Question about Garden
Nexgen 400/600 watt ballast does not work
Does not work blinking red light
  • 132 Answers
SOURCE: 400 watt HPS
roger last time a ballast stopped working on me i simply replaced it on the grounds i might become a fire hazard do you no what i mean they are not that expensive
Posted on Nov 09, 2008
fknstart
  • 404 Answers
SOURCE: lighting ballast ???
hps lamps
Posted on May 29, 2009
  • 11800 Answers
SOURCE: Bulb went out with *** sound. Ordered a
There's a more serious problem in the power source, when the bulb failed it fried the high tension rail. Check it and fix it if you know how, otherwise replace the entire board.
Posted on Jun 17, 2010
supernova278
  • 1932 Answers
SOURCE: 2 rear fans are working, after ballast spark the 2
Hi
Please check correctly how many times the power LED is flashing. There is no option for flashing four times.
Flashing 3 times- Lamp door or lamp is no securely attached
I have attached a diagram how to check it please follow the steps and you can get rid of this problem65de2ca.jpg
Thanx
Posted on Jul 31, 2010
gopakumarg43
  • 74383 Answers
SOURCE: I have a Sony wega 60 in. Tv (kdf e60a20) I get a blinking green light followed by 5 blinking red lights. I read some forums that say it indicates bad lamp/lamp ballast. However I just installed a ne
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Posted on Mar 12, 2015
When all three lights are blinking what do I do?
If the unit uses a ballast for the lamp, it could be that it needs replacement of the ballast.
Aug 25, 2017 | Office Equipment & Supplies
What does the yellow blinking light mean on Mitsubishi WD65837
Here is a whole list for you :
Mitsubishi Blinking Codes :
Constant Green - TV is Powered On
Constant Red - Lamp Failure
Constant Yellow - DMD temp is very high
Blinking Yellow - Lamp cover is open
1 Red Blink, 6 Yellow Blinks - Color Wheel Failure
3 Red Blinks, 4 Yellow Blinks - Lamp Failure
3 Red Blinks, 6 Yellow Blinks - Exhaust Fan Not Working
3 Red Blinks, 7 Yellow Blinks - DMD Fan is not rotating
5 Red Blinks, 7 Yellow Blinks - Ballast Problem
6 Red Blinks, 6 Yellow Blinks - Lamp Missing, Bad Cable between lamp and ballast
And the Lamp cover must be here somewhere in your TV :
For more you can refer to the below link :
Mitsubishi DLP TV Blinking Code Errors Explained Overview of Each...
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
TV blue light comes on, then the red light blinks two times, on the 3rd blink, it goes into rapid blinking. I replaced the lamp and it worked for a week, but then the same issue. I put the old lamp back...
some units require a lamp counter reset.the ballast usually starts at extreme output and at certain hour interval the ballast would start to decrease voltage as the bulb ages.to reset on some models can be reset using the remote
Aug 12, 2013 | JVC HD-61Z786 61" Rear Projection HDTV
Replaced bulb yesterday worked fine. Today light will not turn on. projector turns on both lights green for 10 seconds, then power goes red and status blinks green for about 5 seconds, then status light...
green green is power on, normal
then it tries to light the lamp, but it can't so the protection circuit comes activated.
you get red and green blinking
Then it goes to standby, red and off.
so something has happened to the lamp, or lamp ballast power supply.
Take the lamp out and check if all is OK with the 2 terminals in the connector, and the leads to the lamp are intact.
Failing that, I would suspect the ballast lamp power unit
Mar 25, 2011 | Mitsubishi HC1600 Projector
My TV screen went black and now the bottom light that is usually green, now blinks red 5 times in a row. Can you please tell me what is wrong w/ it?
5 times red standby light blinking shows problem with ballast supply board in Sony KDF-E50A10 model tv, ballast supply board provides high voltage to lamp to produce high bright light.
Please check/ replace ballast supply board in tv by local tv repairman.
Thanks.
Nov 07, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
Benq pb8250 , red light blinking
you have a problem with either the fans, the ballast, or the colorwheel. if the fans turn on, listen for a high-pitched whir. if you don't hear it, replace the colorwheel. if you do, replace the ballast. if the fans don't spin, replace them.
Sep 22, 2009 | BenQ PB8250 Multimedia Projector
Red light 5 blinks
your set needs attention by the authorised service - probably the Vertical scan, horizontal scan or the flyback transformer driver circuits have failed.
Jul 12, 2009 | Sony KDS-R50XBR1 50" HDTV
When I turn on the tv, green light blinks for a
Its your ballast. it has as short. i recommend changing the ballast. while you are inside the set, i would run a break point test on the power board to be safe but, im sure its the ballast.
Mar 09, 2009 | Televison & Video
Red stand by light blinking
5 blinks = lamp driver (ballast) failure.
1-468-798-14 for the 610 model
replacement is done from the back of the set, should be straight forward, keep the red ballast wires apart for best results
if a tech replaced the red tube, you have an older tv where 5 blinks is the AKB error meaning your CRTs are getting old.
Nov 17, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
400 watt HPS
The ballast may not be the problem. The problem may be the ignitor (starter). If the fixture humms, then the ballast is most likely working. Ballasts (transformers) do not go bad very often.
Oct 12, 2008 | Sunlight Supply 400 Watt Hps Sunsystem I...
Garden Logo
54 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
