Question about Hoover Vacuums
Hoover pure power 1500w u3450 001 type VU01 pdf
Belt broken replace
4 Suggested Answers
  • 417 Answers
SOURCE: I have a u3450 1500w
There must be a restriction or blockage in the carpet suction pipe. Look at the port where the hose connects to the machine and check for any accumulation of debris or blockage. The same motor drives both suction inlets so it can only be that there is an obstruction.
Posted on Nov 02, 2008
  • 27 Answers
SOURCE: How do I change the belt
there are two screws undeneath unfaseh those then the bottom plate comes off then prise the roller out then the belt fits over the motor spindle first then over the brush then reasemble
Posted on Aug 23, 2009
  • 190 Answers
SOURCE: The region of the motor gets very hot during use. What can I do?
The Hoover is likely built with a temperature overload protector, to shut down the unit if it gets excessively hot. All the units will get heat build-up from the suction motor during use.
Posted on Oct 03, 2009
My Hoover pure power 1700w upright, bagged vacuum cleaner shuts down after 5 minute's use. Although I purchased the pure Hoover power 1700w upright vacuum cleaner around eight years ago it has not u
Are the brushes worn down too far? As they wear the springs tension gets weaker. The brushes can also get stuck inside the channel they slide in. Could also be a buildup of dust etc inside and around the internal fan or commutator, etc.
Jan 18, 2015 | Hoover Vacuums
The belt is broken on our Hoover Allergen Filtration Model U5018-900 120 v. 60 Hz 12.0 A. Belt 38528040. Where can I get the belt and instructions on how to replace the broken belt?
The owner's manual can be downloaded here (in red, "Download the Instruction Manual (PDF))
http://www.hoover.com/product.aspx?model=U5018900&ds=false
Instructions for replacing the belt are on page 9.
You can order the belt here:
http://www.hoover.com/shop/searchresults.aspx?itemid=221224
Or use the "Retail Locator" on the first site.. Just type in your zip code, and a store that carries Hoover and products near you will be shown.
Oct 07, 2010 | Hoover U5018-900 Bagged Upright Vacuum
I need a replacement belt for Hoover Elite upright vaccum ,model no. U5043-930. What belt do I get?
Your vacuum cleaner originally came with Hoover belt part number 38528027, however Hoover has now discontinued this part number, and replaced this belt with the new belt which is part number 38528040.
The new belt is a little bit smaller then your old one, but unfortunately this is the only belt that Hoover currently makes that will fit your model.
Here's a direct link to our website if you still need to purchase one:
http://www.govacuum.com/agbelhoovpar7.html
I have also uploaded the parts diagram and instruction manual for you. The parts diagram gives you every single part number for all parts on your vacuum should ever need to know another part number. The owners manual will give you step by step instructions on how to change the belt, as well as other maintenance instructions.
Part Diagram for Hoover U5227-930:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/Part-diagram-hoover-u5043-930.pdf
Owners manual is actually for the commercial version of your vacuum, but this will be identical to your instruction manual which Hoover doesn't have available for free:
http://www.hoover.com/pdfs/manuals/C1414900.pdf
I hope that this information was helpful to you. If it was, please be so kind and rate my repair helpful by clicking the thumbs up icons in the top corner of the repair.
Thank you very much,
Chris J.
GoVacuum
Apr 04, 2010 | Hoover U5227-930 Elite Upright Vacuum
Sep 29, 2009 | Hoover Vacuums
The belt needs replacing
Here is the manual to your Hoover U6630
www.thinkvacuums.com/pdf/uprights/Hoover_U6630.pdf
it goes into detail on how to change the belt and which belt to purchase. Ask for a flat belt Hoover part No. 38528035 when you're going to purchase the replacement belt
Aug 31, 2009 | Hoover U6630-900 WindTunnel Bagless...
Aug 23, 2009 | Vacuums
Roller Belt Keeps Slipping Off
You could try contacting Hoover for parts availability. If it's and older WindTunnel and Hoover no longer has the part, try eBay.
May 14, 2017 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Wind Tunnel V-Belt no longer turns brush
that is the correct belt what you dont see is a tension pulley that when the handle is released pushes on top of that belt giving it the tension it needs. try replacing the other belt, even if it isnt broken it could easily be stretched out ( all belts of that type should be replaced every year - even if you didnt use the machine at all ). if that doesnt work that tension pulley could be damaged you would need to take the bottom of the machine apart to fix that.
Sep 18, 2008 | Hoover U6311-930 Power Drive Bagged...
Vacuums Logo
136 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
