Question about Casio DR-T120 Calculator
Printer Paper
I ran out of printer paper and when I tried to reload the calculator I realized I don't know how to.. I don't see a slot to slide the paper into
  • sanmellen Nov 12, 2008
    I have a Casio DR-T120 Calculator...ran out of paper...tried to reload...your suggestion was to just close the cover....that didn't work. Is there someplace I must feed the paper to reload?
Close the cover with the paper sticking out of the cover. It then works!!! Good luck!!
Posted on Jun 26, 2009
NOT A SLOT TO FEED IT SPECIFALLY
CLOSE THE COVER TILL IT FEEDS OUT
Posted on Oct 29, 2008
Clear paper jam
1. Turn ON calculator and set the slide switch P/NP/IP switch to P position.
2. Remove the paper roll from printer.
3. Use a business card and insert into the printer slot
4. press the feed key to feed the business card to clear the paper jam
Jan 19, 2015 | Victor 1260-3 Calculator
How do i load roll paper on TI-5033II
1. Turn on the calculator.
2. Open the printer compartment cover by pressing down on its front edge and sliding back in the direction of the arrow.
3. Fit the roll of paper on the holder so that it unrolls from the bottom, with the loose end toward the calculator.
4. Cut the end of the paper squarely and insert it firmly into the printer slot on the back of the calculator. Press the paper feed button until the paper is in the printing position.
A PDF version of the manual is available at:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0CCcQFjAB&url=http%3A%2F%2Feducation.ti.com%2Fmedia%2FE152CF808E0C46759750698A1FCC970F%2F5033sv&ei=tA9EVLWbIMKcigLO-4CABQ&usg=AFQjCNF6zdaotZAIlF-6DajAVKg0UMh54w&bvm=bv.77648437,d.cGE&cad=rja
Oct 19, 2014 | Office Equipment & Supplies
How do i load my printer paper ti-5045sv
To load paper into a ti-5054 sv calculator.
  • Turn Calculator on.
  • Press down on the front edge and slide in the direction of the arrow.
  • Insert paper on the roller so that the paper rolls out toward the bottom, and the loose end is closest to the calculator.
  • Cut of the end of the paper.
  • Insert the end of the paper into the printer slot in the back of the calculator.
  • Press the paper feed button ( karmahm_0.png) until the paper is in position.
Mar 17, 2011 | Texas Instruments TI-5045 SVC Calculator
Have a texas instrument paper printing calculator used can't figure out how to load the paper
To avoid paper jams, use quality bond paper. A 2¼-inch roll of quality bond paper is included with your calculator.
1. Set POWER=ON.
2. Cut the end of the paper squarely.
3. Holding the paper so it unrolls from the bottom, insert the end of the paper firmly into the slot on the back of the calculator.
4. While feeding the paper into the slot, press up until the paper is in position.
5. Lift the blue metal paper holder so it extends behind the printer compartment.
6. Place the paper roll on the paper holder.
7. To print, set POWER=PRT or IC.
Note: To prevent damage to the printer (which may void the warranty), set POWER=ON rather than PRT or IC when operating the calculator without paper.
Feb 05, 2011 | Texas Instruments TI-5032 SVC Calculator
Printer can't feed paper from tray
You may need to clean the rubber feed roller with a damp towel, water only, or if parts are broken or missing, a new paper tray, around $20.00
Jul 20, 2009 | Brother HL-5240 Laser Printer
How to load the paper into casio hr 100T . My son just came home with this old model. It has paper provided but no instructions. How do we get the paper to feed and in what directions does it need to be...
I have a casio HR-100 TM. After spending over an hour, and scouring the casio website which had an obscure spot that covered a totally different calculator!.... I found a slot in the back of the machine that when I folded the paper into an arrow, FINALLY went in! You may have to try a few times, but it will go in just keep holding down the feed button as you push and jiggle the paper.
Jun 20, 2009 | Canon P1-DHV Calculator
Printer was printing fine ran out of paper reload paper but it will not pick up the paper now a yellow light comes on and it says load MPF letter Plain 1 024-969
I don't know this specific printer but have seen many printers mishandle the last sheet of paper causing a jam and leaving pieces behind when forcibly removed from the paper path.
