Question about Lexmark Wheelwriter 50 Series II Typewriter
I have a Wheelwriter 50 Series II It speaks terribly! is there a way to oil it? how do we get the sqealing to stop?
  • Lexmark Master
  • 3,594 Answers
If it squeaks when you tab or return a little WD40 on mthe carrier motor bearings will stop it. The motor is located in the R. rear corner under the case. The front bearing is accessible from inside the rear one requires removing the case or fishing the straw thru it.
DickyO
Posted on Mar 10, 2012
SOURCE: wheelwriter 15 series II
The ribbon drive motor might be n/g. I think 6 beeps is the ribbon motor located under the gear on the ribbon cartridge.
Posted on Feb 09, 2008
  • 3594 Answers
SOURCE: Wheelwriter 10 Series II doesn't work
Sounds like a keyboard problem, contact George Beyers Co. @ 1-800-392-8085
DickyO
Posted on Feb 23, 2008
  • 3594 Answers
SOURCE: Need owner's manual for IBM/Lexmark wheelwriter 30 series II
I can send you acopy of a ww30 manual for 25.00
DickyO
Posted on Mar 04, 2008
  • 3594 Answers
Try a little light oil on the printer shaft. WD40 works well.
DickyO
Posted on May 16, 2008
  • 3594 Answers
SOURCE: IBM WHEELWRITER 6 SERIES II - HOW DO YOU TURN OFF
Hold the Code key and press either the "U" or "I" key depending on which underlind mode you are in.
DickyO
Posted on Mar 09, 2009
Do you have a manual for IBM Wheelwriter 50 Series II
press line space button until the light under the number 1 key is lite
Oct 16, 2014 | Office Equipment & Supplies
IBM wheelwriter 50 series 2 typewriter
press the line space key until the light under the number 1 key is lite
Oct 16, 2014 | IBM Wheelwriter 50 Series Ii 6788 Tested...
Ibm wheelwriter 6 Series II
Your print solenoid probably has a broken cap. There are some companies that sell the "kit" with instructions on how to replace the cap.
Apr 28, 2014 | IBM Lexmark Wheelwriter 6 Series II
IBM Wheelwriter 30 Series II Since changing
The ribbon may not be fully seated on the ribbon deck. The blue latch has to hol it in place.
DickyO
Jun 30, 2011 | Lexmark Wheelwriter 30 Series II...
Will not print my job
If you need an instruction book go to lexmak.com there may be an answer in the book.
DickyO
Mar 15, 2010 | Lexmark Wheelwriter 15 Series II...
Wheelwriter series II when I hit return the
The silver shaft that the carrier slide on needs a little lube WD40 works well. Also check for any deprid under the carrier that could interfere with its movement.
DickyO
Dec 26, 2009 | IBM Office Equipment & Supplies
Carriage will not return
the silver shaft that the carrier moves back & fourth on is gummy take a rag & put some light wait oil on it wipe the silver shaft down. With the power off move the carrier back and fouth. spray or put on more oil on shaft wipe down any extra oil.
Jan 22, 2009 | Lexmark Wheelwriter 15 Series II...
DickyO
May 13, 2008 | Lexmark Wheelwriter 10 Series II...
IBM wheelwriter 6 Series II
try turning the machine off put a SMALL amount of oil on the large round rod running across the typewriter manually push the print head left and right a few times to see if it will loosen up. The problem is usually caused be drying oil you may consider having it serviced by a pro.
Oct 31, 2007 | Lexmark Wheelwriter 6 Series II Typewriter
Lexmark Wheelwriter 50 Series II Typewriter Logo
46 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
