Question about Canon Elura 65 Mini DV Digital Camcorder
Zoom problem As many others Elura 65 owners mine has the zoom problem ( it zooms all the way to the maximum on its own; takes a while to come back but can stop it by holding the slider, it is a pain to do that though. Well as I have read through the posts, it looks to be a common problem with this camcorder, Would you please find me a solution to repair it? Thks CC
  • 4 Answers
The zoom is stuck. Smack the bottom of the camera with the palm of your hand. Worked like a charm for me.
Posted on Feb 19, 2009
Our Canon Elura 65 Camcorder won't focus. The
First off I don't condone or advise hitting an electronic device but, from the advice of another post I did it and it worked. It shouldn't have but it did. I hit the bottom of the camcorder with the palm of my hand and it worked perfectly afterward.
Jun 28, 2010 | Canon Elura 65 Mini DV Digital Camcorder
Canon Elura zoom problem
on mine the ribbon cable from zoom button was pinched where it goes around the door replaced cable
Jul 16, 2008 | Canon Elura 65 Mini DV Digital Camcorder
Zoom
My zoom problem was a combination of the software and hardware when it came to the neutral position for the zoom slider. When the camera is first turned on, if the physical zoom slider (hardware) is in the neutral position (you are not touching it) the camera software does nothing, but if you are pushing the physical zoom slider when you turn on the camera, the software resets the "zero zoom" position into memory. The solution to my problem was to push and hold the physical zoom slider towards the wide position and the software realize reset the "zero zoom" neutral position. This may take a few tries to get it right (if you over compensate, do the opposite and push the slider towards "T" when you turn it on), but I hope this will solve your problem and save you a few bucks.
Ryan
Jul 04, 2008 | Canon Elura 65 Mini DV Digital Camcorder
Canon elura 65
on mine the ribbon cable from the button to the main board was pinched by the door and shorted
Feb 13, 2008 | Canon Elura 65 Mini DV Digital Camcorder
Elura 60 Zoom Problem
Guys, so weird but on another site it offered this suggestion: banged the base of your camera against something hard and it will become unstuck. So bang the base of your camera against something hard and it will work again, at least it works like it did but not sure for how long. Good luck. I can't believe that worked. Give it a try. I didnt hit it too hard either.
Dec 20, 2007 | Canon Elura 60 Mini DV Digital Camcorder
Canon Elura 60 zooms by itself
Listen, I know it's a couple of years after this post but, try this: Remove cassette, push to close, close camera as if to use it, hold firmly in left hand, open hand slap it with your right hand once or twice, (I'm not joking) it worked the two times I had this problem. Problems with the zoom? Almost same process, push firmly on zoom button (to un-zoom) try doing this as your tapping it. These are last ditch efforts on an aging camera, it really has been a good one. I've put this poor thing through years of abuse, and it's held up pretty well. Good luck, Jeff S.
Oct 16, 2007 | Canon Elura 60 Mini DV Digital Camcorder
Automatically zooming in
Hello:
I contacted Canon about this same issue in my Elura 65, and they said to send it to them, they would have their techs investigate the cause and then contact me with the costs to make the repairs. They said that if I didn't want them to repair the problem, after I found out the cost, that they would reassemble the camera and send it back.
Mine is out of warranty, even with buying it at Costco, who doubles the warranty time. In my researching the problem, I have found another person with the same problem who had it repaired for something like $175. I will weigh that against purchasing a newer model.
Someone else did reccommend wacking in on the top a few times, shutting if off and turning it back on, and that would often fix the problem. I don't want to take the chance of ruining an important shot that may not come around again, by having to Indian Leg Wrestle my camera to get it to work. Best wishes.
Oct 12, 2007 | Canon Elura 60 Mini DV Digital Camcorder
My zoom acts wierd
Banging the camera solved the problem on my elura 60! I have whack the camcorder three times again the other hand. It worked.
I had this trouble for two years!
Mar 28, 2007 | Canon Elura 70 Mini DV Digital Camcorder
Canon Elura 60 - Zoom is on maximum and won't restore. I own Canon Elura 60 since last two years and now i'm facing problems with zoom. Zoom button does go to and fro but actual zoom doesn't take...
Hi There, did you find any resolution for this problem? If you could share any info about the problem, it will be really great. Even I have the same issue with my Elura 70. Thanks.. Pradeep
Nov 08, 2006 | Canon Elura 60 Mini DV Digital Camcorder
Canon Elura 65 Mini DV Digital Camcorder Logo
248 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