You might try peering into the paper tray slot to see if there are any obstructions. Different printers use different methods of sensing 'paper out' and yours may use a mechanical flag that interrupts a photo sensor that really detects on the passage of the sheet and if this is impeded in some way, it may just think it's out of paper.
Jan 21, 2009 | Dell 3010cn Laser Printer
6122 Printer says it is out of paper and will not print test page
Hi Ken,
The user manual says this:
1. Verify the following:
There is sufficient paper in the paper tray (at least ten sheets).
The paper tray is not overly full.
The paper stack is touching the back of the paper tray.
2. Slide the paper guides so they fit firmly against the edges of the paper.
3. Press the Resume button to continue printing.
Sometimes my printer won't print if it has too little or too much paper in the slot. It's a relatively common sensor problem.
Try that.
If all else fails, here's a link to the user manual in pdf form:
http://h10032.www1.hp.com/ctg/Manual/c00044028.pdf
Good luck
Chris (ziraffa)
Dec 22, 2008 | HP DeskJet 6122 InkJet Printer
Adding paper
There is no manual available for this model online.
However, there are two basic methods. Always make sure you are puting in paper that has been cut cleanly with scissors, not torn, as this can ruin your printer. If you have a slot on the back of the machine, just under where the paper roller typically sits on the holder, with the calculator off feed the paper in that slot (rolling out from the bottom). Then turn the printer on, and hit the feed to advance the paper into the printer.
If there is no slot on the back, you will see that the opening where the paper comes out from the top is "subdivided", and when it has printed, it is coming out of the front partition of that slot. Make sure the printer is off, feed the paper into the back portion of the opening, rolling from the top. Then turn the printer on, and hit the feed to advance the paper into the printer.
Either method should solve the issue exactly, and once the paper has fed in, then place the roll onto the holder. You're set!
Please post back if you need more help, otherwise thank you for using and rating FixYa!
Jun 07, 2008 | Canon P23-DHV Calculator
Loading printer paper
Where I was guiding the paper, after feeding the paper through the back of the machine (the slot is located on the outside of the back of the machine), the paper naturally wanted to enter underneath the black plastic plate where it would end up underneath the entire printing mechanism. As the instructions indicate, the paper does not actually feed "under the black plastic plate", it should feed through it. There are two rectangular silver tabs, one on each side of the proper paper entry slot. I cut the paper at a very slight angle and finally found the magic entry point. Also if you make an arrow with the paper by folding the sides, it will help guide it in that tiny silver slot. Because the machine is so tiny, that entry slot is almost invisible, except for those two silver tabs. After you manage to insert the end of the angled cut through the "invisible slot" be sure the entire edge of the paper actually enters the slot so that when you push the "Feed" button, the paper is grabbed and fished through evenly. Hope this helps somebody!
gaframe = true; ' + '' + google_ads[i].line1 + '
' + '' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
' + '' + google_ads[i].visible_url + '
'; } } var adsByGoogleRight = "-40px"; if(dartRecieved){ document.getElementById("ga_300x250").style.clear="both"; document.getElementById("ga_300x250").style.left = "0px"; document.getElementById("inner_adv_caption").style.display = "block"; document.getElementById("ga_300x250").style.width = "370px"; adsByGoogleRight = "5px"; } else if(isHealthinationExist){ var healthinationBox = $('healthonationBox'); if(healthinationBox){ var helthinationBot = getObjXY(healthinationBox)[1]+healthinationBox.clientHeight; var ga_top =getObjXY(document.getElementById("ga_300x250"))[1]; if(ga_top-helthinationBot >0){ document.getElementById("ga_300x250").style.width = "530px"; } else{ document.getElementById("ga_300x250").style.width = "410px"; } } $('boxAdWrapper').style.display = "none"; } else{ document.getElementById("ga_300x250").style.width = "530px"; $('boxAdWrapper').style.display = "none"; } //add "ads by google" var logo_img = 'abg-en-100c-000000.gif'+versionno+''; s += '' + logo_img + ''; document.getElementById("ga_300x250").innerHTML = s; var currl = $('related_links'); var currq = $('related_questions'); if(currl!=null && currq!=null){ var currltop = getObjXY(currl)[1]; if(currltop > rltop ) currq.style.clear="left"; } return; }; //-->
Mar 19, 2007 | Canon P1-DHV Calculator
Casio DR-T120 Calculator Logo
398 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
