Question about Brother IntelliFAX 4750 Plain Paper Laser Fax
Incoming faxes are coming out the back and not out the front
How do I change the output to receive incoming faxes through the front of the machine?
  • dashiell2007 Oct 23, 2008
    Thanks sooo much!
    An user who is expert in 3 categories / brands.
  • Brother Master
  • 1,362 Answers
There is a lever in the back that you need to lift up to make it go to the front
Posted on Oct 23, 2008
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
Nov 29, 2012 | HP LaserJet 3050 All-In-One Printer
How to recieve a fax on the Canon PIXMA MX340 Wireless Office All-in-One Printer
Take your incoming phone line and plug it into the place that says "line" on your fax machine. Plug another phone cord into where it says "phone" and connect this to your telephone. Test to make sure you have chosen the right places by dialing a phone number to fax to and listen for the dial tone. If you get a dial tone, then you have set it up correctly.
On the fax machine look for the button that says "menu". Push it and use the up and down arrows to navigate the options on the display. Look for fax set up and press "ok" or "enter" on the fax machines keyboard to access this area. Look for "number of rings" and change the fax machine to a number of rings that is less then your voice mail box if you have one. Then close and save your choices.
Have someone send a test fax by dialing your phone number for the line connected to the machine. The fax machine will pick up on the number of rings set and automatically begin receiving and printing a copy of your incoming fax.
You cannot use magic jack.
You can also choose to manually answer an incoming fax if you see that your display on the fax machine says "ringing" or incoming" you can push the "start" button and this will start receiving your incoming fax.
Sep 30, 2010 | Canon imageCLASS MF7480 Laser Printer
No Incoming or Out going Faxes Out going faxes
Press Setup Button on front panel of printer
Scroll to Fax Settings ( Or Advanced Fax Settings )
You will find ECM ( Error correction mode )
Turn it OFF
Try to receive Fax, IT should work
Jun 25, 2010 | HP Officejet J5780 All-In-One InkJet...
When incoming fax is coming, mfax machine answers but then says fax not detected on screen. I have tried manually receiving the fax as well and this does not work either.
This can be caused by the incoming call not actually being a fax machine at the other end... like someone has dialled the wrong number.
If you are really certain that the incoming call is actually a fax, then check that you have the phone line plugged into the correct socket on the back of the device.
Dec 03, 2009 | HP Office Equipment & Supplies
How do i set up fax to automaticely receive faxes after several rings
For a phone line dedicated only to the fax machine, the process is as follows:
  1. Press Menu/Set, 0, 1.
  2. You will see the Fax Receive window
  3. Use UP and DOWN arrows to change the setting to FAX ONLY
  4. Press Menu/Set.
  5. Press STOP/EXIT
Your fax machine will now answer every incoming call.
If the fax machine is sharing the phone line with a telephone, repeat the above steps and change from FAX ONLY to FAX/TEL This option will allow you to share the line with a phone only, not an answering machine. Once in FAX/TEL mode, the fax machine will still grab every incoming FAX call, and give a special ring (slightly different than a regular telephone ring) when it's a regular incoming phone call signaling you to answer the phone. I hope this helps with your problem. Best of luck!
Nov 11, 2009 | Brother IntelliFax-2820 Laser Fax
I'm looking for a fax machine that will share a single phone line, so that incoming calls are routed to the phone and incoming faxes are routed to the fax machine. Is this a built in feature?
I don't really know of a fax machine that will do this automaticly. But you have hope at electronics stores or computer stores they sell a spiltter just for this use. All you do to hook it up is there is one spot to plug in the incoming phone line, then at the other end or side depending on type you buy. You'll have one output to fax and one to your telephone. You can fax or receive faxes and make calls. The splitter seperates the uincoming calls as to faxs or calls and sends them to the correct output.
Sep 25, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Unplug for 10 seconds. Set to AUTO ANSWER
Oct 09, 2008 | HP FAX 1250 Fax Machine (Black)
Not receiving incoming Fax
is the number for incoming fax correct and setup properley
Sep 11, 2008 | Brother IntelliFAX 770 Plain Paper Thermal...
Receiving incoming faxes
# Press the button to enter Fax mode. # Press . # Press the right or left arrow button to select [Receive mode settings], then press the button. # Press the up or down arrow to select the receive mode that best suits your needs(you probably want "FAX ONLY" When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only), then press . # Press repeatedly to return to fax standby mode.
Aug 07, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Brother IntelliFAX 4750 Plain Paper Laser Fax Logo
46 people viewed this question
James Cagle
James Cagle
Jim Keysor
