Question about Refrigerators
My beko glacier freezer is not freezing
My beko glacier fridge freezer is not getting cold
  • Anonymous Mar 24, 2014
    Change light bulb
    Problem Solver:
  • 6 Answers
Evap coils could be frozen due to bad defrost timer or heater. could be a bad evap motor or worst case the compressor could be bad
Posted on Feb 10, 2012
SOURCE: Fridge not cold
my freezer is over freezing and my fridge is not cold. I have a whirlpool where the freezer is on top and the fridge is on the bottom. I need guidence in trying to figure out the problem.
Posted on Oct 09, 2008
BNewberry
  • 93 Answers
SOURCE: Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
Posted on Nov 25, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
Posted on Feb 12, 2009
Bogie Boy
  • 46 Answers
SOURCE: my mothers beko fridge freezer making bubbling sound
Sounds like the evaporator fan is doing its job. Nothing to worry about. Good hearing is a blessing all fridges make different sounds some click loud while others gurgle loud. Some pop and snap. Till I got my hearing aids I didn't know mine ran so loud and clicked.
Posted on Dec 16, 2009
SOURCE: Fisher and Paykel N500B fridge freezer. Freezer not freezing
I had a similar problem on the same model. Ice creams were soft & frozen food not ice cold. I opened the freezer. Removed the food & noticed the evaporator fan at the back was not turning. This is the likely cause of poor cooling in the freezer. I got it running by turning the fan with a screwdriver but replaced the fan soon after!!!
Posted on Jan 09, 2010
Got a beko chill53w fridge and its freezes up at the back but doesn't get cold. Any ideas?
If it freezez inside at the back, check the door seals. If it freezes on the rear radiator outside, the gas needs settling or re gassing.
Jun 27, 2015 | Beko Tda735w Cda543fw Cda647w Cga963s...
Why does beko glacier fridge icebox makes too much ice and freezes interior flap shut??
2 possibilities
moist air getting in by way of damaged door seals or bent door not sealing
or your inside (evaporator fan is not working) do you have lots of frost all over you items in the freezer. if so then check if the door sealing...turn off all lights in your house at night and put a torch in your freezer shut the door and see if there is any light. a little bit will cause you issues
May 24, 2014 | Refrigerators
Fridge/freezer not working
check the condensor fan if that aint it unit may be low on charge
Apr 24, 2010 | Freezers
I have a Beko frost free fridge freezer but the freezer part has stopped freezing, the fan is working although it is not on all the time and the freezer is getting cold but no cold enough to freeze, have...
have you checked the door seals, if it has split it won`t freeze 100% as warm air will get in and keep the temperature up, bit like leaving the door slowly open hth
Oct 12, 2009 | Freezers
Top of freezer not freezing, bottom of fridge is?
Could be the evaporator fan motor is not working. This is what circulates the air from the freezer to the refrigerator section.
Aug 24, 2009 | Refrigerators
My beko eco care d3421fw dishwasher won't fil with
i have beko glacier fridge freezer.the freezer section works as normal but the fridge section only works sometimes.the pump only starts after you hear a click sound from the back of the fridge.is there a starter component that activates the pump.
May 22, 2009 | Beko 24 in. D3421F Free-standing...
Drain freezes and glacier forms inside bottom
hi thanks for the question the drain hose leading from the freezer is clogged up remove the ice from the bottom pull fridge from wall find small drain tube clean the tube now it will drain into tray vacuum out while your there thanks the appliance doc
Sep 23, 2008 | Maytag Freezer MQU2057
Our beko frost free fridge freezer has stopped freezing. The fan is working and the freezer section cold but not cold enough. Thermostat is in the fridge - the fridge is icing up.
the thermostat in the fridge is turning off your compressor before the freezer has completed its job.this is because it doesnt care about the freezer temperature only the temperature where its located in this case the fridge,try completely defrosting the fridge and restarting it
Aug 12, 2008 | Refrigerators
Refrigerators Logo
350 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
