Question about Samsung Q45 Notebook
Wrong screen resolution - Samsung Q45 Notebook
How do I change the font and icon size on the monitor. I have two monitors and font and icons are different sizes.
Change the Resolution of the 2 monitors to match the setting you prefer. (Right-Click on Desktop, choose "Screen resolution" It should show both monitors.Set resolution on the "Wrong" screen to match the settings on the "Correct" screen.
Oct 11, 2015 | HP W2007 LCD Monitor
How do i reset my computer screen back to normal
By this I guess you mean you want to reset your screen resolution. You are not quite clear on exactly what has gone wrong with your screen but however if it is because of the resolution then that one is easy. You write click on your mouse on your screen then you go to 'Properties' then go to 'settings' then you move the arrow there to set you r screen resolution trying different sizes and seeing which one suits you. If this is not what you meant then send me a message telling me what is wrong. good luck.
Dec 01, 2011 | Dell Computers & Internet
The screen is not clear/blurd
It sounds like the screen is set at the wrong resolution, i would play with the resolution settings. do you know what you screens default resolution is supposed to be.
Jun 18, 2011 | Acer Computers & Internet
My computer continues to prompt me to the attempting to fix screen and continues to attempt to fix problem all day. what could be wrong?
Check the resolution of the screen. Depending on the screen size, there is a maximum resolution that your screen can handle and will look perfect at that resolution.
Feb 28, 2011 | E-Machines eMachines Desktop PC
Black border either side of the screen
hi this could be the resolution settings, try changing it to a different resolution, till you get it to fit hope this helps
Sep 04, 2010 | Computers & Internet
Only displaying 10 x 10 screen
It sounds to me that you have the resolution on the wrong setting. Go a a clear space on your desktop, right click, and select properties. When that opens go to the settings tab and change the screen resolution to 1600 X 1200. This is the native setting for the monitor. If that doesn't fix the problem continue changing the screen resolution until you get one that works.
Sep 03, 2010 | Samsung 204T 20" LCD Monitor
The pictures are too wide all people look fat
You most likely have a wide screen and the screen resolution needs to be adjusted to suit the monitor.
Go to the Control Panel - Display and adjust the screen resolution until you get a normal image and correct screen aspect screen ratio. Start with a screen resolution of 1024X768 and gradually increase it until you get an image that suits your screen.
Oct 01, 2009 | Acer Computers & Internet
Cant adjust video resolution onboard videocard failed installed jaton trident videocard cant adjust above 800 600 screen resolution
Try downloading the most recent drivers for your new video card from the manufacturers website, that should get your resolution problem fixed.
May 03, 2009 | Computers & Internet
Prob with screen resolution
options listed would be correct for that monitor if you installed the drivers and inf file for the display. if it is another monitors resolution settings then you may just have the wrong monitor installed
Jan 30, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Samsung Q45 Notebook Logo
35 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
