Question about Tippmann 98 Custom Act Paintball Gun
Tippman 98 barely shoots and bolt will not return to cocked position
I have cleaned gun inside and out. I have a full tank, no leaks, velocity is turned up. It shoots about 30 feet and only one shot at a time. I have to pull bolt back each time. What next?
5 Suggested Answers
  • 8 Answers
SOURCE: Shoots 2 balls at once
You are double feeding you need to get a new ball latch.
Posted on Dec 14, 2009
  • 15 Answers
SOURCE: I attempted to put a car stock on my Tippmann 98
Check the O rings on the big metal striker, make sure that you have the spring on the back (where the stock would have went) in the right hole on the back plate. Make sure that your velocity is set to a reasonable level.
Posted on Jan 03, 2011
  • 111 Answers
SOURCE: i added a stock to my tippman 98 custom and it
Check and make sure that it's secured properly and that the spring is seated correctly in the back.
Make sure it's clean and lubed with a quality oil made for paintball.
If neither of those is the culprit keep trying to use it. The feel will definitely be a little different and it may just "seem" like it's not the same gun, because it's not. Some players like a stock, and some not, and some don't know until they've tried one. Practice with it for a while and see if you're view changes (assuming the above isn't an issue).
If you decide it has problems, check out your local airsmith and make sure everything else is in good shape.
Play hard, play safe, play with honor!
8^)
Posted on Jan 04, 2011
  • 15 Answers
SOURCE: i bought my tippmann 98 used the co2 tank is
Try turning up the velocity on the marker.
Posted on Feb 07, 2011
Paintballs keep blowing up in my tippmann 98 custom HELP!
it could be a combination of a number of things.. most likely it has to do with the type of paint you're shooting; in regards to shell.. tippman guns are harder on paint therefore require a harder shell paint, also not all paintballs are exactly .68 caliber, meaning some a bigger and some are smaller.. could be that they're slightly to big for the bore of you barrell
Feb 13, 2013 | Tippmann 98 Custom Act Paintball Gun
Tippman A-5 with low pressure kit, e-grip. When pull the trigger gun shoots fully auto until I manually stop it by re cocking the gun.
Sounds like the gun needs lube. Oil it and try again. 2-3 drops of oil in the hole
where the tank screws on then put the tank back on. Fire it and see how it does.
I havent heard of a low pressure kit for the A-5 but I think it is a waste. There is a rule
with pressure and paintball guns. Low pressure=high volume of air used.
Standard pressure=regular volume. I have 2 a-5's with e-grips and flatlines.
I polished the internals by sanding the bore of the tube (use fine sandpapaer) and
this makes the velocity very consistent.
One thing that comes to mind is that the hammer may not be getting caught on the
trigger latch. Makes sure your gun is assembled correctly. here is your manual.
http://www.tippmann.com/pdfs/products/A5/a5manual.pdf
Feb 15, 2011 | Tippmann A 5 Standard Paintball Gun
First time user I just got a tippman marker and doesnt look like the C)2 is working? Is there something that needs to be done to get to work out of the box?
this is gonna kinda sound dumb. but did you remember to pull the cocking handle back after you put on your tank? and is your tank screwed on tight?
Feb 13, 2011 | Tippmann 98 Custom Act Paintball Gun
I fire the gun and it doesnt wanna stay cocked i have to **** it every time i wanna fir
One.. dirty...
Two.. no lube/wrong lube...
Three.. no air...
or any combination of the above. Make sure you have a full tank, clean the marker and use paintball-specific oil to lube the internals. The 98 is a very dependable marker and I'm sure once you have the basics down you'll find it very reliable.
8^)
Nov 14, 2010 | Tippmann 98 Custom Act Paintball Gun
I attempted to put a car stock on my Tippmann 98 custom and took apart the gun but the stock didnt fit, now when i put it back together and shot it with my tank connected the gun wont stay cocked and...
Oct 02, 2010 | Tippmann 98 Custom Act Paintball Gun
Paintball gun is rapid firing when trigger is pressed. CO2bottle is full and i have tried other bottles but stillth same.
Tippmanns are known for their reliability and are very simple markers making them very easy to repair. you need oil from a local paintball shop or regular sewing machine oil will do.
On one side of the marker there is a little "handle" for cocking the gun, pull that handle as far back as you can and you will see 1 o-ring. put 2 drops of oil on it and fire it a couple times without paintballs to test it. This solves the problem 9/10 for tippmanns, if not..
Sometimes paintballs can break inside your gun. Look and feel inside your breech (where the paintballs go into the gun) and check for paint. If its dirty this can be causing your problem, strip it down and clean it (refer to your manual if you have difficulty)
on one side of the marker there is a little "handle" for cocking the gun, pull that handle as far back as you can and you will see 1 o-ring. put 2 drops of oil on it and fire it a couple times without paintballs to test it. This solves the problem 9/10 for tippmanns
Jan 08, 2010 | Tippmann 98 Custom Act Paintball Gun
Cannot adjust velocity
Please see below page 8 for picture of what I am talking about.
On page 8 in the middle left side is a picture of the internal vale parts.
When you pull the valve out on the back side is a little o ring that can be taken out using an o ring pick. Make sure to watch the way the parts come out and look for any rust, also broken o rings if the valve is stuck open this will allow the maximum of air to pass. Most of time is this part that is messed up. You can by the valve in one unit this is the best option.
But the first thing is to check the valve and all the parts. Lube it up and re install it.
http://www.tippmann.com/pdfs/manuals/98Custom_Manual.pdf
Jul 17, 2009 | Tippmann 98 Custom Act Paintball Gun
Tippmann 98 Custom Act Paintball Gun Logo
400 people viewed this question
Top Tippmann Sport & Outdoor - Others Experts
spank61
Vickie Miller
Vickie Miller
Level 1 Expert
Are you a Tippmann Sport and Outdoor - Other Expert? Answer questions, earn points and help others
