Question about Hoover Vacuums
Hoover pure power 1500w u3450 001 type VU01 pdf
4 Suggested Answers
  • 417 Answers
SOURCE: I have a u3450 1500w
There must be a restriction or blockage in the carpet suction pipe. Look at the port where the hose connects to the machine and check for any accumulation of debris or blockage. The same motor drives both suction inlets so it can only be that there is an obstruction.
Posted on Nov 02, 2008
  • 27 Answers
SOURCE: How do I change the belt
there are two screws undeneath unfaseh those then the bottom plate comes off then prise the roller out then the belt fits over the motor spindle first then over the brush then reasemble
Posted on Aug 23, 2009
  • 190 Answers
SOURCE: The region of the motor gets very hot during use. What can I do?
The Hoover is likely built with a temperature overload protector, to shut down the unit if it gets excessively hot. All the units will get heat build-up from the suction motor during use.
Posted on Oct 03, 2009
HOOVER MAX EXTRACT DUAL V LEAKING SOAP INTO THE FRESH WATER TANK
that is purely normal to have cleaning material in the fresh water tank as the vac picks up the dirt from the floor it should really go into the dirty pickup tank purely normal nothing to worry about
Apr 22, 2017 | Hoover Vacuums
How to replace a on /off rocker switch on a hoover pure power bagged vacuum
Some switches can be prised from the housing with a thin blade and the wires transferred to the new switch which is then pushed back into place.
Often with older equipment the plastic of the switch and the housing can become stubborn and unyielding so it is kinder to access the rear of the switch and either press in the locating springs or break them off to free the switch.
Lots of repair professionals would break the old switch to pieces in-situ and save any dismantling.
Feb 25, 2015 | Hoover Vacuums
My Hoover pure power 1700w upright, bagged vacuum cleaner shuts down after 5 minute's use. Although I purchased the pure Hoover power 1700w upright vacuum cleaner around eight years ago it has not u
Are the brushes worn down too far? As they wear the springs tension gets weaker. The brushes can also get stuck inside the channel they slide in. Could also be a buildup of dust etc inside and around the internal fan or commutator, etc.
Jan 18, 2015 | Hoover Vacuums
Need operating instructions for Hoover Steam Vac model # F5905-900
Use Google and type this in the search box:
hoover steamvac manual filetype:pdf
This will give you several models of manuals to look at and I'm sure one of them will be very close to the model you are seeking, which will be enough to be able to use it.
Here is one that I quickly found using this method:
http://www.hoover.com/pdfs/manuals/F5857955.pdf
Please rate this solution! I hope this gets you off on the right foot.
Thanks,
~PCF
Mar 05, 2011 | Hoover Vacuums
How do you attach the hose?
If your model is the same as the type shown, you may click this link to access the User Manual:
http://www.hoover.com/pdfs/manuals/F5871900.pdf
If not, use this link and type in the appropriate model number:
http://www.hoover.com/CustomerService/Manuals/Default.aspx
Oct 24, 2009 | Hoover V1 SteamVac SpinScrub Vacuum
Sep 29, 2009 | Hoover Vacuums
Aug 23, 2009 | Vacuums
Vacuum faulty power PCB, Need service manual/schematic
No schematic found. The Q1 transistor is a 2N3904, D3 was replaced with a 1N4000 series.
Root cause still Unknown, but Q1 is an exact match and D3 is an acceptible replacement.
Hoovers solution is to replace the whole PCB no matter whats wrong with it, what a waste or good technology!
Mar 30, 2009 | Hoover Self-Propelled WindTunnel Bagless...
I have a u3450 1500w hoover, suction on hose works fine, but carpet suction has never worked, how can i fix this?
Nov 02, 2008 | Hoover Vacuums
Vacuums Logo
89 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
