Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
GE dss25kgrb not dispensing ice - GE Profile PSW26P Stainless Steel Side by Side Refrigerator
  • 330 Answers
SOURCE: GE TFX22CR Ice Dispenser inoperative
Check the ice maker see it is in the right position, maybe you can try pull out the ice maker and clean it and push it back, make sure the position is right.
Posted on Jul 21, 2008
  • 115 Answers
SOURCE: Replace GE ice dispenser damper door on GE model PSI23sgna
take both hands and place on the front bottom edge of control panel pull up and out it is hard and you think you are going to break something but you are not when you get the control panel off there will be 4 screws at each corner undo them and slide that piece off then you can see your door
Posted on Dec 30, 2008
SOURCE: GE Side by Side only dispenses crushed ice
remove the ice cube tray assy, remove all the ice, save the cubes, wash the assy with warm water dry the assy, be sure the lever in the rear of this ice cube assy is moving and spring loaded, move the lever and it should snap back and return if so you know the unit is ok(the cube assy), now with the assy still out of the freezer close the freezer door and select crushed ice and push the pad where the glass normally hit to activate the ice cubes,if the operates and you here a thump and snap and hum most likely your ok,if not you could have a defective auger motor assy,but if you here all the sounds as decribed oped the freezer door and select cubed ice push actuator on despensor door with the freezer door closed, reopen and install the ice cube assy tray bucket assy,push it in firmley, and try it with some ice in the bucket you should be fine,if not replace auger motor assy..
nbcrca:)
Posted on Apr 11, 2009
SOURCE: GE refer will not dispense cubed ice
I have the same problem. My GE refridgerator won't dispense ice cubes.
Posted on May 01, 2009
Sea Breeze
  • 4655 Answers
SOURCE: ge profile artica ice dispenser and chute frosing.
This may be because the chute door is not all the way shut when off. If yes the warm moist air is being pulled through the opening and causing this. Sea Breeze
Posted on Oct 21, 2009
Testimonial: "new here--did not mean to rate you low..sorry!"
Ge Profile Stainless Steel 26 ft Refrigerator ice maker dispenser
try pulling out the ice bucket, remove all ice and look for signs of damage on the auger mechanism... most of the time the ice tends to clump up and that prevents the auger from moving freely.
Mar 24, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice dispenser has rust
The rust will conterminate your ice, please have the spiral ice dispenser replaced.
Jul 30, 2009 | GE Profile Performance 25.2 cu. ft....
GE GSS22JERFWW won't dispense ice
hi
this is the heating element problem ie thermostat ,,u should replace it..
thank u please rate it//
Jul 04, 2009 | Refrigerators
May 01, 2009 | General Electric GSS22JET Side by Side...
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
Kenmore Side by Side Ice Dispenser Not Working
My GE DSS25KGRB side-by-side refrigerator had a problem where the ice dispenser motor would not turn. I had noticed this intermittently in the past, and this time it happened after the power came back on after being off for several hours. I removed the ice-cube bucket, and tried to turn the auger motor shaft ¼ turn manually, as advised in my instruction booklet for how to refit the bucket. Since it wouldn’t turn I guessed (correctly) that ice had gotten into the motor and froze it.
I removed the ice dispensor motor assembly (outer four hex screws), disconnected the two cables as I went, and removed the assembly from the fridge. I then disconnected the two motor wires, removed the clear-rubber boot that covered the motor, and let it defrost and dry out for 20 minutes or so, partially assisted with a hair dryer. Then I could turn the motor shaft.
Before reassembling it, I noticed what appeared to be a GE engineering error. Only two of the three attaching screws on the motor fit into the three clear-rubber grommets that were attached to the rubber boot. It looked like mismatched parts. This prevented the boot from covering the motor tightly, which probably contributed to moisture getting in. So after letting it dry for another hour or so, I put it back together, and sealed the gaps between the boot and the metal housing by applying some "100% silicon sealant, indoor/outdoor, for windows and doors".
I’ll really know whether this is a permanent fix if it survives a few freeze-thaw cycles. But it works again for now, and I don’t want my ice-cream to melt.
Jan 04, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
May 28, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Arctica (PSS26NGSB) ice and water dispenser
need to call ge at 1800-386-1215 some of these sxs have a door insulation issue that they will either send replacement doors to an authorized service company to exchange at no cost to you or offer a rebate for a newer model. yours might be in this group
have your model and serial number out of the ref located in the refrigerator section, about 4-5 inches from the celing down the right side and call and see
Apr 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
