Question about Samsung Weather Resistant Security Camera SSC-12C
Samsung ssc21web repair man
Ssc21web - monitor and camera will not connect. osd "L" is displayed
2 Suggested Answers
SOURCE: SAMSUNG SSC21WEB
If it is the same year as mine you can change the settings through the ssc21web system instead of the recorder-have you tried that yet? The ssc21web system has the ability to be set to view the input from the cameras. There are many options- motion detect, quad, single, it will switch from single to quad intermittently, etc. Maybe your settings were changed on the ssc21web and not your recording devise-check that first, then go back to the ssc1280.
Posted on Jul 23, 2010
Ssc21web samsung monitor
You would have to refer this matter to Samsung directly
Apr 23, 2013 | Samsung Weather Resistant Security Camera...
How to get rid padlock Dell E176FP 17" LCD Monitor Dell monitor lock display and all display button not functioning ang monitor power too
You can follow these steps:
1.Click on the menu button in front of the monitor
2. Select OSD settings
3. Select OSD lock
4. Then choose Yes or No to lock and unlock it
Hope this helps
Thanks
Dennis
Oct 26, 2011 | Dell E176FP 17" LCD Monitor
My monitor is of AOC " e2043Fsk " . When I try
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Jan 03, 2011 | ASUS Computers & Internet
"OSD LOCKED" box on my screen
OSD stands for "On Screen Display." It is an onscreen configuration menu included with various monitors. When you press the MENU button or one of the other buttons on the front or side of a monitor, the onscreen display may appear. The OSD typically includes monitor calibration options, such as brightness, contrast, and color adjustments. Some OSDs may also include horizontal and vertical position controls as well as tilt and keystone adjustments.
If you can't make adjustments to the monitor settings using the OSD interface, the onscreen display may be locked. You may also see the phrase "OSD Locked" appear when you try to change the settings. Some monitors include an option within the menu called "OSD Lock", which you can turn on or off. If this option is available, simply turn OSD Lock off and you will be able to make adjustments to the settings.
If your monitor does not include the "OSD Lock" option, you may be able to unlock the OSD by pressing and holding the MENU button on the front or side of the monitor for several seconds. If you try this method, be patient! It may take up to 15 seconds for the OSD to unlock.
VOTE ME
Dec 07, 2010 | Dell Computers & Internet
When i press the power button to turn off monitor, i get a power button lockout message. how do i unlock the power button
I did not see anything regarding to the Power locked out function, may be it's time to call HP. Please post back what you find out from HP.
I look at HP WEBSITE: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01632269&tmp_track_link=ot_recdoc/c01643091/en_us/c01632269/loc:1&lc=en&dlc=en&cc=us&product=3770762
Locking OSD settings
When the OSD is locked, settings cannot be changed in the OSD menu. The OSD functionality is enabled or disabled by pressing the Menu button and holding it for 10 seconds. Upon disabling the OSD, an OSD Lock-out message is displayed for 10 seconds. When the OSD is locked and an OSD menu button is pressed, the OSD Lock-out message is displayed for an additional 10 seconds. When the OSD is locked, pressing the OSD menu button for 10 seconds unlocks the OSD and displays the main menu. Identifying monitor conditions
Special messages display on the monitor screen for the following monitor conditions:
  • Input Signal Out of Range : Indicates the monitor does not support the input signal because the resolution and/or refresh rate are set higher than the monitor supports. Recommended refresh rates are as follows:
    • For the w1858 monitor: 1366 x 768 @ 60 Hz.
    • For the w2338h monitor: 1920 x 1080 @ 60 Hz.
  • Monitor Going to Sleep : Indicates the screen display is entering a sleep mode.
  • Check Video Cable : Indicates a video input cable is not properly connected to the computer or monitor.
  • OSD Lock-out : When the OSD is locked, the warning message OSD Lock displays for 10 seconds.
  • No Input Signal : Indicates the monitor is not receiving a video signal from the computer on the monitor video input connector. Check whether the computer or input signal source is off or in the power-save mode.
  • Auto Adjustment in Progress : Indicates the auto-adjustment function is active and in process.
May 13, 2010 | Computers & Internet
Unable to connect to the network on a SSC21web monitor
is this poe cam? cable footage over 300 ft needs cat5 extender if fiber check media converter to see if single or multimode also check media converter for tx/rx or using cat5 b crossover cable connect directly to laptop type in ip in command bar enter
Oct 12, 2009 | Samsung Weather Resistant Security Camera...
My monitor displaying OSD menu Automatically.......and monitor screen is also disturbed(as it shrink and its contrast will goes automatically at 100...and many more problems like this)
d problem is in a transistor costing little, situated near d monitor's osd control ic (microprocessor), it is probably short....[refer the connection n area around the front panel cn connector and crystal clock generator]
Sep 10, 2009 | SAMTRON 55V 15" CRT Monitor
SAMSUNG SSC21WEB
It's a quad. It records all 4 cameras at the same time. You can display 1 cam at a time. If you play it back, you have to hit the buttong that displays the corresponding camera you want to review.
Nov 06, 2008 | Samsung Weather Resistant Security Camera...
Monitor Blank with an OSD display.
Took my monitor to one of the Philips Authorize Repair Shop, they fixed for me. He upgraded the firmware and charged me $70.
Compbits P/L 8/2 Railway Pde , Libcombe
Tel: 02-9649-9449
Dec 22, 2006 | Philips 170S4FB 17" LCD Monitor
Samsung Weather Resistant Security Camera SSC-12C Logo
99 people viewed this question
Top Samsung Home Security Experts
Bill
Level 1 Expert
bobby little
Level 1 Expert
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
