Question about Dryers
How do I replace the belt that goes from motor around the drum ?
    Problem Solver:
  • 6 Answers
Takes a little time. front of dryer comes off. drum assembly has a felt gasket attached to front assembly. when you get the front removed the belt can be removed from around drum and motor pulley. most are fairly easy to do, just take your time and find all the screws to remove the front plus most have a clip for final removeal. don't forget to shut off power to dryer. best done by unplugging
Posted on Feb 10, 2012
mikedurland
  • 481 Answers
SOURCE: Fitting new drum belt to Simpson Dryer
it all depends on the brand of the dryer. go here for diagrams for a bunch of brands.
http://www.repairclinic.com/0079.asp
Posted on Jul 06, 2008
  • 417 Answers
SOURCE: Zanussi Tumble dryer belt replacement
Yes, that sounds about right.
Posted on Oct 11, 2008
dragonsthatk
  • 547 Answers
SOURCE: Drive Belt replacement for GE DDE7200SBLWW Dryer
http://www.partstap.com/ please go here for diagram thank you please rate me
Posted on Feb 22, 2009
  • 62 Answers
SOURCE: Belt diagram route for tub
Would this diagram help?
http://www.appliance-parts-warehouse.com/maytag-parts/maytag_parts_view.cfm?id=69871
Posted on Apr 19, 2009
  • 74 Answers
SOURCE: Motor is noisy (loud buzzing). Drum belt seized.
the problem, is with a component,called a capacitor.a capacitor gives a"jump start"to the motor.when this charge or jump start cannot be given,the motor will "hum" or"buzz".a new capacitor should not too expensive.
Posted on Oct 16, 2009
New drive belt on LG dryer to loose?
belt goes around drum the to the right of the tensioner and then to the motor pulley. you have to move the tensioner to the left to get the belt to the motor pulley. so the belt goes to the top of the tensioner, and around it in a clockwise manner, to the motor, not just under the motor and under the tensioner.
Sep 20, 2016 | LG Dryers
My affinity front load washer drum will not move after the water goes in nothing else happens.
The belt needs tightening, remove the back, you will see a belt which goes around the drum & back to the motor, the motor has an adjustment feature that by moving it away from the drum tightens the belt, there should be no more than 8mm deflection either side of the belt when it is adjusted correctly, when this is done replace the back & your machine should spin & wash, If it does not after this simple fix then you either need a replacement panel (Electronics) or a replacement motor
Nov 11, 2014 | Frigidaire Washing Machines
REPLACING THE DRUM BELT
Belt should go around entire drum then around motor pulley (which is metal) and tensioner/safety pulley (which is the white pulley)
Apr 17, 2014 | Haier HLP140E Electric Portable Dryer
NEED TO PUT THE DRUM BELT BACK ON ASAP
The other pulley is spring loaded it puts tension on the belt.
Pull the pulley back and the belt will slip ight over then release the tension pulley and your done!
Changing dryer belt on kirkland/whirlpool dryer took apart dryer but dont see where belt suppose to mount.
Hello. The belt goes around the tub and the tension pulley. In fact, it is always a good idea to replace both the belt and the idler/tension pulley at the same time. J.
If you want a schematic go to searsdirect.com and enter your model number. J.
Jun 27, 2010 | Whirlpool LER4634J Electric Dryer
Need to replace drum belt
Most dryers have a tensioner pulley that the belt needs to go around to keep it tight. The belt goes around the motor pulley and the drum, but it goes around the tensioner pulley in a way that would keep it tight (you also need to release the tension on the tensioner to get the belt around it) If there's not a tensioner pulley there has to be some other means of putting tension on that belt, look around the the other pulleys that the belt goes around.
May 07, 2010 | Whirlpool 6.5 Cu. Ft. Super Capacity Gas...
Best way to replace drum belt
The belt is acessable from the front of the dryer you can remove it by popping the top up then taking off the front of the dryer off the drum will come out now place the belt around the drum and put back in now the belt goes around the drum the motor pulley and under the tentioner pulley replace front and top and you are good to go thank you
Please rate me
Apr 18, 2009 | Bosch Axxis WTA 3003 Electric Dryer
Drum does not rotate
The drum rotates due to a belt that goes around the drum and is driven by a small motor. The most likely answer is that the belt broke. This a common problem on an older dryer. It is relatively easy to replace the belt.
Feb 01, 2009 | Kenmore 62602 Electric Dryer
Dryer belt replacement
To replace the belt, you have to take the front off the dryer and lift out the drum. With the new belt, place it around the drum and with the drum in place put the excess belt through the idler pulley or bracket (depending on your model), then around the motor pulley. You push the bracket or idler arm toward the motor to get the "loop" of the belt around the pulley on the motor. Hope this helps! Paul Hoffmanns
Jun 17, 2008 | Dryers
Replacing maytag dryer belt
looking at the back of the motor where the belt pulley is you would grasp belt coming down from the left side of drum then come across the top of belt pulley that is on motor shaft going clockwise around that pulley then continue back to your left and over the top of belt tension pulley going counterclockwise around that pulley this is when you will have to raise pulley against spring pressure to get belt on then release belt tension pulley make sure that belt is still in belt groove on the drum hope this helps ed
Feb 28, 2008 | Dryers
Dryers Logo
41 people viewed this question
Top Dryers Experts
