Question about Ovens
Hotpoint EW52 slot in - Ovens
2 Suggested Answers
  • 44 Answers
SOURCE: oven not heating
Hi
The problem will be the fan element. remove back panel inside oven from there you will see the element just repalce and you will be back up and running. hope this helps you
regards dan
Posted on Mar 19, 2009
Hotpoint oven eg74 slot in i need to no how to use the timer,so when im out the oven will come on and be cooked when i get in
Good afternoom.
Go to the following site.
WWW.HOTPOINTSERVICE.CO.UK
In the menu on the left, click on---HOTPOINT USER MANUALS, and then in the search box on the right enter you model number in CAPITAL letters, and download the instructions.
Jan 23, 2011 | Hotpoint Ovens
I need a user manual for the hotpoint BD32K, black double oven
I cannot provide you a manual , But definitely guide you to solve your Problem
Please Rate my answer Fairly and Support me . Thanks and Regards Deepak Richard
Dec 01, 2010 | Hotpoint Ovens
Need to replace baking unit on Hotpoint range
Difficult is a relative question, I don't think it's very difficult though.
**First-Unplug the unit from the wall, or shut off any power to the unit.**
All you should need is a robertson screwdriver, perhaps a philips and slotted depending on the existing screw heads (square,star and flat) Remove the two screws at the back of the element bracket. Once they are removed, carefully pull the element a couple of inches from the oven cavity, there will be 2 wires connected to it. Hopefully the wires will be long enough to allow you to do this from the front, if not you'll need to remove the back panel of the range. If you have wires long enough you can proceed to remove them and install the new element in the reverse procedure.
You may also require a pair of pliers as well to remove/install the screws on the bake element, hold the connector with the pliers, and turn the screw with the driver so as not to twist the connector in a circle and hence ruining your new element.
*Note; inspect the connections of the wires to the element, if they look burnt, cracked, or just barely hanging on, replace them. you'll need to purchase (if you haven't already) a wire stripper/crimper and some new fittings. Make sure the new fittings/connectors are of the "hi-temp" (usually chrome/nickle plated) variety. Regular metal connector's will fatigue in a short time, relative again to how often the bake is used.
hope that helps, let me know if you need any further assistance.
Good Luck :)
Oct 23, 2009 | Hotpoint Ovens
Oven not heating
Hi
regards dan
Mar 18, 2009 | Ovens
Manual
You can download the instructions you require by going to the Hotpoint web site.
In your browser bar type in --hotpoint user manuals
In the list click on---manuals-user guides-handbooks
In the search box enter the oven model number and download as req'd
Plz rate my solution.
Thanks.
Jan 26, 2009 | Hotpoint Ovens
CLOCK ON COOKER
You can down load the user instructions from Hotpoint web site.
In your browser bar type in---- hotpoint user manuals
Then in the drop down list click on------ hotpoint manuals and guides
In the search box type in your model number and down load instructions.
Thanks.
Jan 14, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Hotpoint BS 21 fan oven Broken door hinge
Pull the door down as far as it will go, and at the lower end of the hinges, there you should see what looks like 2 round discs, with a step cut out, rotate the discs with a scewdriver as far as they will go,then close the door and pull it towards you, the door should then pull off.
Replace both hinges, not just the one ,or it will close unevenly.
Slot the hinges back into the hinge slots, pull the door down, rotate the disc back to their original setting, and that should be it.
Plz rate this solution. Thanks.
Dec 27, 2008 | Ovens
Hotpoint dy230gx
it is normal for the grill electrode to spark as well when lighting main oven - i assume you don't mean that the grill lights - just sparks
Jun 29, 2008 | Hotpoint SY21 Style Line Gas Single Oven
EG73 Hotpoint Oven heating when switched off
sounds just like hotpoint customer service "fob off"
your fault sounds more like the selector swich shorting out going by prev repairs i would isolate the cooker straight away and investigate.
ps. would not leave cooker powered up if not in use until fault repaired
Feb 28, 2008 | Ovens
Ovens Logo
64 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
