Question about Air Tools & Compressors
Ingersoll rand p175wd - Air Tools & Compressors
SOURCE: ingersoll Rand SSR compressor shuts down loaded or
When it shuts down, press DISPLAY SELECT button once and use the up down arrows to see the code just before shutdown.
HIGH AIREND TEMP
HIGH AIR PRESSURE
LOW SUMP PRESSURE
PRESSURE OR TEMP SENSOR FAIL
CHECK MOTOR ROTATION
MOTOR OVERLOAD
FAN MOTOR OVERLOAD
STARTER FAULT
I am assuming this has a Intellisys controller.
Posted on Sep 25, 2009
  • 174 Answers
SOURCE: ingersoll rand 463 skid steer manual 2004
www.whitestarmachinery.com
Posted on Oct 11, 2009
  • 243 Answers
SOURCE: i have an ingersoll rand P185WJD Compressor that
possible that one of the protections switch it off check oil levels motor and screw can also be a sensor, can check these by briging them one by one. first indication is control lamp. or possible fuel problem check filters and tank. also check wiring complete. is weak point for ir machines. good luck.
Posted on Feb 10, 2010
  • 409 Answers
SOURCE: I am changing from 460 V to 230 V on a Ingersol rand Compressor
Recheck the way you have the motor leads hooked up, make sure they are correct. You did re connect the motor leads didnt you? You are not trying to run it on 230v single phase are you? Assuming it is a dual voltage motor, the leads will have to be re connected from hi voltage to lo voltage. Also when you cut the operating voltage in half the operating current(amps ) will double, all this info should be on the motor name plate. This motor does not use a capicitor to start it
Posted on Mar 17, 2010
compman66
  • 169 Answers
SOURCE: what type of oil for ingersoll rand model 2475 air
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
Posted on May 12, 2010
How to change from BAR to PSI on INGERSOLL RAND INTELLISYS CONTROL for INGERSOLL RAND SSR-6-20-125 AIR COMPRESSOR
Ingersolll Rand website support section should be able to provide a manual.
Failing that contact customer services.
Aug 03, 2016 | Ingersoll Rand Air Tools & Compressors
What level does the coolant need to be in the sight glass?
About 31,000 results (0.83 seconds) Search Results
    [PDF]IRM-G-8780 2-25hp US - Ingersoll Rand Air Compressor
    www.ingersollrandproducts.com/...
    Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
    [PDF]Owner's Manual - Air Compressors Direct
    www.aircompressorsdirect.com/.../irmanual2340_2475_2545_7100_15t...
    installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
    [PDF]XF 7.5 - 15 EP 7.5 - 15 HP 7.5 - 15 XP 7.5 - 15
    diagramasde.com/.../Manual%20comp%20ingersollrand%20SSR-15.pdf
    EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
    Ingersoll Rand Air Compressors - About Air Compressors
    www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Feb 08, 2016 | Ingersoll Rand 15 Horsepower Rotary Screw...
Problem with Ingersoll Rand - Rand 1/2" Impact Wrench, Quiet Tool with Extended Anvil wont shutoffwont shutoff
The IR 2135-k303 air inlet repair kit along with a IR 2131-322 inlet removal tool should fix your problem.
Jun 02, 2012 | Ingersoll Rand - Rand 1/2" Impact Wrench,...
I would like acquire all tecnical manual Ingersoll Rand 2CV ( 35 or 39 ) M5 or M3 for maintenance. Please inform price and payment conditions. I represent a audit company presenting maintenance...
Hello, Rdouglasv -
Fixya.com does provide some repair and service manuals for a variety of items, but they are available because Fixya.com volunteers have uploaded those manuals for others to retrieve for free via Fixya.
Fixya.com does not sell any maintenance / repair / service manuals.
I did find a few web sites which sell some Ingersoll Rand repair / service manuals:
http://industrialmanuals.com/ingersoll-rand-m-66.php
and:
https://airtoolpro.com/ingersoll-rand-service-documents/
You will find Ingersoll-Rand manuals to download for free here:
http://powertool.manualsonline.com/manuals/mfg/ingersollrand/ingersollrand_air_compressor_product_list.html
Note: The manuals are PDF documents and Adobe Acrobat Reader software (free) will be needed.
Best wishes.
Feb 25, 2018 | Ingersoll Rand Air Compressor Maintenance...
What type of oil for ingersoll rand model 2475 air compressor could not find specs at Rand website
May 10, 2010 | Ingersoll Rand - Rand Type - 30...
Where may I purchase or download a complte repair manual for the Ingersoll Rand model # 2475N7.5? Thank you in advance, Gary
I would suggest contacting a local Ingersoll-Rand air center, a lot of times they can make you a copy for little or no charge
Dec 28, 2009 | Ingersoll Rand - Rand Type - 30...
Air Tools & Compressors Logo
97 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
