in
how loud is this nose. most refrigerators are designed to stop the fan when the doors are open. and start again when the doors are closed. when u push the light switch in the fan thinks the doors are closed.
Feb 04, 2011 | Kenmore Refrigerators
Refrigerater door won't close because lightswitch stays extended in on position. Door switch doesn't have food nor debris on it to prevent it from being pushed in when door tries to close.
I'd remove the light switch. IT should pop out of the side. You should unplug the refrigerator first, pry switch out. Tape up terminals. Push wires into hole where you can still reach them. Plug back in and be sure door closes. If all that works, buy a new switch and re-install
Jul 18, 2010 | Frigidaire Refrigerator Light Switch -...
Refrigerator inside light will not go out when door closes
This can be due to one of two things, either the door is not hitting the light switch when it closes or the light switch is bad.
Locate the switch, it is usually on the top of the cabinet inside the refrigerator, push the switch, if the light does not go out then the switch is bad, if the light goes out the door needs adjusted so it will hit the switch when it closes. Typically this can be done by loosening the hinges and holding the door in place while someone tightens the hinges back up.
May 08, 2010 | Kenmore Freezers
Refrigerator lights stay on when doors close
The switch and possibly the circuits may be faulty. Certainly the switch should be replaced. Test wire to circuits.
Get parts and manual and morel at repairclinic.com
Sep 14, 2009 | LG LFC21760 Bottom Freezer French Door...
What is the light switch button for in the fridge section? why does the light stay on in the fridge with the door closed when the switch inside is on ?
The switch is curved so when you close the door the light will also close.How do you know if the light is on when the door closes?Try pushing on the switch and you will see that the light will close.If that is what you are asking.If you push on the switch and the light stays on then you have a faulty switch. hope this helped:)
May 11, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Light stays on when door is closed
The GE GSL22JFPH refrigerator door gets lower over time. When it gets low enough the light stays on when the door closes. There is a vertical bolt along the hinge line. Push down the hinged plastic "hinge cover" under the door right on the hinge line and you can get a wrench on the bolt to raise the door. I have to do this every 6 months/
Jan 18, 2006 | Hoover HCA331FFK
Frigidaire FRT21H8 Top Freezer Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
